[Ovmsdev] Connection issues
Kevin Sharpe ZCW
kevin.sharpe at zerocarbonworld.org
Mon Sep 30 15:06:33 HKT 2013
I use giffgaff (O2 network) and it works like a charm all over the UK.
I couldn't get GEO-sim to work although I gave up quickly because giffgaff was easy.
Kevin
> On 30 Sep 2013, at 07:34, "Nikki Gordon-Bloomfield" <nikki at aminorjourney.com> wrote:
> If the carrier was the problem, it would be concurrent with the problems I had when I tried to put a non-compatible SIM in the unit.
> Matt, I can recommend O2… if you're having problems with signal in the area.
> I would suggest you run it on the bench for a dummy test in generic mode? See if it connects then -- as Mark says, with GSM Lock…
>> On 30 Sep 2013, at 07:24, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> Matt,
>> One thing glaring is the flapping between Orange and TMO. Can you try to GSMLock to just one (preferred) provider (using PARAM_GSMLOCK, #13)?
>> The log itself shows "PDP: DEACT" - which means it can't establish GPRS. The COPS gets through ok, so it managed to connect to GSM ok - which would seem to indicate the antenna and basic network reception was ok.
>>> On 30 Sep, 2013, at 3:54 AM, Matt Beard <matt at beard.tv> wrote:
>>> I have been having issues with my OVMS module not connection.
>>> When it does connect I tend to find it has very good signal strength, but it often will not connect when I power it on and I find that it drops off quite often.
>>> I received my RS232/USB adaptor so logged the following data, any use?
>>> P.S. This is with a Global GeoSIM, in the UK
>>> ==== LOG ====
>>> GPS Ready
>>> ATREG: 5
>>> OK
>>> AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
>>> +CSMINS: 0,1
>>> OK
>>> AT+CCID;+CPBF="O-";+CPIN?
>>> 89234185500007905230
>>> +CPIN: READY
>>> OK
>>> AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;E0
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"Orange"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"TMO UK"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"Orange"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"TMO UK"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"Orange"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"TMO UK"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"Orange"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"TMO UK"
>>> OK
>>> SHUT OK
>>> OK
>>> OK
>>> +PDP: DEACT
>>> ERROR
>>> OK
>>> +CSMINS: 0,1
>>> OK
>>> +CPIN: READY
>>> OK
>>> +IPR: 9600
>>> OK
>>> +COPS: 0,1,"Orange"
>>> OK
