[Ovmsdev] OvmsDev Digest, Vol 32, Issue 5
Thu Sep 25 14:39:13 HKT 2014
We switched to use the EV CAN bus in the summer (just before that hack-a-leaf day).
On 25 Sep, 2014, at 2:27 pm, Aatheus <virtualhermit at gmail.com> wrote:
> On 09/24/2014 09:00 PM, ovmsdev-request at lists.teslaclub.hk wrote:
>> Message: 4
>> Date: Thu, 25 Sep 2014 09:51:47 +0800
>> From: Mark Webb-Johnson <mark at webb-johnson.net>
>> Subject: Re: [Ovmsdev] CFG commands on RT_Production
>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> Message-ID: <DB4A9580-13F5-4343-A098-CB5463C2A3D9 at webb-johnson.net>
>> Content-Type: text/plain; charset=us-ascii
>> Jeff,
>> It should be sufficient, for the Nissan Leaf, to use the V2_EXPERIMENTAL build and select NL and the vehicle type.
>> You also need to make sure you've got the new style Nissan Leaf OBDII cable (with the EV bus CAN pins, not the CAR CAN bus).
> Mark,
> I tried recompiling because I see that the V2_EXPERIMENTAL firmware is
> from 7 months ago, but the vehice_nissanleaf.c was last modified in
> July. I had to exclude all of the other vehicles from the build, or I
> got the "cannot fit" linker error.
> I did not know about the custom LEAF ODBII cable. Was it recently added
> to the Fasttech site? I could have sworn that it wasn't there a month ago.
> Thanks,
> -Jeff
