[Ovmsdev] Ampera Range
Denis KRAUTH
denis.krauth at gmail.com
Wed Jan 22 14:28:52 HKT 2014
Hi,
Yes, I agree. If we can not read the actual range estimation of the car from
the bus, then we should use 50 miles (80 km) as ideal range.
Estimated range could be something below that, using a multiplyer.
What we could do to get a better estimate, is to use the temperature, as we
have the value from the car.
It should require a little testing, but we could find out a relation between
temperature (both ext. and battery temp.) and the range.
Denis.
De : ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] De la part de Paul Churchley
Envoyé : mercredi 22 janvier 2014 02:36
À : OVMS Developers
Objet : Re: [Ovmsdev] Ampera Range
In my experience the range from 100% in ideal conditions rarely exceeds 50
miles. It does occasionally and many have done well over that but for the
vast majority, for the vast majority of the time, an ideal conditions range
is 50 miles.
We have the SOC% so can we not simply use that to adjust the ideal range?
My normal range varies from about 45 miles to about 30 miles depending on
temp, speed etc so can we just adjust the ideal range by say, 4/5 to give
typical range?
I realise that these are not scientific ways to estimate range but perhaps
that is about as good as we can expect for now? We can adjust these
multipliers once we have had a chance to test it out.
Could we use parameters to set a personal 100% ideal range and 100% typical
range? The module could then provide a personal range based on our personal
parameters and as we get better (or worse!) as EV driving so we could then
adjust our personal preferences and tune our own personal range.
On 22 January 2014 01:24, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
Seems to be a hard-coded constant:
va_drive_distance_bat_max = MiFromKm(35); // initial Battery distance in
km
I think we could be a bit 'smarter' with this - particularly given the
'ideal' and 'estimated' range indicators we have.
Any ideas?
On 22 Jan, 2014, at 12:17 am, Steve Gadd <ste_gadd at hotmail.com> wrote:
That's odd because i've just noticed that in the past few days - the range
now being displayed on my Volt, which used to be as you described, is now
quite acurate?
Steve.
_____
Date: Sat, 18 Jan 2014 08:58:56 +0000
To: ovmsdev at lists.teslaclub.hk
Subject: [Ovmsdev] Ampera Range
Just a bit of feedback regarding the range displayed on the phone app for
the Ampera.
A full charge currently displays a range of about 22 miles. This is probably
a bit over half the real range and well below the estimated range on the car
dash.
OvmsDev at lists.teslaclub.hk
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140122/7b6a43da/attachment.html>
