[Ovmsdev] Debugging
Geir Øyvind Vælidalo
geir at validalo.net
Thu Nov 23 06:10:04 HKT 2017
Thanks a lot, Steve! Great explanation :-)
I’m using Mac, so please send the binary and library.
Best regards,
Geir
> 22. nov. 2017 kl. 23:03 skrev Stephen Casner <casner at acm.org>:
> On Wed, 22 Nov 2017, Geir ?yvind V?lidalo wrote:
>> I see some of your are talking about gdb-stub, but I have never used
>> gbd and need some help.
>> How do I debug? What options do I have?
> Happy to help with that. To use the gdb-stub you change the parameter
> in menuconfig / Component Config / ESP32-specific / Panic handler
> behavior / Invoke GDBStub.
> When the crash occurs, you'll be presented with a "gdb>" command
> prompt. You can find references for "gdb commands" online. Here is
> one: http://www.yolinux.com/TUTORIALS/GDB-Commands.html
> The first command I would expect you will want is "bt" which displays
> a stack backtrace telling in which function each call is made,
> including the source line number. The frames on the stack are
> numbered; you can give the command "frame N" where N is a frame number
> to change to the context of that frame, since the lowest one might not
> be the place where things started to go wrong.
> When you're at the right frame, you can use the "print" command to
> look at the value of variables. If variable foo is a pointer, you can
> say "print *foo" to display the contents of the object foo points to.
> In many cases this will be enough to figure out the problem. I also
> use the "x" command to examine memory by address in various ways.
> You can also use the "list" command to see a few lines of source code
> around the point in the code referenced by that stack frame. Usually
> I just look at my source in a separate window.
> When using gdb on a real computer you can set breakpoints before
> starting the program, but I have not learned whether that is possible
> to do with the ESP32.
> As I mentioned in one of the emails, if you are running on a Mac you
> should use the gdb binary that I made which references the newer
> libiconv library in order to avoid gdb getting stuck in an infinite
> loop. If so, let me know and I'll send the binary and library to you.
> If you are running on a different platform, you should check to see
> what version of libiconv DLL (Windows) or shared library (Linux) is
> referenced. On my Mac the new one is 9.0.0 vs. 7.0.0. The old one is
> usable, but you have to be careful not to give any command that might
> result in gdb tryinging to display a variable value that has non-ASCII
> chars.
> -- Steve
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171122/3b29c862/attachment.html>
