[Ovmsdev] GPS / NMEA integration
Sun Dec 10 12:01:25 HKT 2017
I tried with mine. I’m getting the same. But GPGSV is showing 16 satellites… My testing setup is far from ideal, however; with an extension cable and 40’ of GPS antenna stretched across my bedroom to the balcony outside.
It was working on the original prototype I tested, so not sure what has changed.
Quickest is to ask the China supplier to check. I’ve done that, and will let you know the result.
> On 10 Dec 2017, at 6:46 AM, Michael Balzer <dexter at expeedo.de> wrote:
> I'm currently working on the NMEA module. The MUX channel is working, but I don't get a GPS fix.
> I've tried all GPS commands and now suspect my SIMCOM module having a hardware issue.
> I'm doing this:
> OVMS > level debug
> OVMS > power simcom on
> …wait for the MUX to be ready, then issue…
> OVMS > simcom muxtx 4 AT+CGPSNMEA=1
> OVMS > simcom muxtx 4 AT+CGPS=1,1
> …now the SIMCOM begins sending NMEA $GPGGA lines once per second looking like this:
> D (2937174) SIMCOM rx: f9 05 ff 35 24 47 50 47 47 41 2c 2c 2c 2c 2c 2c ...5$GPGGA,,,,,,
> D (2937174) SIMCOM rx: 30 2c 2c 2c 2c 2c 2c 2c 2c 2a 36 36 0d 0a 60 f9 0,,,,,,,,*66..`.
> Normally the modem should get a GPS fix within about 1-2 minutes and begin filling data in the $GPGGA record.
> But my modem won't, it just keeps sending empty fields.
> Can someone please try this with his/her module?
> To disable the GPS receiver, issue:
> OVMS > simcom muxtx 4 AT+CGPS=0
> Thanks & regards,
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/873c2184/attachment.html>
