[Ovmsdev] OVMS as Antithft/Alarm system
Julien Banchet
jaxx at jaxx.org
Mon Feb 2 20:23:52 HKT 2015
This could be fairly doable without touching the actual oVMS firmware code,
and working only on the server and client app, right?
On Feb 2, 2015 1:21 PM, "Gianluca Magalotti" <gianluca at magalotti.net> wrote:
> Hi,
> it's a bit that I'm using OVMS with my Twizy and I would like to share
> with you an idea I have.
> Can we use OVMS as an antitheft (or at least as an alarm)?
> That's the idea: OVMS (module, server, app) to decide if the car is
> "properly used" or "probably stolen" by means of car position AND device
> with mobile app position.
> Simple rule: If car is moving then send an alarm to the device if the the
> device position is not compatible with car position (Alarm can be changedc
> into stop the car, or whatever can be done by means of ovms module).
> Case of more than one device connected: All of devices positions are not
> compatible with the car position.
> There are more complex situations that can have "social aspects" (i.e.
> having an alarm if a device AND the car exit/enter a specific area).
> Brainstorming on this are welcome!
> Gianluca
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150202/c528fe8c/attachment.html>
