[Ovmsdev] ODB CAN message decoder?
Tom Parker tom at carrott.org
Mon Feb 6 19:16:24 HKT 2017
On 06/02/17 12:16, Greg D. wrote:
> I currently have a Raspberry Pi with a PiCAN-2 board on top, lashed to
> either an OBDwiz module or a T-Mobile "SyncUp Drive" Wi-Fi hotspot.
> Wireshark running on the Pi captures the initial messages that the
> modules transmit (500kbps assumed).  I need to find a table of what
> these messages translate to, so I can create a small program to
> provide suitable answers.
I'm using an slcan device with socket can on linux and I've found that
wireshark and tcpdump record the CAN frame id with the wrong endianess.
Does the output of candump agree with what you are seeing in wireshark?
I wrote some simple tools for manipulating pcaps.
https://carrott.org/git/leaf-can-dissector.git/blob/HEAD:/pcap-canid-endian-swap.py
fixes the endian bug I'm seeing (only tested on 11 bit identifiers).
https://carrott.org/git/leaf-can-dissector.git/blob/HEAD:/pcap-histogram.py
promises a histogram but disappoints by giving a table. Also it filters
by a hard coded nissan leaf frame id.
https://carrott.org/git/leaf-can-dissector.git/blob/HEAD:/pcap-state.py
prints the last frame seen for each frame id, this is good for looking
at two captures and finding which frames are new
https://carrott.org/git/leaf-can-dissector.git/blob/HEAD:/pcap-to-canplayer-binary.py
converts a pcap into the semi-binary format that canplayer uses. Useful
to play back a pcap file.
Most of these tools operate on stdin and stdout. None of them are
documented, sorry.
You might capture without your obd module plugged in, and then capture
again with it plugged in and look at what new messages are present by
diffing the output of pcap-state.py on each capture.
I'm also working on a MitM for exploring how the Nissan Leaf car
authenticates it's battery. I'm using can4python and I really like the
kayak file format to describe the frames (much easier to understand than
the wireshark dissector I made), see
https://carrott.org/git/leaf-can-utils.git
Unfortunately Can4python doesn't support remote request frames, but
maybe your RTR frames are actually regular frames misinterpreted due to
the endianess bug?
