[Ovmsdev] CFG commands on RT_Production
Julien NOZAIS
julien.nozais at ext.uni.lu
Fri Sep 26 17:33:25 HKT 2014
Hi Michael,
> Power cycle means switching off and on again -- a reset would do as well if the Twizy had a reset button.
> To change some power map setup you normally turn the key to the first notch, issue the CFG command(s), turn off and then on as usual.
Thank you very much, it clears out the doubts I had on the process. I'll keep on going forward and will update when I have made some progress.
Julien
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140926/b8021ceb/attachment.htm>
