[Ovmsdev] Open Charge Map
Lee Howard lee.howard at mainpine.com
Thu Jun 12 09:48:34 HKT 2014
If I understand correctly, the GPS data is sent from the module in the
car encrypted through the server to the handheld app.  (Correct?)  Or
maybe that was outdated information that I read (README files in the
code).  Hence, I do not understand how OCM would reliably "pull" data
from either the module or the app.  A "push" from module to OCM seems
burdensome and inappropriate.
So, if the GPS data is encrypted all the way from the module to the app,
then I can really only sensibly imagine the app pushing data to OCM.
I must have misunderstood or read outdated information in the READMEs...
because it seems much more-sensible for OCM to be communicating with the
OVMS server... whether it be a push or a pull.  But... if the data is
encrypted passing through the server... then that's out of the question.
And, I presume, then, *that* is where you are looking for help:
implementing the authentication model on the OVMS server. (?)
Thanks,
Lee.
On 06/11/2014 05:25 PM, Mark Webb-Johnson wrote:
> Where I'm really looking for help is the authentication model for the HTTP API. What we have now is kludgy, and it would be good to support OAUTH.
> On 11 Jun, 2014, at 5:25 am, Lee Howard <lee.howard at mainpine.com> wrote:
>> Mark,
>> Has there been any work done in regards to submitting charging data out to OCM? I'm ready to start tinkering on this, and if some work is already being done then I want to attempt to do so collaboratively.
>> Thanks,
>> Lee.
>> On 05/23/2014 01:19 AM, Mark Webb-Johnson wrote:
>>> So, given that we will be ‘giving away’ the data, it comes to the ‘black box’ question of how to do that. My own personal preference is just to provide an api to either PUSH or PULL the data, and the reason for that is I don’t want to be extending the server code to support ten different third-party APIs. That said, I did suggest a PUSH option in the original RFQ, and the thinking behind that is we can format a URL+formdata with parameter-substitution (based on server.conf settings for a particular provider - no code) and just fire it off. I see no problem with a single API key for OVMS to submit to such an external service. For ‘user credit’, it would be nice to have an option where the user could enter an optional username+pin for each service, and we can provide it as part of the PUSHed/PULLed data.
*Lee Howard*
*Mainpine, Inc. Chief Technology Officer*
Tel: +1 866 363 6680 | Fax: +1 360 462 8160
lee.howard at mainpine.com | www.mainpine.com
