No subject
Fri Sep 27 23:39:33 HKT 2013
'Debug-Only Msg' in blue, in the top left corner of the message.
I hadn't noticed that before.
I think the only way I am going to be able to work this out is to try to
spoof some messages to the car and see what comes up on the VDS.
On 5 Nov, 2013, at 7:31 am, Tom Saxton <tom at idleloop.com> wrote:
> I looked at all of the data and assumed that all messages that had text b=
ut
> aren't marked as DMC are not debug messages. I ignored messages that had =
no
> text.
>=20
> The DMC messages have no bits in common. Together, they use the bits in
> 0x08293200.
> The user messages also have not bits in common. Together, they use the bi=
ts in
> 0xC5BFBFFF.
>=20
> Because neither class of messages all share a bit, there is no single bit=
 in
> the data field that marks an error as either debug or user.
>=20
> The bits in 0x00293200 appear in at least one debug message and at least =
one
> user message. Therefore, none of those bits can distinguish one from the
> other.
>=20
> The bits in 0x00293200 appear in at least one user message, but no debug
> messages. Maybe there=B9s something useful there...
>=20
> Unfortunately, there are several messages whose only set data bits also a=
ppear
> in debug messages. For example these two messages have the same data valu=
e,
> but one is debug and one is not.
>=20
>   954 00000000001000000000000000000000 00200000      2097152 Line Voltage=
 Lost
> Sync
>  1146 00000000001000000000000000000000 00200000      2097152 DMC Motor Fa=
n
> Problem
>=20
> Therefore, the data value cannot be used to distinguish debug messages fr=
om
> user messages.
>=20
> Bummer.
>=20
>    Tom
>=20
> From:  Mark Webb-Johnson <mark at webb-johnson.net>
> Reply-To:  OVMS Developers <ovmsdev at lists.teslaclub.hk>
> Date:  Sunday, November 3, 2013 at 5:14 PM
> Subject:  [Ovmsdev] Debug vs Normal messages in Tesla Roadster
>=20
>=20
> I'm not having much luck trying to differentiate between debug and normal
> alert messages in the Tesla Roadster. So, here is my working so far, and
> calling out for ideas.
>=20
> First, here is what is known about the CAN bus message relating to this:
>=20
>>         Error Notification
>>                 ID=3D0x100
>>                 B1=3D0x93
>>                 B2=3DOn, Off, Severity, etc, indication
>>                 B3=3DError code LSB
>>                 B4=3DError code MSB (error code 0xFFFF means no error)
>>                 B5=3DData LSB
>>                 B6=3DData
>>                 B7=3DData
>>                 B8=3DData MSB
>>=20
>>                 N.B. Regarding B2, we've seen:
>>                         0x01 =3D 00000001b =3D Show Alert
>>                         0x00 =3D 00000000b =3D Cancel Alert
>>                         0x05 =3D 00000101b =3D Show Alert
>>                         0x04 =3D 00000100b =3D Cancel Alert
>>                         0x15 =3D 00010101b =3D Show Message
>>                         0x14 =3D 00010100b =3D End Message
>>                      Suggestion is that bit0 is set when alert is raised=
, and
>> zeroed when alert is cleared.
>=20
> Here is some raw can bus messages showing some alerts coming and going:
>=20
>>          6.6947 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>         13.4250 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         20.1151 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         26.8368 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         33.5484 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         40.2862 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         46.9766 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         53.6772 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         60.3577 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         63.2089 100 93 04 78 03 00 00 00 00    ->VDS (message to VDS 93)
>>         67.0663 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>         73.7502 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>         80.2421 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>         80.4511 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>         87.1387 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>         93.8198 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        100.5295 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        107.2297 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        113.9373 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        120.6307 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        121.7428 100 93 04 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        127.3396 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        128.3633 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        134.0215 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        140.7018 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        147.4018 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        147.9951 100 93 04 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        154.1413 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        160.8654 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        167.5743 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        174.5784 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        181.3024 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        188.0697 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        194.7832 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        201.4736 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>=20
> The message shown on the car's VDS includes 4 bytes of data, so we are
> assuming that is B5..B8.
