[Ovmsdev] New cables just arrived, with strange pinout
Sat Jul 26 23:22:16 HKT 2014
Jeremy,
The prize is that I’ve just committed all the code we made on the recent UK hack-a-leaf day.
The code itself is now based purely on EV bus. It has some active polling (which we are still working on, but doesn’t work properly as is) to try to get to the CAR-CAN bus. It can pickup SOC (based on GIDS) and charge state. Very buggy, but a good start.
To help testing/developing, you’ll need one of these:
http://www.fasttech.com/products/0/10000001/1779000-nissan-leaf-obd-ii-to-db9-data-cable-for-ovms
On 26 Jul, 2014, at 4:12 pm, Jeremy Whaling <jeremy.whaling at gmail.com> wrote:
> This is the required cable for the leaf. "Primary CAN" in this case is the EV CAN bus found on the leaf (non standard pinout) and alternate is CAR can (standard pinout).
> On Sat, Jul 5, 2014 at 3:54 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I just got a shipment of these custom cables.
> Any prizes for guessing the purpose?
> Mark.
> DB9-F to Left-Hand right-angle J1962-M cable with pinout B, as below
> Pinout B
> J1962-M DB9-F Signal
> 4 3 Chassis/Power GND
> 6 5 CAN-H (alternate CAN)
> 14 4 CAN-L (alternate CAN)
> 13 7 CAN-H (primary CAN)
> 12 2 CAN-L (primary CAN)
> 16 9 +12V Vehicle Power
> J1962 end should be MALE plug with right angle cable. DB9 end should be FEMALE.
> Both ends should be enclosed in shells, and cable should be 1metre in length.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140726/39ad7945/attachment-0001.html>
Type: image/jpeg
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140726/39ad7945/attachment-0001.jpg>
