[Ovmsdev] USSD Codes
Thu Jan 15 09:13:49 HKT 2015
Michael,
Thanks. Most appreciated.
Let me know when you have something suitable as a diff.
On 15 Jan, 2015, at 7:38 am, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> I managed to import the App code into Android Studio and build the App, currently running successfully on Android 5.0.2 on my tablet -- not yet tested on my 2.3 phone.
> I have fixed the OCM integration and the USSD code entry, also added a homelink reset menu option and extended the "D" message parsing to include 12V reference and charging info, which is then displayed on the car info sheet.
> I'll fix the OCM range switch tomorrow (if I find the time).
> I'd like to push my changes back into github, but it seems the change to Android Studio / Gradle modified a lot of files, even directory layout. It seems I'll have to create a new repository, breaking the version history. I'll see if I can do something about that and work in my own github account first.
> Am 13.01.2015 um 07:03 schrieb Mark Webb-Johnson:
>> This seems to be a one-liner in res/layout/dlg_pin.xml:
>> <EditText android:id="@+id/etxt_input_value"
>> android:layout_width="match_parent"
>> android:layout_height="wrap_content"
>> android:digits="0123456789"
>> android:password="true"
>> android:inputType="numberSigned" />
>> It seems that the re-use of the showPinDialog in so many places in the Android code is a bit restrictive.
>> We could try changing this to andoid:inputType textPassword.
>> On 12 Jan, 2015, at 1:57 am, Michael Balzer <dexter at expeedo.de> wrote:
>>> Hi Pierre,
>>> that's a known bug of the App. You currently need to use the perl client to send USSD codes.
>>> Command code for this is 41, so for your USSD code it's...
>>> ./cmd.pl 41 "*131#"
>>> Am 11.01.2015 um 17:33 schrieb Pierre Uhl:
>>>> Hi everybody,
>>>> I am trying to use USSD Codes. But the App (Android 3.2.2) does not accept * and # but only numbers. How can I input *131# to recharge the Prepaid SIM-Card?
>>>> Pierre Uhl
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150115/82c70077/attachment.htm>
