[Ovmsdev] Wifi with spaces in the SSID
Tom Parker
tom at carrott.org
Sun Nov 19 11:14:56 HKT 2017
Observant readers will notice that I made a spelling mistake in the wifi
mode client call to demonstrate the problem, it doesn't work with the
same error even if you spell the ssid correctly.
On 19/11/17 16:12, Tom Parker wrote:
> It appears that you cannot set a configuration value with a name
> containing spaces. It almost works, but it doesn't seem to store them
> correctly:
> OVMS > config set wifi.ssid "Wifi With Spaces" secretpassword
> OVMS > config list wifi.ssid
> wifi.ssid
> AndroidAP
> Wifi With Spaces
> OVMS > wifi mode client "Wifi with spaces"
> Error: SSID password must be defined in config wifi.ssid
> So it thinks it has a configuration value for that network but it
> doesn't work. When you reboot the OVMS you find that the configuration
> item was stored with only the first word of the SSID:
> wifi.ssid
> AndroidAP
> Wifi
