[Ovmsdev] Twizy release 3.4.0
J-C Saint-Pô
jcsaintpo at gmail.com
Thu Aug 7 15:10:19 HKT 2014
i would just buy a twizy to be able to use ovms :-)))
2014-08-07 8:06 GMT+02:00 Michael Balzer <dexter at expeedo.de>:
> I missed one important change for the summary:
> The first RAMPS parameter ("start") now needs to be given in per mille
> instead of percent, and allows a value range of 1..250.
> This allows for fine control over the start ramp, which also applies to
> transitions from driving to recuperation.
> Stored profiles need to be updated manually.
> Am 06.08.2014 23:39, schrieb Michael Balzer:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commit/efe844828aa5ef9e68bbbf940379015a79ee14c8
> - Automatic recuperation level adjustment from BMS max power reading
> - SEVCON auto-login retries on switch-on
> - Power map debug output optimized
> - CFG POWER now allows power_low param up to 139% (same level as
> high=130%)
> - Send power statistics only if 25+ Wh used
> - Collect power (/current) min/max values per GPS section
> - Preop mode safety check in configmode() to protect against delayed
> SMS
> - Accel/decel stats now based on running average of speed changes
> - Client scripts now generate CSV header lines
> Note: had to exclude Tesla Roadster specific CAN data from diag module
> to get space. If other cars need these, a new preprocessor switch
> can be introduced.
> - Bugfix: RT-PWR-Log speed/accel stats output fixed for 0 distances
> (charge/onoff)
> - Now checking for carbits vehicle alert & (new) info suppression
> (info suppression applies to trip reports)
> Framework:
> - Added car bits flag FEATURE_CB_SVINFOS (0x10): 1 = suppress vehicle
> informational notifies (currently only used on Twizy)
> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
http://home.scarlet.be/jcsaintpo
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140807/5832ecbc/attachment.htm>
