[Ovmsdev] PICkit changes parameters (EEPROM)
Sun Jun 1 05:55:47 HKT 2014
Tom,
that could be the case if it's only me, but this has been reported by
other users as well.
This is my PICkit config:
       <PICkit2PlatformTool>
         <property key="pk2settings.3state" value="false"/>
         <property key="pk2settings.preserveee" value="true"/>
         <property key="pk2settings.setvddvoltage" value="5,00"/>
         <property key="pk2settings.userpgmexec" value="true"/>
         <property key="pk2settings.usetargetpower" value="false"/>
       </PICkit2PlatformTool>
The "5.00 V" setting is marked red with "!!" and "Unknown cause" by the
MPLAB config UI -- I don't know what that means.
Am 31.05.2014 17:40, schrieb Tom Saxton:
> I've never had anything like that happen and I've flashed my device plenty
> of times when doing occasional coding. I have blasted it to all zeros a
> few times, which I attribute to forgetting to flip that setting either in
> the MPLab project or in the PICkit2 downloader.
> Perhaps you have a bad chip or a bad programmer?
> Very curious.
>     Tom
> -----Original Message-----
> From: Michael Balzer <dexter at expeedo.de>
> Date: Saturday, May 31, 2014 at 6:19 AM
> Subject: [Ovmsdev] PICkit changes parameters (EEPROM)
>> Hi all,
>> my PICkit2 frequently alters single EEPROM cells on flashing. It's set
>> to "preserve EEPROM" and mostly does so, the effect only for example
>> changes the server parameter from "64..." to "S4...".
>> Other parameter slots also have been affected, my last flash changed my
>> registered phone id, and a forum member reports a change of the first
>> vehicle id byte from "D" to "R".
>> Is there a way to make the flashing process reliably preserve the EEPROM?
>> Thanks,
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140531/1488712e/attachment-0002.vcf>
