[Ovmsdev] Add ChaDeMo and CSS to car_chargemode
Robert Cotran
robert at cotran.ca
Wed Dec 9 03:10:01 HKT 2015
I like the idea of having charge type for logging purposes.
I agree it shouldn't be combined with the Roadster charging types.
Can just create a new "field" called connector type?
On 12/8/2015 2:07 PM, Nikki Gordon-Bloomfield wrote:
> Charge type would become important if you were automatically sending
> charge session data back (anonymously) to the OCM database…
> ᐧ
> https://about.me/aminorjourney
> <https://about.me/aminorjourney?promo=email_sig>
> On Tue, Dec 8, 2015 at 10:46 AM, Tom Saxton <tom at idleloop.com
> <mailto:tom at idleloop.com>> wrote:
> The chargemode currently encodes software charging profiles, based
> on what the Roadster offers. It's similar to what the early Leafs
> offered, charging to full or charge to 80%, but more complex
> setting both a charging limit and target battery temperature ranges.
> What you are proposing adding is to encode the charging connection
> type, which is a different kind of thing, orthogonal to the car's
> chosen charging profile.
> A Roadster can charge in any of the four profiles from either a
> Level 1 connection (120V, 12A to 16A) or Level 2 (208V to 240V at
> up to 70A), for example Standard mode on Level 1 or Range mode on
> Level 2. So, you can't encode both a charging profile and a
> connection type with a single number. A Leaf is similar in how
> those two interact.
> To me, the interesting thing is more the charge rate (V/A or kW)
> more than which connector my car uses. I don't need OVMS to tell
> me how I plugged in, but I do care about knowing how fast it's
> charging.
> Tom
> On 12/8/15, 10:19 AM, "Geir Øyvind Vælidalo"
> <ovmsdev-bounces at lists.teslaclub.hk
> <mailto:ovmsdev-bounces at lists.teslaclub.hk> on behalf of
> geir at validalo.net <mailto:geir at validalo.net>> wrote:
> >Hi guys,
> >I would like to have ChaDeMo and CSS added to car_chargemode,
> and maybe Type 1 and Type 2 too. Then we can display those names
> in the apps and maybe even add images for those charge plugs.
> >I would propose this:
> >0x00 - Standard
> >0x01 - Storage
> >0x02 - ???
> >0x03 - Range
> >0x04 - Performance
> >0x05 - ChaDeMo
> >0x06 - CSS
> >0x07 - J1772 Type 1
> >0x08 - Mennekes Type 2
> >What to you guys think? Would it be problematic for the server
> and/or apps if suddenly the Kia Souls stated sending chargemode 0x05?
> >Best regards,
> >Geir
> >_______________________________________________
> >OvmsDev mailing list
> >OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
> >http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20151208/c63ab6f0/attachment.htm>
