[Ovmsdev] Can't set OVMS time zone
Tom Saxton
tom at idleloop.com
Thu Nov 27 03:14:59 HKT 2014
My iPhone is on 8.1.1 and updating to the latest OpenVehicles app (1.6.5)
solved the problem. I should have checked for that first.
I see the messages in the server log now look like this:
2014-11-26 18:36:59 C 4 23 -08:00
2014-11-26 18:37:03 c 4 0
Thanks for the the backstory.
Tom
-----Original Message-----
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date: Tuesday, November 25, 2014 at 11:38 PM
Subject: Re: [Ovmsdev] Can't set OVMS time zone
>Tom,
>Is your iPhone on the latest iOS? There was a bug in 8.0 that caused this.
>Also, is the OVMS App up-to-date?
>The latest OVMS App on the latest iOS should be fine. I have iOS v8.1.1
>and App v1.6.4, and it seems on work fine on that combination.
>Regards, Mark.
>P.S. History:
> 1] last betas of iOS 8 had this problem
> 2] We changed the App to work around the problem (thinking apple had
>changed the view container hierarchy)
> 3] iOS 8 was released, as was our App, and all was fine.
> 4] iOS 8.0.1 was released, reverting to old iOS 7 style view container
>hierarchy, and we were broken again
> 5] We released an updated App to resolve the problem (revert to our old
>behaviour)
>On 26 Nov, 2014, at 3:28 pm, Tom Saxton <tom at idleloop.com> wrote:
>> I'm having problems setting the time zone from the iPhone app. When I
>>try
>> to change parameter #23 from -07:00 to -08:00 (or simply -8, or even
>> -07:00), I get a "parameter out of range" error.
>> The server log says:
>> 2014-11-26 07:23:11 C 4 -200 -07:00
>> 2014-11-26 07:23:14 c 4 1 Parameter out of range
>> 2014-11-26 07:23:18 C 4 -200
>> 2014-11-26 07:23:22 c 4 1 Parameter out of range
>> 2014-11-26 07:23:29 C 4 -200 -08:00
>> 2014-11-26 07:23:32 c 4 1 Parameter out of range
>> 2014-11-26 07:24:02 C 4 -200
>> 2014-11-26 07:24:05 c 4 1 Parameter out of range
>> 2014-11-26 07:24:12 C 4 -200 -07:00
>> 2014-11-26 07:24:16 c 4 1 Parameter out of range
>> Is anyone else having this issue?
>> I do have a few small changes in my version of the firmware, but nothing
>> anywhere near the parameter setting code.
>> Tom