>=20
> The most likely seemed to be B2, which we don't normally report back to t=
he
> server. So, I switched my car to report that rather that the Data (B5..B8=
) and
> here is what I got:
>=20
>> rx msg P ETR2N,1165,5
>> rx msg P ETR2N,888,5
>> rx msg P ETR2N,1124,5
>> rx msg P ETR2N,1166,5
>> rx msg P ETR2N,1146,5
>> rx msg P ETR2N,954,1
>=20
> 1146 (DMC Motor Fan Problem) is a debug message. 954 (line voltage lost s=
ync),
> 1166 (release parking brake), 888 (disarm vehicle with keyfob), 1165 (doo=
r
> ajar) and 1124 (unsafe gear shift) are not. The last number (5 or 1) is t=
he B2
> value corresponding to the alert. I have no idea why 954 should be B2=3D1 a=
nd
> the others B2=3D5, but it seems to have no relation to the debug level of t=
he
> alert.
>=20
> So, how about the ID number of the alert itself? Well, here is the list o=
f
> known alerts, with the ID number shown in binary, hexadecimal and decimal=
> followed by the message:
>=20
>> 0000000000011001 0019    25 Memory Stick transfer in progress (%d%%)
>> 0000000000110101 0035    53 GPS: No data fault
>> 0000000100001101 010d   269 BSM: Negative contactor/economizer stuck low
>> 0000000100011011 011b   283 BSM: Isolation fault
>> 0000000100011110 011e   286 BSM: Isolation fault while contactors closed
>> 0000000100011111 011f   287 Power train Problem Service Required
>> 0000000110011001 0199   409 TPMS: Hardware Error
>> 0000000110101100 01ac   428 12V Battery Service Required
>> 0000001001011100 025c   604 Battery Low Power Reduced
>> 0000001001011110 025e   606 ESS: Range Mode Remaining charge uncertain
>> 0000001001100011 0263   611 ESS: Almost empty - Car stops in 1 mile
>> 0000001101110010 0372   882 Before starting, charge port door must be cl=
osed
>> 0000001101111000 0378   888 Disarm vehicle with key fob before starting
>> 0000001110100110 03a6   934 DMC FW: Line OverCurrent Peak Fault
>> 0000001110101000 03a8   936 Charging Problem
>> 0000001110101001 03a9   937 Charge Problem Extension Cord Detected
>> 0000001110110001 03b1   945 System too hot - Vehicle shutting down
>> 0000001110111001 03b9   953 Line Voltage Lost Sync
>> 0000001110111010 03ba   954 Line Voltage Lost Sync
>> 0000001111001110 03ce   974 DMC FW: Pole Current Error Fault
>> 0000001111010101 03d5   981 DMC FW: Bad State Transition Fault
>> 0000001111000000 03c0   960 DMC FW: VBrickMax versus VBattery Error faul=
t
>> 0000010000110001 0431  1073 DMC FW: PhaseA OverTemp warning. Torque limi=
ted
>> 0000010000110010 0432  1074 DMC FW: PhaseA Temp Diff warning
>> 0000010000110110 0436  1078 DMC FW: PhaseC Temp Diff warning
>> 0000010000111100 043c  1084 External Charger Problem
>> 0000010001000100 0444  1092 Do not plug in charge cable while driving
>> 0000010001001111 044f  1103 ABS & Traction Control Problems. Service
>> Required.
