[Ovmsdev] net.c SOC alert obsolete?
Tue Apr 19 05:23:13 HKT 2016
Tom,
so the roadster doesn't cut off the battery to avoid deep discharging?
Sounds like a bad BMS bug...
Ok, that's a very good reason why this kind of alert should be sent out
on all channels available.
Thanks & regards,
Am 18.04.2016 um 20:56 schrieb Tom Saxton:
> Personally, I like having the second backup warning that doesn’t depend on a setting being right. It’s a big deal if our Roadster gets down to 5% accidentally.
>    Tom
> On 4/18/16, 8:35 AM, "Michael Balzer" <ovmsdev-bounces at lists.teslaclub.hk on behalf of dexter at expeedo.de> wrote:
>> Hi everyone,
>> we've currently two low SOC alerts in the framework, one is the
>> configurable (feature #9) min SOC alert in vehicle_ticker(), the other
>> is the OVMS_SOCALERT code in net_state_ticker600().
>> The latter is fixed to 5% and does not respect user channel &
>> notification configuration. Is there still a use case for this or is it
>> obsolete?
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160418/1b001409/attachment-0002.vcf>
