[Ovmsdev] Newbie question & initial report
Mon Oct 9 15:14:31 HKT 2017
Debugging this was simple. In gdb's stack trace, frame 0 pointed to the 'delete' in the destructor that referenced the invalid address due to the uninitialized value.
> On Oct 8, 2017, at 11:31 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Steve,
>> You may have noticed that in 57aab41 I fixed the bug that caused the
>> crash.  The OvmsHttpClient::m_buf variable was not initialized.
> Thanks for that. Nice find. Works for me:
> Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console
> OVMS > ota flash http
> Current running partition is: factory
> Target partition is: ota_0
> Download firmware from api.openvehicles.com/firmware/ota/v3/main/ovms3.bin to ota_0
> Error: Request failed
> W (7274) net: DNS lookup on api.openvehicles.com failed err=202
> Feel bad about that one. I (almost) never do that (I push myself into the habit of adding initialisers and destructors when I create the member variable). Not sure how that slipped through, but it explains the weird stack mess.
>> OTA flash was successfull
>>  Flashed 927744 bytes from api.openvehicles.com/firmware/ota/v3/main/ovms3.bin
>>  Next boot will be from ‘ota_0'
> Looks good! (apart from the spelling error, now fixed)
>> On 9 Oct 2017, at 2:16 PM, Stephen Casner <casner at acm.org> wrote:
>>> On Sun, 8 Oct 2017, Mark Webb-Johnson wrote:
>>> I think that is because no network connection available (wifi). Can
>>> you try with wifi up, running, and an IP address assigned?
>> Checksum is ae7b3ab032f6a5be7a8789650c76ea52 and expected file size is 927777
>> Preparing flash partition...
>> Downloading... (100943 bytes so far)
>> Downloading... (201095 bytes so far)
>> Downloading... (301399 bytes so far)
>> Downloading... (402139 bytes so far)
>> Downloading... (502879 bytes so far)
>> Downloading... (603771 bytes so far)
>> Downloading... (704359 bytes so far)
>> Downloading... (805099 bytes so far)
>> Downloading... (905839 bytes so far)
>> Download file length is 927744 and digest ae7b3ab032f6a5be7a8789650c76ea52
>> Setting boot partition...
>>  Next boot will be from 'ota_0'
>>> Seems stack gets messed up in that case. I'll try to find out why,
>>> but the backtrace isn't helping much.
>> crash.  The OvmsHttpClient::m_buf variable was not initialized.  Now
>> without the wifi connection I get:
>> W (8297) net: DNS lookup on api.openvehicles.com failed err=202
>>                                                        -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171009/becd012b/attachment.htm>
