[Ovmsdev] Open Charge Map
Christopher Cook
christopher.cook at webprofusion.com
Thu May 22 17:27:46 HKT 2014
I'm easy either way, whatever suits everyone else.
By the way I'm in the process of a bug update to the OCM API
documentation, which is always at: http://openchargemap.org/site/develop/api
There is now also a sandboxed API for testing.
Chris
On 22/05/2014 15:46, Paul Churchley wrote:
> Hi,
> There is a design principle at play here that we would do well not to
> ignore and that is encapsulation.
> As a general rule there are massive benefits to ensuring that each
> system is as much as a "black box" as possible. By that I mean that
> each system functions in isolation taking care of its own business and
> not getting involved in the business of other systems. Designing
> systems, programs etc this way removes, or at least reduces,
> dependencies and decouples functionality.
> The way I see the integration of OVMS and OCM is that OCM should
> remain as much as possible a static partner. It should provide an API
> to allow the adding of locations, checking in, handing out location
> data etc by anyone. Where ever possible, it should not be pulling data
> from other systems if we want to reduce these dependencies and remain
> flexible.
> Functionally this interface is identical to a person doing the same
> things except that it is being automated. We should therefore use the
> same processes. This is not a database transfer, or a bulk data load,
> which would functionally be initiated by OCM. It is an individual
> checking in at a single location and so shouldn't we use the same
> process... OVMS sends the data to OCM via the OCM API? Which userid is
> used to access OCM is clear to me... it is OVMS that is the source and
> so there must be a single user in OCM through which OVMS intefaces
> with the OVMS user id perhaps passed to OCM perhaps as a comment or in
> one of the other API data fields that makes sense.
> For OCM to pull data from OVMS, or any system from that matter, is the
> wrong way to apporach this IMO.
> Paul
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140522/a708533e/attachment.htm>
