[Ovmsdev] Twizy V3.7.1 / Android App V3.11.2
Tue Jan 5 00:09:33 HKT 2016
V3.7.1 is now final, including flux map optimization for T80 & T45:
http://dexters-web.de/f/tw/OVMS-Twizy-3.7.1.zip
Android App V3.11.2:
http://dexters-web.de/f/tw/OpenVehicleApp-release-3.11.2.apk
- Added Kia Soul images
- Car images set on view creation (avoids short roadster display)
- Added shadow to odometer & speed display to enhance readability on
light backgrounds
- Long click on notification = copy to clipboard
- Twizy specific charge port overlay image
- Twizy: feature label for battery capacity added
Am 02.01.2016 um 20:19 schrieb Michael Balzer:
> Firmware:
> http://dexters-web.de/f/tw-beta/OVMS-Twizy-3.7.1.zip
> Note: this is still "beta" because I've got no info yet on the T45
> SDO values missing and no results from a T45 current modification.
> Framework:
> - Fixed base64decode(), removed bug workarounds
> - base64encode(): return pointer to end of base64 string
> - New net_assert_caller(): check caller, fallback to REGPHONE
> - net_put RAM redirection now uses net_buf[]
> - Code cleanup, size and stack depth optimization
> - Fix: stack overflow/underflow flags cleared after crash
> - Perl diagmode clients: missing license info added
> Documentation:
> - Added developer hints on stack debugging and optimization
> Twizy 3.7.1:
> - New: CFG GET & SET: read/write complete profiles (base64 encoded)
> - CFG GET, SET, INFO & SAVE can be used "offline" (w/o SEVCON access)
> - CFG RESET n = reset EEPROM profile (w/o SEVCON access)
> - Code size and stack depth optimization
> - Frequent CFG errors reported human-readable
> - Button reset result notification now sent via IP/SMS
> - Client utility "cfgconv" to convert SEVCON profiles to/from base64
> CFG GET/SET:
> CFG GET [n]
>     get (download) profile base64 encoded
> CFG SET [n] [base64data]
>     set (upload) profile from base64 encoded string
> with:
>     n = 1..3: from EEPROM
>     else: from current working set
> Hint: to avoid confusion with profile #0, don't use n=0 to address
> the working set. Better use "-" or "ws" (translates to 0), i.e.
>     CFG GET -
>     CFG SET - ...
> or
>     CFG GET WS
>     CFG SET WS ...
> Use the "cfgconv" utility to convert base64 to text or vice versa.
> "cfgconv" online: http://dexters-web.de/cfgconv
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160104/cedf93f4/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160104/cedf93f4/attachment-0002.vcf>