>> 0000010001100100 0464  1124 Unsafe Gear Shift Transition Denied
>> 0000010001111000 0478  1144 Powertrain Problem Service Required
>> 0000010001111010 047a  1146 DMC Motor Fan Problem
>> 0000010010000000 0480  1152 DMC WARNING Charge Thermal Limit
>> 0000010010001101 048d  1165 Key in Key Switch Door Ajar
>> 0000010010001110 048e  1166 Release Parking Brake
>> 0000010010010001 0491  1169 Charge port open
>> 0000010010010010 0492  1170 Tow Mode is not available while car is on
>> 0000010010010110 0496  1174 Fasten Seatbelt
>> 0000010110001000 0588  1416 Low Power System Service Required
>> 0000010110110111 05b7  1463 HVAC: Compressor OverTemp
>> 0000010110111001 05b9  1465 HVAC: Low current pump fault
>> 0000010110111101 05bd  1469 HVAC: Compressor comms timeout
>> 0000010110111111 05bf  1471 HVAC: Compressor DTC comms timeout
>> 0000100000011110 081e  2078 There was a problem processing your request
>=20
> The "DMC" prefix is supposed to indicate a debug message. I don't see any
> pattern. It has also been reported that one single ID can have both debug=
 and
> non-debug variants to the message - see:
> http://www.teslamotorsclub.com/showwiki.php?title=3DRoadster
>=20
> So, here is all the error codes and data that we've seen for the past few
> months (error code, followed by data bytes in binary, hex and decimal):
>=20
>>     0 00000000000000000000000000000000 00000000            0
>>     3 00000000000000000000000000000000 00000000            0
>>     3 00000000000000000000000000000100 00000004            4
>>     3 00000000000000000000000000100000 00000020           32
>>     3 00000000001000000000000000000000 00200000      2097152
>>     3 10000001001000100011100010110100 812238b4   2166503604
>>     3 10000001001010111011100010110100 812bb8b4   2167126196
>>     3 10000001001011001011100010110100 812cb8b4   2167191732
>>    10 00000000000000000000000000010000 00000010           16
>>    10 00000000000000000000000000100000 00000020           32
>>    10 00000000000000000000100000000000 00000800         2048
>>    10 01000000000000000000000000000100 40000004   1073741828
>>    19 00000000000000000000000000000000 00000000            0
>>    25 00000000000000000000000000000000 00000000            0 Memory Stic=
k
>>    25 00000000000000000000000000000001 00000001            1 Memory Stic=
k
>>    25 00000000000000000000000000000010 00000002            2 Memory Stic=
k
>>    25 00000000000000000000000000000011 00000003            3 Memory Stic=
k
>>    25 00000000000000000000000000101111 0000002f           47 Memory Stic=
k
>>    25 00000000000000000000000000110000 00000030           48 Memory Stic=
k
>>    25 00000000000000000000000001000000 00000040           64 Memory Stic=
k
>>    25 00000000000000000000000001000001 00000041           65 Memory Stic=
k
>>    25 00000000000000000000000001000010 00000042           66 Memory Stic=
k
>>    25 00000000000000000000000001100001 00000061           97 Memory Stic=
k
>>    25 00000000000000000000000001100011 00000063           99 Memory Stic=
k
>>    25 00000000000000000000000001100100 00000064          100 Memory Stic=
k
>>    29 00000000000000000000000000000000 00000000            0
>>    32 00000000000000000000000000000010 00000002            2
>>    50 00000000000000000000000000000000 00000000            0
>>    52 00000000000000000000000000000100 00000004            4
>>    53 00000000000000000000000000000000 00000000            0
>>    53 00000000000000000000000000001000 00000008            8
>>    55 00000000000000000000000000100000 00000020           32
>>    57 00000000000000000000000000000000 00000000            0
>>    57 00000000000000000000000010000000 00000080          128
>>    63 00000000000000000010000000000000 00002000         8192
>>   104 00000000000000000100000000000000 00004000        16384
>>   257 00000000000000000000000000000001 00000001            1
>>   263 00000000000000000000000001000000 00000040           64
>>   264 00000000000000000000000010000000 00000080          128
>>   269 00000000000000000001010000000000 00001400         5120 BSM: Negati=
ve
>>   270 00000000000000000010100000000000 00002800        10240
>>   271 00000000000000000100000000000000 00004000        16384
>>   276 00000000000010000000000000000000 00080000       524288
>>   283 00100100000000000000000000000000 24000000    603979776
>>   283 01000100000000000000000000000000 44000000   1140850688
