[Ovmsdev] Framework V3.1
Thu Jan 12 11:58:23 HKT 2017
Looks good. Nothing to be done at my end.
> On 8 Jan 2017, at 1:40 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> thanks for tidying up :)
> Btw: I removed the private and generated MPLAB IDE files from the git repository and extended the .gitignore accordingly, but I got two of those files back from your commit:
> vehicle/OVMS.X/nbproject/Makefile-impl.mk
> vehicle/OVMS.X/nbproject/private/configurations.xml
> Maybe that's because you had already checked in these files in commit 0ed00448471ae3e5cab22b0e831bb3bacbfb2581 before merging my repository cleanup.
> I've just checked in their removal again, please check if you need to remove them manually though.
> Thanks,
> Am 04.01.2017 um 14:50 schrieb Mark Webb-Johnson:
>> OK. That was a bit of a mess and took some tidying up.
>> I moved NissanLeaf and Mitsubishi to production (and removed them from experimental).
>> Also fixed a small twizy compilation issue (for compiling without twizy config option enabled).
>> Memory status is now:
>> V1_Production: 91% data, 92% program
>> V2_Experimental: 99% data, 85% program
>> V2_Production: 96% data, 76% program
>> V2_TR_Production: 93% data, 76% program
>> V2_RT_Production: 97% data, 100% program - about 130 bytes free
>> All pushed to github.
>>> On 4 Jan 2017, at 9:11 AM, Mark Webb-Johnson <mark at openvehicles.com <mailto:mark at openvehicles.com>> wrote:
>>>> Maybe it's time to move the Leaf & Mitsubishi modules to the production
>>>> build? Is there anything still experimental about them?
>>> I will have a look at this tonight, and move things around as necessary.
>>>> On 4 Jan 2017, at 7:57 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> Sorry, haven't done a batch build before checking in...
>>>> Your description matches what could happen with the buffer bug.
>>>> Regarding the App crashing: hardening it against garbage data is on my
>>>> list. It happened also with the buffer bug on the Twizy, because the
>>>> data parser is a bit too strict.
>>>> Btw: I've been in contact with an enthusiastic Leaf owner named Slava
>>>> from the Ukraine, told him to get in contact with you. He thinks about
>>>> setting up an OVMS server for his region. As you may have guessed, there
>>>> is no NissanConnect in the Ukraine... ;)
>>>> Regards,
>>>> Michael
>>>> Am 03.01.2017 um 23:55 schrieb Tom Parker:
>>>>> On 03/01/17 00:44, Michael Balzer wrote:
>>>>>> As you may have seen, I submitted a rework of the network framework
>>>>>> yesterday.
>>>>> The experimental firmware doesn't build anymore -- there isn't enough
>>>>> space during linking. I removed some of the other cars and it builds
>>>>> again, do we need to split the experimental configuration in two?
>>>>> At the weekend I rebased onto master immediately prior to your changes
>>>>> and then managed to mess up my OVMS while doing some development, I
>>>>> haven't looked into what happened but I saw garbage messages relayed
>>>>> through the server, the OVMS android app crashed on startup (sorry no
>>>>> logs), many "Vehicle authentication failed" messages by email and also
>>>>> a "Vehicle is stopped turned on" via SMS and email (I'm using Dexter's
>>>>> server which sends me emails sometimes).
>>>>> I'm not sure if I ran some bad code of my own or if I fell victim to
>>>>> the buffer problem you've hopefully fixed. My OVMS has been very solid
>>>>> for the last 6 months or so, but I haven't taken any updates until the
>>>>> weekend.
>>>>> I'll read out the EEPROM and test with your updated framework tomorrow.
>>>>> OvmsDev mailing list
>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20170112/8e7d11b4/attachment.htm>
