[Ovmsdev] iOS 8.4
Michael Eymann
michael.eymann at me.com
Fri Aug 21 23:16:25 HKT 2015
Happy to Beta-Test
Mit freundlichen Grüßen / Kind regards
Michael Eymann
An den Teichen 34
46519 Alpen
+491722571111
> Am 21.08.2015 um 16:56 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> A lot has changed in iOS 8, and it seems to have broken push notifications (APNS) for new users. Existing users are fine.
> So, I find the few lines that need to be changed, and fixed that. Cool.
> Now, submit to App Store, and Apple requires 64bit.
> OK, change the building settings for a 32bit + 64bit dual package, and rebuild.
> (old) Testflight sdk not compatible (32bit only).
> Remove testflight sdk, and all its tendrils throughout the code base.
> Rebuild.
> 190+ warnings about int vs long.
> Crap de crap de crap.
> Rebuild.
> OK. All clean, built and ready to go.
> Only issue is that all my working devices are IOS 9 beta (for work), and Apple’s not accepting iOS 9 built stuff yet, so I can’t properly test.
> Each of the above steps needs about 15-to-45 minutes of googling.
> So, I have a build (v1.6.6). It is 32bit and 64bit. It seems to work. But, I need help testing.
> Seems Apple have a new test flight integrated to iTunes connect. Never tried it, but you are all about to get an invite ;-)
