[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard OVMS smvo at mxf.org.uk
Thu Jan 23 22:34:57 HKT 2014
Is there an simple explanation somewhere of the change to the polling
system?
Matt Beard
On 23 January 2014 12:11, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Michael,
> Yep, that’s it.
> Problem is OVMS_POLLER is a compile-time definition, so it must be shared
> by all cars in the configuration. I’ve re-worked it slightly to call the
> poll0 function even there is no poll list defined:
> diff --git a/vehicle/OVMS.X/vehicle.c b/vehicle/OVMS.X/vehicle.c
> index 9c1e9d9..a706bf1 100644
> --- a/vehicle/OVMS.X/vehicle.c
> +++ b/vehicle/OVMS.X/vehicle.c
> @@ -295,15 +295,21 @@ void high_isr(void)
>      can_databuffer[7] = RXB0D7;
>      RXB0CONbits.RXFUL = 0; // All bytes read, Clear flag
>  #ifdef OVMS_POLLER
> -    if ((vehicle_poll_plist != NULL)&&
> -        (can_id >= vehicle_poll_moduleid_low)&&
> -        (can_id <= vehicle_poll_moduleid_high))
> +    if (vehicle_poll_plist != NULL)
> -      if (vehicle_poll_poll0())
> +      if ((can_id >= vehicle_poll_moduleid_low)&&
> +          (can_id <= vehicle_poll_moduleid_high))
> -        vehicle_fn_poll0();
> +        if (vehicle_poll_poll0())
> +          vehicle_fn_poll0();
> +    else
>  #else // #ifdef OVMS_POLLER
>      vehicle_fn_poll0();
>  #endif //#ifdef OVMS_POLLER
> I hope this fixes it.
> Thomas: Can you try to build this version (it is in github master now).
> On 23 Jan, 2014, at 4:29 pm, Michael Balzer <dexter at expeedo.de> wrote:
>  Mark,
> if the Mitsubishi code does not use the new polling hooks, poll0() will
> not be called if the polling code is compiled in.
> I had the same problem for the Twizy, that's why I introduced the
> OVMS_POLLER compiler switch.
> Am 22.01.2014 02:18, schrieb Mark Webb-Johnson:
> Thomas,
>  Strange. So far, I see 4 cars using 2.6.2, but only one (presumably
> yours) is showing authentication errors.
>  I also can't see any changes to the vehicle_mitsubishi.c code that would
> cause poll0 to stop working. It is certainly working in other vehicle
> modules.
>  I'll keep looking, but would be grateful if you could try to narrow down
> the poll0 problem.
>  Regards, Mark.
>  On 22 Jan, 2014, at 5:00 am, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>  Mark,
>  Was testing the new 2.6.2 code on i-Miev today.
>  Two observations:
> - Lots of restarts and "Vehicle authentication failed" messages in the iOS
> app
> - No CAN bus messages form PID in poll0, while messages in poll1 is
> working OK.
>  Programmed the OVMS module with a version, and verified that the module
> was OK.
>  Regards, Thomas
> 2013/10/30 Thomas Bergo <thomas.bergo at gmail.com>
>> Matt,
>>  Please report back when you have done some testing on the QC.
>>  If the car report 0A while QC, the current code will not detect that we
>> are charging. So then we need to rely on the estimated range reported as
>> 255 to detecting that the car is QC.
>>  Regards, Thomas
>> 2013/10/30 Matt Beard OVMS <smvo at mxf.org.uk>
>>>   Hi Thomas,
>>>  During QC you don't get valid values reported in 0x389 - it seems to be
>>> constant 255V, 0A during QC.
>>>  My code is relying on the fact that the estimated range only ever seems
>>> to be reported as 255 during QC (except for the first few messages at
>>> startup, but those are easy to filter out). In my testing so far this seems
>>> to work for detecting the start and end of QC. I am going to be doing 3
>>> more tests today with my latest code and will report back later.
>>>  Matt
>>>  On 27 October 2013 20:13, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>>>>  Hi Matt
>>>>  I have started to look into the QC code. And i have one concern.
>>>>  Have you seen if the voltage and charging current (PID 0x389) is
>>>> reported during QC?
>>>> If not, we are not able to detect that the car is charging during QC
>>>> with current code.
>>>>  Thomas
>>>>  _______________________________________________
>>>> OvmsDev mailing list
> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>  <dexter.vcf>_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140123/b47f98de/attachment.htm>
