[Ovmsdev] Problems ms_v_charge_mode
Geir Øyvind Vælidalo
geir at validalo.net
Sat Dec 2 06:50:49 HKT 2017
Thanks, Steve! It compiles now 🙂
Geir
> 1. des. 2017 kl. 23:34 skrev Stephen Casner <casner at acm.org>:
> Geir,
> You need to select branch release/v2.1 of ESP-IDF. Try the 'git
> branch' command and see if release/v2.1 is there but not selected.
> Then switch to it with 'git checkout release/v2.1'.
> -- Steve
> On Fri, 1 Dec 2017, Geir ?yvind V?lidalo wrote:
>> Thanks a lot for checking this out, Mark! I’m sorry to bother you with these things that probably are very trivial to you. I hope you don’t mind.
>> So… In addition to the things you mention, I found out that I did not have the correct ESP-IDF. I had the espressif-version. I still haven’t got the grips on GIT, so that’s probably the reason for that, and most of the problems I’m having :-D
>> Anyway, I have cloned the open vehicle/esp-idf now and I have pulled the latest build tree for ohms v3, but when i run make it fails with this message:
>> /Users/goev/Prosjekter/ovms3/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:39:41: fatal error: freertos/heap_regions_debug.h: No such file or directory
>> I can’t find heap_regions_debug.h & .c in openvehicles/esp-idf nor in espressif/esp-idf. Do you have those locally on your computer?
>> Best regards,
>> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171201/b6a54719/attachment.htm>
