[Ovmsdev] GPS / NMEA integration
Sun Dec 10 07:53:30 HKT 2017
My multimeter says pin 79 (GNSS_ANT) is connected to GND (pins 77, 78 + 80 + frame etc.)…?
I've measured before & after unplugging the pigtail…
…and I think I found the bug: it seems our SIMCOM board design is wrong.
The official docs say GNSS_ANT is pin 79:
But we're using pin 78:
Mark, can you confirm this?
Am 09.12.2017 um 23:46 schrieb Michael Balzer:
> I'm currently working on the NMEA module. The MUX channel is working, but I don't get a GPS fix.
> I've tried all GPS commands and now suspect my SIMCOM module having a hardware issue.
> I'm doing this:
> OVMS > level debug
> OVMS > power simcom on
> …wait for the MUX to be ready, then issue…
> OVMS > simcom muxtx 4 AT+CGPSNMEA=1
> OVMS > simcom muxtx 4 AT+CGPS=1,1
> …now the SIMCOM begins sending NMEA $GPGGA lines once per second looking like this:
> D (2937174) SIMCOM rx: f9 05 ff 35 24 47 50 47 47 41 2c 2c 2c 2c 2c 2c ...5*$GPGGA,,,,,,*
> D (2937174) SIMCOM rx: 30 2c 2c 2c 2c 2c 2c 2c 2c 2a 36 36 0d 0a 60 f9 *0,,,,,,,,*66*..`.
> Normally the modem should get a GPS fix within about 1-2 minutes and begin filling data in the $GPGGA record.
> But my modem won't, it just keeps sending empty fields.
> Can someone please try this with his/her module?
> To disable the GPS receiver, issue:
> OVMS > simcom muxtx 4 AT+CGPS=0
> Thanks & regards,
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/6e955658/attachment-0001.html>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/6e955658/attachment-0002.png>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171210/6e955658/attachment-0003.png>
