[Ovmsdev] Android update 3.2.3
Sat Jan 17 22:38:42 HKT 2015
Hi again,
the directory structure changes are not that complex, it's just another
root directory and the sources subdirectory is named "java" instead of
"src".
So here are my changes so far:
https://github.com/dexterbg/Open-Vehicle-Android/commit/56445e31a3de48dfde97956ce70b1153f6729922
Version 3.2.3:
- OCM API update: fixes missing stations, missing detail data
and station address encoding issues
- USSD code dialog is now text field allowing "*" and "#",
default "*100#" (account balance query in most networks)
- 12V battery state display (car info)
- Renault Twizy: "Homelink" gets "Profile" and extended by "Default"
Mark, you need to pull this or add me, I cannot push into the project
repository.
Haven't begun on the range switch, I'm stuck building for my Android
2.3.5 phone -- everything works except the OCM markers, and the log
contains lots of resolver errors (see below). Tried different build
settings and also replacing the google-play-services.jar, but nothing
helps so far.
It must be some build config, as it runs perfectly on my 5.0.2 tablet.
If anyone's got an idea on this, let me know.
Resolver errors on Android 2.3.5:
01-17 13:31:56.788 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to find class referenced in signature (Landroid/app/Fragment;)
unable to resolve virtual method 90:
Landroid/app/Activity;.getFragmentManager ()Landroid/app/FragmentManager;
01-17 13:31:56.948 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 6780:
Lcom/actionbarsherlock/internal/nineoldandroids/widget/NineFrameLayout;.onHoverEvent
(Landroid/view/MotionEvent;)Z
01-17 13:31:56.958 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 5406:
Landroid/widget/FrameLayout;.getAlpha ()F
unable to resolve virtual method 5408:
Landroid/widget/FrameLayout;.getTranslationY ()F
unable to resolve virtual method 5412:
Landroid/widget/FrameLayout;.setAlpha (F)V
unable to resolve virtual method 5420:
Landroid/widget/FrameLayout;.setTranslationY (F)V
01-17 13:31:56.968 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 5100: Landroid/view/ViewGroup;.getAlpha ()F
unable to resolve virtual method 5111:
Landroid/view/ViewGroup;.getTranslationX ()F
01-17 13:31:56.978 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 5112:
Landroid/view/ViewGroup;.getTranslationY ()F
unable to resolve virtual method 5134: Landroid/view/ViewGroup;.setAlpha
(F)V
unable to resolve virtual method 5139:
Landroid/view/ViewGroup;.setTranslationX (F)V
unable to resolve virtual method 5140:
Landroid/view/ViewGroup;.setTranslationY (F)V
01-17 13:31:57.008 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 7644:
Lcom/actionbarsherlock/internal/widget/ActionBarView$HomeView;.onHoverEvent
unable to resolve virtual method 5410:
Landroid/widget/FrameLayout;.onPopulateAccessibilityEvent
(Landroid/view/accessibility/AccessibilityEvent;)V
01-17 13:31:57.049 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 4995:
Landroid/view/View;.jumpDrawablesToCurrentState ()V
unable to resolve virtual method 5003:
Landroid/view/View;.onInitializeAccessibilityEvent
unable to resolve static method 5027:
Landroid/view/View;.resolveSizeAndState (III)I
01-17 13:31:57.079 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve static method 7853:
Lcom/actionbarsherlock/internal/widget/IcsAbsSpinner;.resolveSizeAndState (III)I
01-17 13:31:57.089 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 5117:
Landroid/view/ViewGroup;.onInitializeAccessibilityEvent
(Landroid/view/accessibility/AccessibilityNodeInfo;)
unable to resolve virtual method 5118:
Landroid/view/ViewGroup;.onInitializeAccessibilityNodeInfo
(Landroid/view/accessibility/AccessibilityNodeInfo;)V
unable to resolve virtual method 5122:
Landroid/view/ViewGroup;.onRequestSendAccessibilityEvent
(Landroid/view/View;Landroid/view/accessibility/AccessibilityEvent;)Z
01-17 13:31:57.099 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve direct method 5551:
Landroid/widget/PopupWindow;.<init>
(Landroid/content/Context;Landroid/util/AttributeSet;II)V
01-17 13:31:57.109 7099-7099/com.openvehicles.OVMS E/ResourceType﹕
Style contains key with bad entry: 0x01000000
01-17 13:31:57.109 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
