[Ovmsdev] Android update 3.5.1
Wed Feb 25 16:54:26 HKT 2015
Chris,
1. Check "Options > Settings > Enabled"
2. If the menu reads "Filtered Stations OFF" that
means your filter is currently ON, selecting the
menu will switch to OFF... not very clear IMO,
changing that is on my list, the whole menu code
is a little bit strange, depending on hard coded
labels... Btw, same menu switching logic applies
to the range filter.
3. For the filter you need to configure your
connection types in the car menu: click on the
edit pen of the car, then on the joystick icon in
the top bar, then button "Connections".
Am 25.02.2015 um 03:11 schrieb Christopher Cook:
> Hi Michael,
> I don't use the OVMS app but I tried your
> version on Android with the demo car selected.
> On the Location view should I see charge points
> or do I have to do something to make them appear
> by default? For me the Demo car is appearing
> near San Jose, Filtered Stations is Off, Only
> show Stations in range is Off.
> Chris