>>   286 00100100000000000000000000000000 24000000    603979776
>>   287 01000100000000000000000000000000 44000000   1140850688 Power train
>>   399 00010000000000000000000000000000 10000000    268435456
>>   399 10000001001000100011100010110100 812238b4   2166503604
>>   399 10000001001000111011100010110100 8123b8b4   2166601908
>>   399 10000001001010111011100010110100 812bb8b4   2167126196
>>   399 10000010111110011011100010110100 82f9b8b4   2197403828
>>   400 00000000000000000000000000000100 00000004            4
>>   400 00000000000000000000000100000000 00000100          256
>>   400 00010000000000000000000000000000 10000000    268435456
>>   400 10000001001000100011100010110100 812238b4   2166503604
>>   400 10000001001000110011100010110100 812338b4   2166569140
>>   400 10000001001000111011100010110100 8123b8b4   2166601908
>>   400 10000001001010111011100010110100 812bb8b4   2167126196
>>   400 10000010111110011011100010110100 82f9b8b4   2197403828
>>   401 00000000000000000000000000000001 00000001            1
>>   403 00000000000000000000000000000100 00000004            4
>>   405 00000000000000000000000000010000 00000010           16
>>   407 00000000000000000000000001000000 00000040           64
>>   409 00000000000000000000000100000000 00000100          256 TPMS: Hardw=
are
>> Error
>>   415 00000000000000000100000000000000 00004000        16384
>>   416 00000000000000001100000000000000 0000c000        49152
>>   420 00000000000000000000000000000001 00000001            1
>>   428 00000000000000000000000000000000 00000000            0 12V Battery
>> Service Required
>>   428 00000000000000000000000000000001 00000001            1 12V Battery
>> Service Required
>>   428 00000000000000000000000000000100 00000004            4 12V Battery
>> Service Required
>>   428 00000000000000000000000000010000 00000010           16 12V Battery
>> Service Required
>>   428 00000000000000000000000000100000 00000020           32 12V Battery
>> Service Required
>>   428 00000000000000000000000001000000 00000040           64 12V Battery
>> Service Required
>>   428 00000000000000000000000010000000 00000080          128 12V Battery
>> Service Required
>>   428 00000000000000000000000100000000 00000100          256 12V Battery
>> Service Required
>>   428 10000001001000011011100010110100 8121b8b4   2166470836 12V Battery
>> Service Required
>>   428 10000001001000011011110110011100 8121bd9c   2166472092 12V Battery
>> Service Required
>>   428 10000001001000100011100010110000 812238b0   2166503600 12V Battery
>> Service Required
>>   428 10000001001000100011100010110100 812238b4   2166503604 12V Battery
>> Service Required
>>   428 10000001001000100011110110011100 81223d9c   2166504860 12V Battery
>> Service Required
>>   428 10000001001001000011100010110100 812438b4   2166634676 12V Battery
>> Service Required
>>   428 10000001001001000011110110011100 81243d9c   2166635932 12V Battery
>> Service Required
>>   428 10000001001010111011100010110100 812bb8b4   2167126196 12V Battery
>> Service Required
>>   428 10000001001010111011110110011100 812bbd9c   2167127452 12V Battery
>> Service Required
>>   529 00000000000000000000000000000000 00000000            0
>>   529 00000000000000000000000000000100 00000004            4
>>   529 00000000000000000000000000001000 00000008            8
>>   529 00000000000000000000000000001100 0000000c           12
>>   529 00000000000000000000000000100000 00000020           32
>>   529 00000000000000000000000100000000 00000100          256
>>   529 00000000000000000000000100000100 00000104          260
>>   529 00000100000000000000000000000000 04000000     67108864
>>   529 00010000000000000000000000000000 10000000    268435456
>>   529 00100100000000000000000000000000 24000000    603979776
>>   529 01000000000000000000000000000100 40000004   1073741828
>>   529 01000000000000000000000000001100 4000000c   1073741836
>>   529 10000001001000100011100010110100 812238b4   2166503604
>>   529 10000001001001001011100010110100 8124b8b4   2166667444
>>   530 10000001001010111011100010110100 812bb8b4   2167126196
>>   537 00000000000000000010000000000000 00002000         8192
>>   537 00010000000000000000000000000000 10000000    268435456
>>   537 10000001001000100011100010110100 812238b4   2166503604
>>   537 10000001001000111011100010110100 8123b8b4   2166601908
>>   538 10000001001000100011100010110100 812238b4   2166503604
