[Ovmsdev] New cables just arrived, with strange pinout
Jeremy Whaling
jeremy.whaling at gmail.com
Sat Jul 26 16:12:11 HKT 2014
This is the required cable for the leaf. "Primary CAN" in this case is the
EV CAN bus found on the leaf (non standard pinout) and alternate is CAR can
(standard pinout).
On Sat, Jul 5, 2014 at 3:54 AM, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> I just got a shipment of these custom cables.
> Any prizes for guessing the purpose?
> Mark.
> - DB9-F to Left-Hand right-angle J1962-M cable with pinout B, as below
> *Pinout B*
> J1962-M DB9-F Signal
> 4 3 Chassis/Power GND
> 6 5 CAN-H (alternate CAN)
> 14 4 CAN-L (alternate CAN)
> 13 7 CAN-H (primary CAN)
> 12 2 CAN-L (primary CAN)
> 16 9 +12V Vehicle Power
> J1962 end should be MALE plug with right angle cable. DB9 end should be
> FEMALE.
> Both ends should be enclosed in shells, and cable should be 1metre in
> length.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140726/a2f62239/attachment.html>
