[Ovmsdev] Twizy : Symptomes of a failing charger
Fri May 30 22:40:10 HKT 2014
Hi Julien,
thanks for sharing, that sure looks like the charger issue, dropping and
moving charge power has been reported before as a pre-failure sign.
Be aware the "fix" provided by Renault will mean you get a charger that
works a little bit slower, i.e. they restrict charge power to ~2000W
instead of the 2.300W max with gen 1. But charge times are normally only
extended by a few minutes.
Am 30.05.2014 10:52, schrieb Julien (JaXX) Banchet:
> Updated Whart with a "better", impressive, wobbling:
> https://www.dropbox.com/s/b4udu79ql4h65a5/twizy_charge_wobble.png
> Le 30/05/2014 10:33, Julien (JaXX) Banchet a écrit :
>> Hello,
>> And an extra hello to Twizy Specialists.
>> I'm running into what's believed to be a common Twizy issue
>> concerning the onboard charger
>> Hugs and all!
>> JaXX./.
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140530/5831c333/attachment-0002.vcf>
