Sun Dec 31 16:57:00 HKT 2017
Greg,
thanks for testing.
Please check your "can can3 status" output and also check if "level verbose can" + "can can3 trace on" will show frames. Trace output is now done at the
"verbose" level.
To go back in the commit history, use "git log" and "git checkout":
"git log" shows the latest commits. You can checkout any commit by referencing its hash value, i.e. "git checkout 1c833dbcbddd4efdbb7ed765cc3ed96be31c820f" will
set your working tree back to the commit before I started working on the MCP2515 code.
Then you can advance commit by commit to see where the error was introduced.
If you've open changes conflicting with the checkout, git will detect that and tell you. You can then use "git stash" to put them aside, and later on "git stash
pop" to get them back.
Am 31.12.2017 um 07:43 schrieb Greg D.:
> Michael Balzer wrote:
>> Am 30.12.2017 um 19:07 schrieb Greg D.:
>>> The only issue we had was that if you try to transmit several frames back-to-back, the third and subsequent frame sent were all duplicates of the second
>>> frame.  That was fixed by adding a delay in the code, hoping that it would be sufficient for the prior frame to actually get sent.
>> I've replaced that "nasty hack" by a TX buffer status check polling all three buffers, so TX speed on the MCP2515 buses is no longer limited to 100 frames per
>> second.
>> Please test.
> I haven't used the ECU code in the last few merges (maybe a couple of weeks), as I've been playing with the modem, but I just merged and now I'm not seeing
> /any/ frames receive on CAN3.  So, I can't tell exactly when, but it's broken now.
> I forget...  Is there a way to force boot the module from the other flash partition?  I could try that to see if it was just the latest merge.
> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171231/492a393c/attachment.htm>
