[Ovmsdev] Wifi with spaces in the SSID
Tom Parker
tom at carrott.org
Sun Nov 19 11:12:07 HKT 2017
It appears that you cannot set a configuration value with a name
containing spaces. It almost works, but it doesn't seem to store them
correctly:
OVMS > config set wifi.ssid "Wifi With Spaces" secretpassword
OVMS > config list wifi.ssid
wifi.ssid
AndroidAP
Wifi With Spaces
OVMS > wifi mode client "Wifi with spaces"
Error: SSID password must be defined in config wifi.ssid
So it thinks it has a configuration value for that network but it
doesn't work. When you reboot the OVMS you find that the configuration
item was stored with only the first word of the SSID:
wifi.ssid
AndroidAP
Wifi
