[Ovmsdev] Android update 3.3.1
Christopher Cook
christopher.cook at webprofusion.com
Sun Feb 1 10:13:28 HKT 2015
Michael,
Nice work! If you're interested in extending the OCM integration at all
you could consider:
* Add &includecomments=true to the API call and you will get a
UserComments list for locations where people have left check-in
comments, you will also get a MediaItems list when people have added
photos.
o Example with lots of comments:
http://api.openchargemap.io/v2/poi/?chargepointid=5546&includecomments=true
o Example with several images:
http://api.openchargemap.io/v2/poi/?chargepointid=23178&includecomments=true
* You could add basic buttons to edit, comment and uploads photos.
These would need to launch a browser activity with the appropriate URL
o Edit: http://openchargemap.org/site/poi/edit/{OCM-ID}
o Add Comment: http://openchargemap.org/site/poi/addcomment/{OCM-ID}
o Add Photo: http://openchargemap.org/site/poi/addmediaitem/{OCM-ID}
o Add A New Location (bit more complex an demanding on the
browser): http://openchargemap.org/site/poi/add
I would invalidate the cache a bit more frequently than 4 weeks
(depending on what it's caching). In regions where OCM is popular we
would have a number of POI updates every day. I don't know if the app
informs the user they're seeing cached data and lets them do anything
about it?
On a tanget, we do have an experimental (subject to change) API call for
smaller POI result sets: http://api.openchargemap.io/v2/compactpoi/ it's
the same as the /poi call in terms of filters but it returns a much more
concise result set. Might be worth looking at.
Best regards,
Christopher Cook
On 01/02/2015 06:17, Michael Balzer wrote:
> Hi everyone,
> I fixed the 2.3 compatibility issue. Turned out it was in fact a cache
> error combined with a RAM issue.
> Test APK release can be downloaded from:
> http://dexters-web.de/f/tw/oVMS-release-3.3.1.apk
> Github kept telling me "auth error", so I created a pull request and
> merged it myself =>
> https://github.com/openvehicles/Open-Vehicle-Android/commits/master
> This includes...
> Version 3.3.1: …
> Michael Balzer authored 6 minutes ago
> - Fixed OCM region caching, added cache validation based on time:
> cache reload triggered once every 4 weeks
> - Added OCM maxresults configuration (invalidates cache)
> (+ changed OCM settings layout to TableLayout)
> - Switched OCM JSON parsing to GSON library to reduce RAM usage;
> now >500 chargepoints loadable on Android 2.3 devices again
> - Implemented OCM filtering by vehicle range
> Version 3.2.3: …
> Michael Balzer authored 14 days ago
> - OCM API update: fixes missing stations, missing detail data
> and station address encoding issues
> - USSD code dialog is now text field allowing "*" and "#",
> default "*100#" (account balance query in most networks)
> - 12V battery state display (car info)
> - Renault Twizy: "Homelink" gets "Profile" and extended by "Default"
> Testing & feedback is welcome :-)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150201/772e504b/attachment.html>
