[Ovmsdev] Modem link-drop crash
Tue Dec 26 03:39:23 HKT 2017
Greg,
It is a feature of idf_monitor that it can reset the device using the
RTS line.  I thought I read somewhere that this could be disabled, but
I didn't find that in the documentation just now.  They did mention an
alternative "make simple_monitor" to run an earlier version.  Maybe it
does not do the reset.
Regarding the need to type Ctrl-J rather than the Enter key, we could
make ConsoleAsync translate \r to \n as ConsoleTelnet and ConsoleSSH
do.
On Mon, 25 Dec 2017, Greg D. wrote:
> 115200 baud (typo?).  Also, you may need to use control-J for the "Enter" key when typing commands.  I have a Raspberry Pi that I can put in the car as a monitor, using Putty for the terminal.
> Will try the new IDE when I get back home.
> Greg
> p.s. Why does 'make monitor' reset the module? Seems to do that about half the time for me...
> On December 25, 2017 1:40:30 AM PST, Tom Parker <tom at carrott.org> wrote:
> >I've also found that you can connect with a terminal emulator at 155200
> >baud and it doesn't reset the ovms (make monitor does reset it) so
> >hopefully next time it stops communicating while driving I'll be able
> >to
> >see what is wrong.
> Sent from my Android device with K-9 Mail. Just so you know...
