[Ovmsdev] V3 progress
Mon Oct 23 09:52:33 HKT 2017
All good. I merged it, and changed NL->KS on line 41.
> On 23 Oct 2017, at 9:19 AM, Tom Parker <tom at carrott.org> wrote:
> Hi Geir,
> I see you've got Soule on line 41, and you've used the NL vehicle code on line 63 of vehicle_kiasoulev.cpp.
> Otherwise it looks good.
> I've been porting the Leaf v2 logic with as few changes as possible. The changes are mostly simple, replacement of can_databuffer with d and replacing the global state variables with metrics setters. I can still make sense of a diff between the v3 .cpp file and the v2 .c file. Once I have full feature parity between v2 and v3, I'll probably refactor the cpp code some.
> On 23/10/17 09:50, Geir Øyvind Vælidalo wrote:
>> Mark,
>> I just sent a Pull request for the initial Kia Soul EV-stub.
>> I’m still a newbie on GIT so forgive me if I make a mess! Most of the time spent so far is setting up esp-idf and trying to figure out GIT again 🙂
>> Geir
>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171023/13d05cc7/attachment-0001.html>
