[Ovmsdev] OvmsDev Digest, Vol 31, Issue 1
Aatheus virtualhermit at gmail.com
Sat Aug 2 12:10:58 HKT 2014
Mark,
Fair point on the diag port being more of a 'power user' input.
Regarding the SIM card, I was not able to get the card to register on
the AT&T or T-mobile networks using my unlocked quad band phone. The
registration timed out. It may in fact be my SIM. And no, the GSM lock
is not set on the module.
I was able to get some output using the 'diag' command. The signal
strength bounces between 0 and 24 every few minutes. Also, the VIN is
reported is random characters, plus part of the SIM's serial. This is on
a 2014 LEAF S trim (US).
Thanks,
-Jeff
On 08/01/2014 09:00 PM, ovmsdev-request at lists.teslaclub.hk wrote:
> Message: 2
> Date: Fri, 01 Aug 2014 10:54:52 +0200
> From: Michael Balzer <dexter at expeedo.de>
> Subject: Re: [Ovmsdev] OvmsDev Digest, Vol 30, Issue 12
> To: ovmsdev at lists.teslaclub.hk
> Message-ID: <53DB55DC.9070706 at expeedo.de>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Jeff,
> I think the diag port is not something a normal user should be
> confronted with. The OVMS setup and troubleshooting is already quite
> complex for a simple user. If you're able to use a serial port, you're
> able to find and read the tech docs -- just my 2 cents.
> Now for your trace: is a GSM lock configured (parameter #13)? If so, try
> without.
> Also, does the SIM work correctly in a mobile phone?
> Am 01.08.2014 06:46, schrieb Aatheus:
>> Mark,
>> Thank you for the info. Can the serial port parameters get added to the
>> helpme page? The info is not findable anywhere on the page. I did find
>> it in the development PDF, but it was hard to find!
>> I managed to get serial access to the OVMS board, and it looks like the
>> data call is repeatedly failing. I verified that my GeoSIM card has $15
>> balance on it. Is my SIM card screwed up? I activated the SIM on the
>> GeoSIM site, and I think it's set up ok.
>> RDY
>> +CFUN: 1
>> +CPIN: READY
>> +PACSP: 1
>> +CREG: 0
>> +CREG: 2
>> Call Ready
>> GPS Ready
>> AT
>> OK
>> AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
>> +CSMINS: 0,1
>> OK
>> AT+CCID;+CPBF="O-";+CPIN?
>> (SERIAL OBSCURED)
>> +CPIN: READY
>> OK
>> AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;+CLTS=1;E0
>> +IPR: 9600
>> OK
>> ERROR
>> +CREG: 3
>> +CREG: 0
>> OK
>> +CSMINS: 0,1
>> OK
>> (SERIAL OBSCURED)
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> ERROR
>> +CREG: 3
>> OK
>> +CSMINS: 0,1
>> OK
>> (SERIAL OBSCURED)
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> ERROR
