[Ovmsdev] Just up and running with OVMS (leaf)
Sun May 4 00:26:34 HKT 2014
Just re-send the MODULE command to redefine the vehicle type.
On 3 May, 2014, at 10:25 pm, Nigel Jones <nigel at cherrybyte.me.uk> wrote:
> Hi,
>  Just a quick update. As of yesterday all my hardware arrived so I spent an hour or two this morning setting up OVMS
>  I have the toolchain sorted, and was able to build the v2 experimental fw from source. This incldues a definition of OVMS_CAR_NISSANLEAF so should load the leaf prototype module
>  The firmware also flashed fine though I had to use the standalone flash tool rather than the IDE for this step as I couldn't find the option to provide 5V from the programmer? Never mind....
>  Once flashed I was able to go through updatign password, registering,. including on openvehicles website. I can chat via SMS, and can see the car in the android app. I can get GPS data and check firmware revision.
> Great.
> I did though when configuring specify a vehicle type of "LE"
> +44NNNNNNNNNN:Module:
> VehicleID:XXX
> VehicleType:LE
> Units:K
> Notifications:SMSIP 9:36 AM
> Me:MODULE XXX K SMSIP LE 9:36 AM
> I then updated this by replacing the correct "NL" for LE, but now I just get back:
> VehicleID:JN1FAAZE0U0005853
> VehicleType:
> Units:K
> Notifications:SMSIP
> NO idea why vehicle type is NULL. I tried a reset. I was thinking I may reset the config completely, but have I done anything obviously wrong? Is it possible to change vehicle type once set?
> Very early stages of learning... with the intent of course to refine the leaf support :-)
> Nigel.
> Nigel Jones
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140504/f5d0486b/attachment.htm>
