[Ovmsdev] Possible Manufactoring fault last Batch
Michael Eric Menk mikeemenk at gmail.com
Sun Jan 17 05:50:34 HKT 2016
Hei, I suspect that there may be a problem with the module that I got.
It's not able to get anything from the CAN of my C-Zero, I have
tried 2.6.2, 2.6.5 and 2.8.1. But it's the same problem. I get "just
parked", but the park-counter is not counting up..
Other bugs in Vechle Info on app:
* Jibrish "Type" if type MI is chosen (XX works fine)
* No VIN
* Server version shows vehicle versjon number (Works fine if type=XX)
I have looked trough the code, and I suspect that it would behave that way
if no can messages were retrieved.
On Fri, Jan 8, 2016 at 9:20 PM, Frank Demes <frank.demes at gmx.de> wrote:
> Hi Mark.
> The third module arrived today.
> Besides some poor soldering on the GPRS Switch everything else looked fine.
> My buddys module was also ok.
> What about your module Jeromé?
> Could you figure out why you had problems reading on the CAN-Bus?
> Regards
> Frank
> > Am 21.12.2015 um 09:46 schrieb Frank Demes <frank.demes at gmx.de>:
> > Hi Mark,
> > the module worked „fine" at first.
> > But I got intermittent failures to write some parameters to the Sevcon.
> > That was in the Summer.
> > Now with temperatures dropping the module stopped working altogether.
> > A buddy of mine got his spare OVMS the same as I did.
> > Also I ordered a OVMS last week for another friend of mine.
> > I will check both and get back to you on this.
> > Regards
> > Frank
> >> Am 21.12.2015 um 09:11 schrieb Mark Webb-Johnson <mark at webb-johnson.net
> >> I’m travelling at the moment, but more than 100 of that batch have
> already been shipped and I haven’t heard of this elsewhere. Maybe just that
> one module? Or have you seen it on others as well?
> >> Regards, Mark.
> >>> On 21 Dec 2015, at 7:28 AM, Frank Demes <frank.demes at gmx.de> wrote:
> >>> <image1.PNG>
> >>> The stencil seems to be defect so Vdd is missing some paste.
> >>> Gruß
> >>> Frank
> >>>> Am 21.12.2015 um 00:23 schrieb Frank Demes <frank.demes at gmx.de>:
> >>>> Hi Jérôme,
> >>>> could you check your OVMS for some missing soldering on the CAN chip?
> >>>> Gruß
> >>>> Frank
> >>>>> Am 06.12.2015 um 23:35 schrieb Jérôme Nicolle <jerome at ceriz.fr>:
> >>>>> Le 06/12/2015 23:19, Michael Balzer a écrit :
> >>>>>> you need to switch on the Twizy to read
> >>>>>> registers.
> >>>>> Just tried aboard my twizy, in INIT an ON state, couldn't get any
> reading.
> >>>>> Jérôme Nicolle
> >>>>> 06 19 31 27 14
> >>>>> _______________________________________________
> >>>>> OvmsDev mailing list
> >>>>> OvmsDev at lists.teslaclub.hk
> >>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160116/92e8bbbf/attachment.htm>
