[Ovmsdev] CFG commands on RT_Production
Tue Sep 23 02:02:47 HKT 2014
Hi Julien,
welcome :)
Am 22.09.2014 um 16:55 schrieb Julien NOZAIS:
> *MSG commands*
> My current situation is that I have upgraded my OVMS module to 2.6.5
> firmware with the .hex file provided on GitHub. I have also
> successfully connected to the module via SMS commands and Android App.
> Most of the basic commands that I tried worked.
> I say 'most', because I have set the #15 'write' bit to '1' and
> cleared the #14 bit as well. However, I don't seem to be able to send
> CFG commands via SMS (such as CFG SPEED <speed> for example) in the
> way that the twizy manual describes it. All I get are push
> notifications forwarding my SMS to the app. Is there something I'm
> missing? :(
Yes. That's having read the last page of the manual and/or having
browsed through this list's archive... ;)
The Github hex files are missing the SEVCON functions. You need to
download the latest hex release from the german forum or compile yourself.
To compile yourself you need to define these (and only these) compiler
flags:
OVMS_CAR_NONE
OVMS_CAR_RENAULTTWIZY
OVMS_HW_V2
OVMS_DIAGMODULE
OVMS_INTERNALGPS
OVMS_TWIZY_BATTMON
OVMS_TWIZY_CFG
...and you need to manually exclude source files "acc.c", "logging.c"
and all other "vehicle*.c" from the build, because otherwise...
> > Error - section '.romdata_net_msg.o' can not fit the section.
> Section '.romdata_net_msg.o' length=0x000000a8
... this will happen ;)
Just use the context menu "properties" on the files to exclude them.
> *DIAG communication*
> Probably noob error: I tried connecting through the DIAG port with
> minicom. I set minicom to 9600 Bds / 8N1, as specified in the
> developers documentation, but had no success. I think that I'm closed
> since since I received data, but it was just gibberish encoding
> errors. Since these errors are often caused by a wrong baud setting, I
> tried different baud values without success. I hope somebody can point
> out something that I could have missed. I have read the manual, but,
> well... you never know.
Be sure to also disable any flow control. Depending on your serial
adapter, another parameter init and/or hardware reconnect may be
necessary. Also make sure your serial device is writable by your login,
to be sure launch minicom as root.
> I look forward to reading from you !
I look forward to reading about your project :)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140922/92862032/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140922/92862032/attachment-0002.vcf>
