[Ovmsdev] GPS antenna direction
Mon Jun 23 20:13:00 HKT 2014
Nikolay,
Placement should be with curved side up (flat side down). It just needs a good view to the sky with no metal above.
On 21 Jun, 2014, at 4:33 am, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> The GPS antenna that can be bought for the ovms module from fasttech - what is the best way to mount it?
> Should the black plastic with "GPS" engraved point towards the sky or can I use double side tape and stick the antenna to the windshield with the label upwards.
> Does it really matter?
> I guess direction of placement for the GSM antenna is not as critical, but any thoughts on it?
> Nikolay
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140623/6c1a7f9b/attachment.htm>