>>   538 10000001001000100011110110011100 81223d9c   2166504860
>>   539 00010000000000000000000000000000 10000000    268435456
>>   539 10000001001011000011100010110100 812c38b4   2167158964
>>   539 10000001001011000011110110011100 812c3d9c   2167160220
>>   601 00000000000000000000000000000010 00000002            2
>>   604 00000000000000000000000000010000 00000010           16 Battery Low
>> Power Reduced
>>   604 00000000000000000000000000010010 00000012           18 Battery Low
>> Power Reduced
>>   606 00000000000000000000000001000000 00000040           64
>>   608 00000000000000000000000100000000 00000100          256
>>   609 00000000000000000000001000000000 00000200          512
>>   610 00000000000000000000010000000000 00000400         1024
>>   611 00000000000000000000100000000000 00000800         2048
>>   881 00000000000000000000000000000010 00000002            2
>>   882 00000000000000000000000000000100 00000004            4 Before star=
ting,
>> charge port door must be closed
>>   883 00000000000000000000000000001000 00000008            8
>>   887 00000000000000000000000010000000 00000080          128
>>   888 00000000000000000000000100000000 00000100          256 Disarm vehi=
cle
>>   888 00000000000000000000000100000100 00000104          260 Disarm vehi=
cle
>>   920 00000000000010000000000000000000 00080000       524288
>>   925 00000000000000000000000100000000 00000100          256
>>   925 00000001000000000000000000000000 01000000     16777216
>>   934 00000000000000000000000000000010 00000002            2
>>   935 00000000000000000000000000000100 00000004            4
>>   936 00000000000000000000000000001000 00000008            8 Charging Pr=
oblem
>>   936 00000000000000000000000000001010 0000000a           10 Charging Pr=
oblem
>>   937 00000000000000000000000000010000 00000010           16 Charge Prob=
lem
>>   945 00000000000000000001000000000000 00001000         4096
>>   953 00000000000000000000000000000000 00000000            0 Line Voltag=
e
>> Lost Sync
>>   953 00000000000100000000000000000000 00100000      1048576 Line Voltag=
e
>> Lost Sync
>>   954 00000000001000000000000000000000 00200000      2097152 Line Voltag=
e
>> Lost Sync
>>   955 00000000010000000000000000000000 00400000      4194304
>>   974 00000000000000000000001000000000 00000200          512 DMC FW: Pol=
e
>> Current Error Fault
>>   977 00000000000000000001000000000000 00001000         4096
>>   981 00000000000000010000000000000000 00010000        65536 DMC FW: Bad
>>  1022 00000010000000000000000000000000 02000000     33554432
>>  1023 00000100000000000000000000000000 04000000     67108864
>>  1023 00000110000000000000000000000000 06000000    100663296
>>  1063 00000000000000000000000000000100 00000004            4
>>  1065 00000000000000000000000000010000 00000010           16
>>  1067 00000000000000000000000001000000 00000040           64
>>  1069 00000000000000000000000100000000 00000100          256
>>  1070 00000000000000000000001000000000 00000200          512
>>  1070 00000000000000000000001100000000 00000300          768
>>  1073 00000000000000000001000000000000 00001000         4096 DMC FW: Pha=
seA
>> OverTemp warning. Torque limited
>>  1074 00000000000000000010000000000000 00002000         8192 DMC FW: Pha=
seA
>> Temp Diff warning
>>  1076 00000000000000001000000000000000 00008000        32768
>>  1077 00000000000000010000000000000000 00010000        65536
>>  1077 00000000000000011000000000000000 00018000        98304
>>  1081 00000000000100000000000000000000 00100000      1048576
>>  1082 00000000001000000000000000000000 00200000      2097152
>>  1084 00000000100000000000000000000000 00800000      8388608 External Ch=
arger
>> Problem
>>  1084 00000000100000000000000000010000 00800010      8388624 External Ch=
arger
>> Problem
>>  1085 00000001000000000000000001000000 01000040     16777280
>>  1086 00000010000000000000000000000000 02000000     33554432
>>  1087 00000100000000000000000000000000 04000000     67108864
>>  1092 10000000000000000000000000000000 80000000   2147483648 Do not plug=
 in
>>  1094 00000000000000000000000000000010 00000002            2
>>  1095 00000000000000000000000000000100 00000004            4
>>  1096 00000000000000000000000000000000 00000000            0
>>  1096 00000000000000000000000000001000 00000008            8
>>  1103 00000000000000000000010000000000 00000400         1024 ABS & Tract=
ion
>> Control Problems. Service Required.
