[Ovmsdev] Just up and running with OVMS (leaf)
Nigel Jones
nigel at cherrybyte.me.uk
Sat May 3 22:25:47 HKT 2014
Hi,
Just a quick update. As of yesterday all my hardware arrived so I spent an
hour or two this morning setting up OVMS
I have the toolchain sorted, and was able to build the v2 experimental fw
from source. This incldues a definition of OVMS_CAR_NISSANLEAF so should
load the leaf prototype module
The firmware also flashed fine though I had to use the standalone flash
tool rather than the IDE for this step as I couldn't find the option to
provide 5V from the programmer? Never mind....
Once flashed I was able to go through updatign password, registering,.
including on openvehicles website. I can chat via SMS, and can see the car
in the android app. I can get GPS data and check firmware revision.
Great.
I did though when configuring specify a vehicle type of "LE"
+44NNNNNNNNNN:Module:
VehicleID:XXX
VehicleType:LE
Units:K
Notifications:SMSIP 9:36 AM
Me:MODULE XXX K SMSIP LE 9:36 AM
I then updated this by replacing the correct "NL" for LE, but now I just
get back:
VehicleID:JN1FAAZE0U0005853
VehicleType:
Units:K
Notifications:SMSIP
NO idea why vehicle type is NULL. I tried a reset. I was thinking I may
reset the config completely, but have I done anything obviously wrong? Is
it possible to change vehicle type once set?
Very early stages of learning... with the intent of course to refine the
leaf support :-)
Nigel.
Nigel Jones
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140503/00eb36e3/attachment.htm>
