[Ovmsdev] OVMS v3
Mastro Gippo
gipmad at gmail.com
Tue Jun 17 17:50:17 HKT 2014
It's interesting to see that we're moving to a linux solution, but it's a
bit scary at the same time. While a linux box would allow us to get the
basic setup running somewhat quickly, it takes a lot more time, effort and
deep knowlege to make the system really safe and sound.
I also am a bit scared about the power drain, as low power modes in these
machines look quite harder to implement/achieve, but I'm not an expert so I
wouldn't know. I found this: http://www.armdevs.com/WiFiG25.html
Linux, wifi, SD card onboard makes it ideal for OVMS, a microchip SPI-CAN
converter or a dedicated small MCU would complement it.
OR, maybe the best route would be to contact some phone designer in
Shenzhen? I purchased a nice dual sim, 4.5 inch screen, 3G, wifi, BT,
SDcard, 2 cameras + flash, glass touchscreen, 2 batteries, (no GPS, lol)
android device for 270 kuai (~40$) when I was in SZ in April, there MUST be
a small dev board with all we need based on an MTK chipset... Then we just
add a micro for CAN -> whatever and we're set. The fact that android
handles the modem by itself, and it's quite good at it as it consumes very
small power even while receiving notifications from the network makes a
device like that ideal for the development of something very worthwile with
the smallest effort. It would make handling updates incredibly easy too.
The fact that this possibility is SO NEAR, but at the same time EXTREMELY
FAR, is making me crazy. I love to hate China.
Mark, can you cross the border and ask around for MTK boards? :)
MG
2014-06-17 10:24 GMT+02:00 Michael Balzer <dexter at expeedo.de>:
> Regarding the display, only smartphones can possibly do the job. I got
> quite a lot comments from users saying it's good the OVMS can be used
> without a smartphone. Also I personally would like to have a dedicated
> fixed mounted display for the additional live info from the OVMS -- in fact
> that's why the Twizplay (www.twizplay.de) is so appealing.
> Btw: the Twizplay uses an EA DOGM128-6 LCD module which can be controlled
> via SPI and costs around 11 Euro (1 pc). There's a touch panel option for
> this display available, not sure about getting the touch input via SPI
> though.
> For the Samsung NX300, I thought that does 2-3 hours with active camera +
> display + wifi. But I'm not certain about that, just read some consumer
> tests because of the hacking possibilities :-)
> Am 17.06.2014 07:39, schrieb Mark Webb-Johnson:
> What I'm wondering is how valuable it would be to have a device in the
> car capable of:
> - logging can bus traffic to SD card
> - logging can bus traffic remotely (over wifi, etc)
> - Issuing CAN bus requests remotely
> - Receiving firmware updates remotely
> And, what if that device was OVMS itself?
> I know that when I am developing for OVMS, I spend a tremendous amount
> of time switching between OVMS and a CAN bus logger. Also, removing OVMS to
> program it, and plugging it back in again. My lousy cellular reception at
> home doesn't help (although has probably helped OVMS deal with lousy
> cellular reception situations quite well). My ideal device would be in the
> car always. It would allow me to log all traffic (or selected traffic with
> an easy start/stop/trigger), and remotely download those logs. It would
> allow me to make a change to the firmware, remotely, and see the impact.
> The issue would be doing all that while keeping security high as well as
> power consumption and price low.
> Regarding the display, could this be bluetooth to an Android/iPhone? Or,
> do we need a physical display? With most of the device nowadays, adding a
> directly attached display is not too hard (and not too expensive) so long
> as it is on ribbon cable less than perhaps 6" away. But, if a remote
> display is required, that tends to drive up the price dramatically. It
> seems that the CPUs nowadays can directly control a display. But, if you
> want to run a remote display than you have to use UART (or something like
> that) and then run a separate CPU in the display itself.
> On 17 Jun, 2014, at 1:20 pm, Tom Saxton <tom at idleloop.com> wrote:
> I think it's incredibly valuable to keep the $100 price point.
> It seems to me that the hard part of adding support for other vehicles is
> figuring out the CAN bus codes. That's ideally done with hardware
> optimized for that task, which is probably not the OVMS device. There's so
> much framework already in place that once you know how to read values and
> issue commands, getting that into OVMS isn't that hard.
> Making OVMS more expensive to better serve the developer community will
> make it a harder buying decision for end users. Hopefully, we'll
> eventually have thousands of users for every developer.
> It would, of course, be an improvement to make firmware updates easier for
> end users, that is an important issue.
> I would like to see some sort of display, either on the box or remote, so
> I can see SOC in the car without using a phone.
> Tom
> -----Original Message-----
> From: Lee Howard <lee.howard at mainpine.com>
> Date: Monday, June 16, 2014 at 11:55 AM
> Subject: Re: [Ovmsdev] OVMS v3
> I want to say "amen" to both Kevin's and Matt's comments.
> Right now it's really only fully useful for Roadster (and Model S)
> owners. Volt/Ampera owners (and Leaf and Twizzy?) can remotely get a
> limited amount of incredibly useful information (like SOC), but the
> degree of control that the Roaster owners have isn't there (locking,
> unlocking, pre-heating/cooling, etc.).
> I intend to develop-in some of these features over time - at least for
> Volt/Ampera, and the only thing that has me not yet doing that is my
> need to get up-to-speed on the development environment and methods.
> However, even if all of the features available to Roadster owners were
> there for everyone, there is still so much more potential, as Kevin and
> Matt have said.
> If something isn't done to enable the expanded use then OVMS will
> continually only cater to a limited audience: one that wants access to
> various remote-control and remote-tracking features, but with limited
> local (in-car) usability and limited developer appeal.
> Thanks,
> Lee.
> *Lee Howard*
> *Mainpine, Inc. Chief Technology Officer*
> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
> lee.howard at mainpine.com | www.mainpine.com
> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140617/0f81de6c/attachment-0001.html>