>>  1124 10000000000000000000000000000000 80000000   2147483648 Unsafe Gear
>>  1131 00000000000000000000000001000000 00000040           64
>>  1133 00000000000000000000000100000000 00000100          256
>>  1144 00000000000010000000000000000000 00080000       524288 Powertrain
>>  1146 00000000001000000000000000000000 00200000      2097152 DMC Motor F=
an
>> Problem
>>  1146 00001000001000000000000000000000 08200000    136314880 DMC Motor F=
an
>> Problem
>>  1152 00001000000000000000000000000000 08000000    134217728 DMC WARNING
>>  1152 00001000000010000000000000000000 08080000    134742016 DMC WARNING
>>  1152 00001000001000000000000000000000 08200000    136314880 DMC WARNING
>>  1153 00010000000000000000000000000000 10000000    268435456
>>  1160 00000000000000000000000000000001 00000001            1
>>  1161 00000000000000000000000000000010 00000002            2
>>  1161 00000000000000000000000000000011 00000003            3
>>  1162 00000000000000000000000000000100 00000004            4
>>  1162 00000000000000000000000000000101 00000005            5
>>  1162 00000000000000000000000000000110 00000006            6
>>  1162 00000000000000000000000000001100 0000000c           12
>>  1163 00000000000000000000000000001000 00000008            8
>>  1163 00000000000000000000000000001100 0000000c           12
>>  1164 00000000000000000000000000010000 00000010           16
>>  1165 00000000000000000000000000000000 00000000            0 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000100000 00000020           32 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000100001 00000021           33 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000100011 00000023           35 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000101000 00000028           40 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000101001 00000029           41 Key in Key
>> Switch Door Ajar
>>  1166 00000000000000000000000000000000 00000000            0 Release Par=
king
>> Brake
>>  1166 00000000000000000000000001000000 00000040           64 Release Par=
king
>> Brake
>>  1166 00000000000000000000000001000100 00000044           68 Release Par=
king
>> Brake
>>  1167 00000000000000000000000010000000 00000080          128
>>  1169 00000000000000000000001000000000 00000200          512 Charge port=
 open
>>  1169 00000000000000000000001000100000 00000220          544 Charge port=
 open
>>  1170 00000000000000000000010000000000 00000400         1024 Tow Mode is=
 not
>>  1171 00000000000000000000100000000000 00000800         2048
>>  1173 00000000000000000010000000000000 00002000         8192
>>  1173 00000000000000000010000000000001 00002001         8193
>>  1173 00000000000000000010000000100000 00002020         8224
>>  1174 00000000000000000100000000000000 00004000        16384
>>  1174 00000000000000000100000000000010 00004002        16386
>>  1174 00000000000000000100000000000100 00004004        16388
>>  1174 00000000000000000100000000000110 00004006        16390
>>  1174 00000000000000000100000000001100 0000400c        16396
>>  1174 00000000000000000100000000010000 00004010        16400
>>  1174 00000000000000000100000000010100 00004014        16404
>>  1174 00000000000000000100000000100000 00004020        16416
>>  1174 00000000000000000100000001000000 00004040        16448
>>  1400 00000000000000000000000000000001 00000001            1
>>  1401 00000000000000000000000000000010 00000002            2
>>  1412 00000000000000000001000000000000 00001000         4096
>>  1415 00000000000000001000000000000000 00008000        32768
>>  1426 00000100000000000000000000000000 04000000     67108864
>>  1442 01000000000000000000000000000100 40000004   1073741828
>>  1442 01000000000000000000000000001100 4000000c   1073741836
>>  1443 00000000000000000000000000001000 00000008            8
