[Ovmsdev] GPS / NMEA integration
Sun Dec 10 07:55:21 HKT 2017
Nonsense, we're using pin 79, forget that…
…still, it's shorted to GND on my module.
Am 10.12.2017 um 00:53 schrieb Michael Balzer:
> My multimeter says pin 79 (GNSS_ANT) is connected to GND (pins 77, 78 + 80 + frame etc.)…?
> I've measured before & after unplugging the pigtail…
> …and I think I found the bug: it seems our SIMCOM board design is wrong.
> The official docs say GNSS_ANT is pin 79:
> But we're using pin 78:
> Mark, can you confirm this?
> Am 09.12.2017 um 23:46 schrieb Michael Balzer:
>> I'm currently working on the NMEA module. The MUX channel is working, but I don't get a GPS fix.
>> I've tried all GPS commands and now suspect my SIMCOM module having a hardware issue.
>> I'm doing this:
>> OVMS > level debug
>> OVMS > power simcom on
>> …wait for the MUX to be ready, then issue…
>> OVMS > simcom muxtx 4 AT+CGPSNMEA=1
>> OVMS > simcom muxtx 4 AT+CGPS=1,1
>> …now the SIMCOM begins sending NMEA $GPGGA lines once per second looking like this:
>> D (2937174) SIMCOM rx: f9 05 ff 35 24 47 50 47 47 41 2c 2c 2c 2c 2c 2c ...5*$GPGGA,,,,,,*
>> D (2937174) SIMCOM rx: 30 2c 2c 2c 2c 2c 2c 2c 2c 2a 36 36 0d 0a 60 f9 *0,,,,,,,,*66*..`.
>> Normally the modem should get a GPS fix within about 1-2 minutes and begin filling data in the $GPGGA record.
>> But my modem won't, it just keeps sending empty fields.
>> Can someone please try this with his/her module?
>> To disable the GPS receiver, issue:
>> OVMS > simcom muxtx 4 AT+CGPS=0
>> Thanks & regards,
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/052dfd24/attachment-0001.html>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/052dfd24/attachment-0002.png>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/052dfd24/attachment-0003.png>
