[Ovmsdev] OVMS as Antithft/Alarm system
Tue Feb 3 05:33:34 HKT 2015
As the server does not know where the App device is, this is more an App
side feature.
The firmware does not need to be changed because it already supports
remote stopping of the car by using the LOCK command. You can already do
that now, but you need to do so manually.
So first step would be a distance alarm, second step would be an
automatic LOCK on alarm.
Sounds pretty simple... I'll have a look at it.
Am 02.02.2015 um 13:23 schrieb Julien Banchet:
> This could be fairly doable without touching the actual oVMS firmware
> code, and working only on the server and client app, right?
> On Feb 2, 2015 1:21 PM, "Gianluca Magalotti" <gianluca at magalotti.net
> <mailto:gianluca at magalotti.net>> wrote:
> Hi,
> it's a bit that I'm using OVMS with my Twizy and I would like to
> share with you an idea I have.
> Can we use OVMS as an antitheft (or at least as an alarm)?
> That's the idea: OVMS (module, server, app) to decide if the car
> is "properly used" or "probably stolen" by means of car position
> AND device with mobile app position.
> Simple rule: If car is moving then send an alarm to the device if
> the the device position is not compatible with car position (Alarm
> can be changedc into stop the car, or whatever can be done by
> means of ovms module).
> Case of more than one device connected: All of devices positions
> are not compatible with the car position.
> There are more complex situations that can have "social aspects"
> (i.e. having an alarm if a device AND the car exit/enter a
> specific area).
> Brainstorming on this are welcome!
> Gianluca
> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150202/128844ee/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150202/128844ee/attachment.vcf>
