[Ovmsdev] Units In the iOS app
Matt Beard OVMS smvo at mxf.org.uk
Thu Sep 26 16:50:23 HKT 2013
A couple of comments on this - first, the filter setting seems the wrong
way in the menu!
Second, it doesn't do what it says on the tin - please see attached pics.
Matt
On 26 September 2013 08:48, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Matt,
> Should be all stations within the car's estimated range (at the moment).
> On the map screen, you can tap the top-left station icon and turn off the
> "Only show stations in range", but I am really not sure how effective that
> is.
> On 26 Sep, 2013, at 3:39 PM, Matt Beard <matt at beard.tv> wrote:
> Ok, very cool, thanks!
> I notice that the chargers shown on the map are only those "within range"
> but there seems to be some sort of fudge-factor. My range I showing as
> 68mi, but I know there is a charger 60mi away and it does not show up. The
> inner red circle seems to be the limit and it is quite a lot less than
> 68mi. Is the fudge-factor adjustable?
> Matt
> On Wednesday, September 25, 2013, Mark Webb-Johnson wrote:
>> In the system settings app, find Open Vehicles in the listed apps, and
>> you can find the configuration settings for this.
>> Regards, Mark
>> > On 26 Sep, 2013, at 5:55 am, Matt Beard <matt at beard.tv> wrote:
>> > Hi,
>> > I want my distances in miles, but temperatures in Celsius. Is this
>> possible in the app, or can it be added? It would really help in the UK.
>> > Matt Beard
>> > _______________________________________________
>> > OvmsDev mailing list
>> > OvmsDev at lists.teslaclub.hk
>> > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130926/a8158a11/attachment.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130926/a8158a11/attachment-0008.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130926/a8158a11/attachment-0009.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130926/a8158a11/attachment-0010.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130926/a8158a11/attachment-0011.jpg>