>>  1443 00000000000000000000000000001100 0000000c           12
>>  1443 01000000000000000000000000001100 4000000c   1073741836
>>  1450 00000000000000000000010000000000 00000400         1024
>>  1451 00000000000000000000110000000000 00000c00         3072
>>  1461 00000000001000000000000000000000 00200000      2097152
>>  1463 00000000100000000000000000000000 00800000      8388608
>>  1469 00100000000000000000000000000000 20000000    536870912
>>  1470 01000000000000000000000000000100 40000004   1073741828
>>  1470 01000000000000000000000000001100 4000000c   1073741836
>>  1471 10100000000000000000000000000000 a0000000   2684354560
>>  1493 00000000000000000000000000001000 00000008            8
>>  1545 00000000000000000000000010000000 00000080          128
>>  1545 01000000000000000000000000000100 40000004   1073741828
>>  1554 00000000010000000000000000000000 00400000      4194304
>>  1554 10000001001000100011100010110100 812238b4   2166503604
>>  1560 00000000000000000000000000000000 00000000            0
>>  1560 00000000000000000000000000100000 00000020           32
>>  1560 00000000000000000000000010000000 00000080          128
>>  1560 00000000000000000000001000000000 00000200          512
>>  1562 00000000000000000000000000100000 00000020           32
>>  1562 00000000000000000000000001000000 00000040           64
>>  1562 00000000000000000010000000000000 00002000         8192
>>  1562 10000001001010111011100010110100 812bb8b4   2167126196
>>  1660 00000000000000000000000000010000 00000010           16
>>  1661 00000000000000000000000000100000 00000020           32
>>  1664 00000000000000000000000100000000 00000100          256
>>  3003 00000000000000000000000000000100 00000004            4
>>  3008 00000000000000000000000010000000 00000080          128
>>  3009 00000000000000000000000100000000 00000100          256
>>  3010 00000000000000000000001000000000 00000200          512
>>  3011 00000000000000000000010000000000 00000400         1024
>>  3012 00000000000000000000100000000000 00000800         2048
>>  3012 00000000000000000000110000000000 00000c00         3072
>>  3018 00000000000000100000100000000000 00020800       133120
>>  3020 00000000000010000000000000000000 00080000       524288
>>  3021 00000000000100000000000000000000 00100000      1048576
>>  3023 00000000010000000000000000000000 00400000      4194304
>=20
> Again, I don't see it.
>=20
> Any ideas? I'm stumped.
>=20
>=20
> OvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovms=
dev
--B_3466431514_32795896
Content-type: text/html;
	charset="ISO-8859-1"
Content-transfer-encoding: quoted-printable
<html><head></head><body style=3D"word-wrap: break-word; -webkit-nbsp-mode: s=
pace; -webkit-line-break: after-white-space; color: rgb(0, 0, 0); font-size:=
 14px; font-family: Calibri, sans-serif;"><div>My recent message says "Debug=
 Text" but I assume that's just because I have the VDS in debug mode, thus I=
&#8217;m seeing the debug version of the text, but I would see the message e=
ven if the VDS was in user mode. I would hope I&#8217;d see that message sin=
ce it prevented a charge from completing.</div><div><br></div><div><img src=3D=
"cid:2E3537BC-8E56-428C-A08E-C753EDBD7EB7" type=3D"image/png"></div><div><br><=
/div><div>"Debug-Only Msg" presumably means the message only appears in debu=
g mode. Are all of those messages prefixed by "DMC"? Is that where that term=
 comes from?</div><div><br></div><div>&nbsp; &nbsp;Tom</div><div><br></div><=
span id=3D"OLK_SRC_BODY_SECTION"><div style=3D"font-family:Calibri; font-size:11=
pt; text-align:left; color:black; BORDER-BOTTOM: medium none; BORDER-LEFT: m=
edium none; PADDING-BOTTOM: 0in; PADDING-LEFT: 0in; PADDING-RIGHT: 0in; BORD=
ER-TOP: #b5c4df 1pt solid; BORDER-RIGHT: medium none; PADDING-TOP: 3pt"><spa=