unable to resolve virtual method 5473:
Landroid/widget/LinearLayout;.getAlpha ()F
unable to resolve virtual method 5476:
Landroid/widget/LinearLayout;.getTranslationX ()F
unable to resolve virtual method 5488:
Landroid/widget/LinearLayout;.setAlpha (F)V
unable to resolve virtual method 5498:
Landroid/widget/LinearLayout;.setTranslationX (F)V
01-17 13:31:57.249 7099-7100/com.openvehicles.OVMS E/Database﹕
close() was never explicitly called on database
'/data/data/com.openvehicles.OVMS/databases/sampledatabase'
android.database.sqlite.DatabaseObjectNotClosedException:
Application did not close the cursor or database object that was opened here
at
android.database.sqlite.SQLiteDatabase.<init>(SQLiteDatabase.java:1960)
at
android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:906)
at
android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:940)
at
android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:933)
at
android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:614)
at
android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:203)
at
android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:118)
at
com.openvehicles.OVMS.ui.utils.Database.get_ConnectionTypes_Main(Database.java:222)
at
com.openvehicles.OVMS.utils.ConnectionList.<init>(ConnectionList.java:46)
at
com.openvehicles.OVMS.ui.MainActivity.onCreate(MainActivity.java:59)
at
android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1072)
at
android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1836)
at
android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1893)
at
android.app.ActivityThread.access$1500(ActivityThread.java:135)
at
android.app.ActivityThread$H.handleMessage(ActivityThread.java:1054)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:150)
at android.app.ActivityThread.main(ActivityThread.java:4385)
at java.lang.reflect.Method.invokeNative(Native Method)
at java.lang.reflect.Method.invoke(Method.java:507)
at
com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:849)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:607)
at dalvik.system.NativeStart.main(Native Method)
01-17 13:31:57.879 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕ VFY:
Am 15.01.2015 um 00:38 schrieb Michael Balzer:
> Mark,
> I managed to import the App code into Android Studio and build the
> App, currently running successfully on Android 5.0.2 on my tablet --
> not yet tested on my 2.3 phone.
> I have fixed the OCM integration and the USSD code entry, also added a
> homelink reset menu option and extended the "D" message parsing to
> include 12V reference and charging info, which is then displayed on
> the car info sheet.
> I'll fix the OCM range switch tomorrow (if I find the time).
> I'd like to push my changes back into github, but it seems the change
> to Android Studio / Gradle modified a lot of files, even directory
> layout. It seems I'll have to create a new repository, breaking the
> version history. I'll see if I can do something about that and work in
> my own github account first.
> Am 13.01.2015 um 07:03 schrieb Mark Webb-Johnson:
>> This seems to be a one-liner in res/layout/dlg_pin.xml:
>> <EditText android:id="@+id/etxt_input_value"
>> android:layout_width="match_parent"
>> android:layout_height="wrap_content"
>> android:digits="0123456789"
>> android:password="true"
>> android:inputType="numberSigned" />
>> It seems that the re-use of the showPinDialog in so many places in
>> the Android code is a bit restrictive.
>> We could try changing this to andoid:inputType textPassword.
>> On 12 Jan, 2015, at 1:57 am, Michael Balzer <dexter at expeedo.de
>>> Hi Pierre,
>>> that's a known bug of the App. You currently need to use the perl
>>> client to send USSD codes.
>>> Command code for this is 41, so for your USSD code it's...
>>> ./cmd.pl 41 "*131#"
>>> Am 11.01.2015 um 17:33 schrieb Pierre Uhl:
>>>> Hi everybody,
>>>> I am trying to use USSD Codes. But the App (Android 3.2.2) does not
>>>> accept * and # but only numbers. How can I input *131# to recharge
>>>> the Prepaid SIM-Card?
>>>> Pierre Uhl
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150117/e5cc34f6/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150117/e5cc34f6/attachment-0002.vcf>
