[Ovmsdev] Add ChaDeMo and CSS to car_chargemode
Wed Dec 9 14:50:05 HKT 2015
Yep, please steer clear of the car_chargermode variable. That is really badly named and is more an operation mode (like Eco/Normal on a Prius, for example). I think it is named as it is because the source on the roadster is the charger message.
I suggest:
unsigned char car_chargeplug;
and setup an enumeration as desired. Create it in ovms.{h,c} and then add it on the end of the ’S’ message.
If someone wants to commit that and send in a pull request, I’ll accept (and update the protocol guide myself).
> On 9 Dec 2015, at 3:10 AM, Robert Cotran <robert at cotran.ca> wrote:
> I like the idea of having charge type for logging purposes.
> I agree it shouldn't be combined with the Roadster charging types.
> Can just create a new "field" called connector type?
> On 12/8/2015 2:07 PM, Nikki Gordon-Bloomfield wrote:
>> Charge type would become important if you were automatically sending charge session data back (anonymously) to the OCM database…
>> ᐧ
>> about.me/aminorjourney
>> <https://about.me/aminorjourney?promo=email_sig>
>> On Tue, Dec 8, 2015 at 10:46 AM, Tom Saxton <tom at idleloop.com <mailto:tom at idleloop.com>> wrote:
>> The chargemode currently encodes software charging profiles, based on what the Roadster offers. It's similar to what the early Leafs offered, charging to full or charge to 80%, but more complex setting both a charging limit and target battery temperature ranges.
>> What you are proposing adding is to encode the charging connection type, which is a different kind of thing, orthogonal to the car's chosen charging profile.
>> A Roadster can charge in any of the four profiles from either a Level 1 connection (120V, 12A to 16A) or Level 2 (208V to 240V at up to 70A), for example Standard mode on Level 1 or Range mode on Level 2. So, you can't encode both a charging profile and a connection type with a single number. A Leaf is similar in how those two interact.
>> To me, the interesting thing is more the charge rate (V/A or kW) more than which connector my car uses. I don't need OVMS to tell me how I plugged in, but I do care about knowing how fast it's charging.
>> Tom
>> On 12/8/15, 10:19 AM, "Geir Øyvind Vælidalo" < <mailto:ovmsdev-bounces at lists.teslaclub.hk>ovmsdev-bounces at lists.teslaclub.hk <mailto:ovmsdev-bounces at lists.teslaclub.hk> on behalf of geir at validalo.net <mailto:geir at validalo.net>> wrote:
>> >Hi guys,
>> >I would like to have ChaDeMo and CSS added to car_chargemode, and maybe Type 1 and Type 2 too. Then we can display those names in the apps and maybe even add images for those charge plugs.
>> >I would propose this:
>> >0x00 - Standard
>> >0x01 - Storage
>> >0x02 - ???
>> >0x03 - Range
>> >0x04 - Performance
>> >0x05 - ChaDeMo
>> >0x06 - CSS
>> >0x07 - J1772 Type 1
>> >0x08 - Mennekes Type 2
>> >What to you guys think? Would it be problematic for the server and/or apps if suddenly the Kia Souls stated sending chargemode 0x05?
>> >Best regards,
>> >Geir
>> >_______________________________________________
>> >OvmsDev mailing list
>> >OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>> >http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20151209/53d019ba/attachment.htm>
