[Ovmsdev] Twizy45 testing needed
Julien (JaXX) Banchet jaxx at jaxx.org
Mon Jan 27 16:14:47 HKT 2014
Well, 11km run, with a few higher speed portions.
Achieves illegal speeds swiftly ! (I'll put it back to normal)
RAMPS/SMOOTHING combo kicks, literally.
Actually, when putting the power on, you can hear a "knock" sound, like
if the motor made a x° rotation to sync in some position, but I could be
wrong.
At low speeds, pushing or releasing the accelerator is immediate
followed by the expected behavior, making the car rock a bit.
Range seems affected, no massively but there is a difference, of course,
will have to see that over time, plus it was freezing.
see ya soon !
Le 27/01/2014 02:17, Mark Webb-Johnson a écrit :
> The flexibility in the tuning of this is making me very jealous!
> Mark.
> On 27 Jan, 2014, at 3:14 am, Julien (JaXX) Banchet <jaxx at jaxx.org> wrote:
>> Sure will try tomorrow !
>> Maybe something like this
>> CFG RECUP 25 35
>> CFG TSMAP N 100 100 80 50
>> CFG TSMAP B 75 100 80 60
>>> 39 will have a recup kick with breaks (urban situation anyways, barely ever over that speed, unless I leave early enough :-) )
>> the sub 33kmh will have near matching values between neutral and breaking, a no surprise zone in other words
>> Won’t be getting back much more juice in the end but well, it’s still that :)
>> Will give a shoot to the RAMPS/SMOOTH combo as well,
>> MfG,
>> JaXX
>> De: Michael Balzer dexter at expeedo.de
>> Répondre: Michael Balzer dexter at expeedo.de
>> Date: 26 janvier 2014 at 19:58:38
>> À: Julien (JaXX) Banchet jaxx at jaxx.org, ovmsdev at lists.teslaclub.hk ovmsdev at lists.teslaclub.hk
>> Sujet:  Re: [Ovmsdev] Twizy45 testing needed
>>> Hi Julien,
>>> thanks :-)
>>> Great to read everything works as designed :-)
>>> Supplementing the POWER command, you should also try
>>> RAMPS 100 100
>>> SMOOTH 0
>>> -- this sets start and acceleration ramps to maximum speed and
>>> disables
>>> smoothing. This makes the Twizy much more responsive to the throttle
>>> and
>>> can make more difference than the 11% torque increase (120% will
>>> be cut
>>> down internally to 111%).
>>> For RECUP, take a look at docs/Twizy-Torque-Speed-Profiles.ods:
>>> you can
>>> shape the braking recuperation strength per speed. Try:
>>> TSMAP B 80 100 60 40
>>> -- this is from sheet 2 "Recup1" and will shift the braking recup
>>> max to
>>> ~39 kph. This works pretty well on the T80 with 40% braking recup
>>> level.
>>> Btw: the TSMAP speed points are at the same for the T45.
>>> Am 26.01.2014 19:20, schrieb Julien (JaXX) Banchet:
>>>> Hi all,
>>>> Hi Michael,
>>>> Listen, first things first:
>>>> Wow, what a f*cki’n crazy great job you’ve done there !!!
>>>> Now: well, works as expected on my Twizy45,
>>>> Tried these on a very short run:
>>>> POWER 120 115 110 (I believe I feel a slight difference, but not
>>> that obvious)
>>>> SPEED 60 75 (didn’t have any slope to go beyond, got up to 60 neat
>>> and fast, kind of surprising/scary at first)
>>>> RECUP 27 42
>>>> Ok, Recup: 27 instead of the default 21 (on the T45) is sensible,
>>> at the limit of slowing down a bit to fast for the following cars
>>> without a brake light
>>>> 42 on brake is scary: you’re already at 27, once you barely touch
>>> the brake, 42% recuperation kicks in after half a second, so you
>>> get your expected friction-brake slowdown and boom, an extra
>>> slow down from recuperation… 42 is really too agressive, making
>>> an in between/modulated foot controlled slowdown nearly impossible…
>>>> Will try 25 35 (Delta of 10% instead of 15%)
>>>> We’ll see…
>>>> Again: w00t! in town the crazy parisians will be less tempted
>>> to push me over the road as long as I can keep up with their illegal
>>> speeds !
>>>> (note: This is to be done at your own risk, mostly legal)
>>>> (sorry for the lack of mail quote, I deactivated the digest mode
>>> which is kind of a pita)
