[Ovmsdev] Android update 3.5.1
Sat Feb 28 05:15:30 HKT 2015
Chris,
following your report I found some more bugs especially regarding the
car specific filter.
Can you please try this version:
|http://dexters-web.de/f/tw/oVMS-release-3.5.2.apk|
Thanks,
Am 26.02.2015 um 13:21 schrieb Christopher Cook:
> Thanks Michael,
> I've tried changing the settings as you've suggested but no luck so
> far, I possibly need to reinstall. I'd suggest that the default be to
> enable the feature and enable all connections (no connection
> filtering) then let the user decide which ones they're not interested
> in (which will be region specific).
> Chris
> On 25/02/2015 16:54, Michael Balzer wrote:
>> Chris,
>> 1. Check "Options > Settings > Enabled"
>> 2. If the menu reads "Filtered Stations OFF" that means your filter
>> is currently ON, selecting the menu will switch to OFF... not very
>> clear IMO, changing that is on my list, the whole menu code is a
>> little bit strange, depending on hard coded labels... Btw, same menu
>> switching logic applies to the range filter.
>> 3. For the filter you need to configure your connection types in the
>> car menu: click on the edit pen of the car, then on the joystick icon
>> in the top bar, then button "Connections".
>> Am 25.02.2015 um 03:11 schrieb Christopher Cook:
>>> Hi Michael,
>>> I don't use the OVMS app but I tried your version on Android with
>>> the demo car selected. On the Location view should I see charge
>>> points or do I have to do something to make them appear by default?
>>> For me the Demo car is appearing near San Jose, Filtered Stations is
>>> Off, Only show Stations in range is Off.
>>> Chris
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150227/d374abdd/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150227/d374abdd/attachment.vcf>
