[Ovmsdev] Twizy release 3.4.0
Thu Aug 7 05:39:30 HKT 2014
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commit/efe844828aa5ef9e68bbbf940379015a79ee14c8
- Automatic recuperation level adjustment from BMS max power reading
- SEVCON auto-login retries on switch-on
- Power map debug output optimized
- CFG POWER now allows power_low param up to 139% (same level as high=130%)
- Send power statistics only if 25+ Wh used
- Collect power (/current) min/max values per GPS section
- Preop mode safety check in configmode() to protect against delayed SMS
- Accel/decel stats now based on running average of speed changes
- Client scripts now generate CSV header lines
Note: had to exclude Tesla Roadster specific CAN data from diag module
to get space. If other cars need these, a new preprocessor switch
can be introduced.
- Bugfix: RT-PWR-Log speed/accel stats output fixed for 0 distances
(charge/onoff)
- Now checking for carbits vehicle alert & (new) info suppression
(info suppression applies to trip reports)
Framework:
- Added car bits flag FEATURE_CB_SVINFOS (0x10): 1 = suppress vehicle
informational notifies (currently only used on Twizy)
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140806/4b7aa602/attachment.vcf>
