[Ovmsdev] Twizy : Symptomes of a failing charger
Julien (JaXX) Banchet
jaxx at jaxx.org
Fri May 30 23:51:00 HKT 2014
Hi Michael,
Didn't have time to get the Garage on the line, so I don't know what
thay're gonna tell me. That said, I'm not against a few minutes if it
avoids stressing the charger too much.
Can't wait to update the OVMS :)
Thanks,
JaXX./.
Le 30/05/2014 16:40, Michael Balzer a écrit :
> Hi Julien,
> thanks for sharing, that sure looks like the charger issue, dropping
> and moving charge power has been reported before as a pre-failure sign.
> Be aware the "fix" provided by Renault will mean you get a charger
> that works a little bit slower, i.e. they restrict charge power to
> ~2000W instead of the 2.300W max with gen 1. But charge times are
> normally only extended by a few minutes.
> Am 30.05.2014 10:52, schrieb Julien (JaXX) Banchet:
>> Updated Whart with a "better", impressive, wobbling:
>> https://www.dropbox.com/s/b4udu79ql4h65a5/twizy_charge_wobble.png
>> Le 30/05/2014 10:33, Julien (JaXX) Banchet a écrit :
>>> Hello,
>>> And an extra hello to Twizy Specialists.
>>> I'm running into what's believed to be a common Twizy issue
>>> concerning the onboard charger
>>> Hugs and all!
>>> JaXX./.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140530/86c9bab8/attachment-0001.html>