n style=3D"font-weight:bold">From: </span> Mark Webb-Johnson &lt;<a href=3D"mail=
to:mark at webb-johnson.net">mark at webb-johnson.net</a>&gt;<br><span style=3D"font=
-weight:bold">Reply-To: </span> OVMS Developers &lt;<a href=3D"mailto:ovmsdev@=
lists.teslaclub.hk">ovmsdev at lists.teslaclub.hk</a>&gt;<br><span style=3D"font-=
weight:bold">Date: </span> Monday, November 4, 2013 at 5:46 PM<br><span styl=
e=3D"font-weight:bold">To: </span> OVMS Developers &lt;<a href=3D"mailto:ovmsdev=
@lists.teslaclub.hk">ovmsdev at lists.teslaclub.hk</a>&gt;<br><span style=3D"font=
-weight:bold">Subject: </span> Re: [Ovmsdev] Debug vs Normal messages in Tes=
la Roadster<br></div><div><br></div><div><meta http-equiv=3D"Content-Type" con=
tent=3D"text/html charset=3Dwindows-1252"><div style=3D"word-wrap: break-word; -we=
bkit-nbsp-mode: space; -webkit-line-break: after-white-space;">Tom,<div><br>=
</div><div>Yep. I feel there are some big gaps in our understanding of debug=
 messages.</div><div><br></div><div>From Pierre's post yesterday, it also se=
ems that we have 'Debug Text' and 'Debug-Only Msg' in blue, in the top left =
corner of the message.</div><div><br></div><div><img apple-inline=3D"yes" id=3D"=
FDCBB472-887E-445D-9C6A-F6C9E31360E5" height=3D"385" width=3D"542" apple-width=3D"=
yes" apple-height=3D"yes" src=3D"cid:02941424-4E97-458F-B85E-A49E7FAC75FF"></div=
></div></div></span><div><br></div><span id=3D"OLK_SRC_BODY_SECTION"><div><div=
 style=3D"word-wrap: break-word; -webkit-nbsp-mode: space; -webkit-line-break:=
 after-white-space;"><div>I hadn't noticed that before.</div><div><br></div>=
<div>I think the only way I am going to be able to work this out is to try t=
o spoof some messages to the car and see what comes up on the VDS.</div><div=
><br></div><div>Regards, Mark.</div><div><br><div><div>On 5 Nov, 2013, at 7:=
31 am, Tom Saxton &lt;<a href=3D"mailto:tom at idleloop.com">tom at idleloop.com</a>=
&gt; wrote:</div><br class=3D"Apple-interchange-newline"><blockquote type=3D"cit=
e"><div style=3D"word-wrap: break-word; -webkit-nbsp-mode: space; -webkit-line=
-break: after-white-space; font-size: 14px; font-family: Calibri, sans-serif=
;"><div>I looked at all of the data and assumed that all messages that had t=
ext but aren't marked as DMC are not debug messages. I ignored messages that=
 had no text.</div><div><br></div><div>The DMC messages have no bits in comm=
on. Together, they use the bits in 0x08293200.</div><div>The user messages a=
lso have not bits in common. Together, they use the bits in 0xC5BFBFFF.</div=
><div><br></div><div>Because neither class of messages all share a bit, ther=
e is no single bit in the data field that marks an error as either debug or =
user.</div><div><br></div><div>The bits in 0x00293200 appear in at least one=
 debug message and at least one user message. Therefore, none of those bits =
can distinguish one from the other.</div><div><br></div><div>The bits in 0x0=
0293200 appear in at least one user message, but no debug messages. Maybe th=
ere&#8217;s something useful there...</div><div><br></div><div>Unfortunately=
, there are several messages whose only set data bits also appear in debug m=
essages. For example these two messages have the same data value, but one is=
 debug and one is not.</div><div><br></div><div>&nbsp; 954 00000000001000000=
000000000000000 00200000 &nbsp; &nbsp; &nbsp;2097152 Line Voltage Lost Sync<=
/div><div>&nbsp;1146 00000000001000000000000000000000 00200000 &nbsp; &nbsp;=
 &nbsp;2097152 DMC Motor Fan Problem</div><div><br></div><div>Therefore, the=
 data value cannot be used to distinguish debug messages from user messages.=
</div><div><br></div><div>Bummer.</div><div><br></div><div>&nbsp; &nbsp;Tom<=
/div><div><br></div><span id=3D"OLK_SRC_BODY_SECTION"><div style=3D"font-family:=
 Calibri; font-size: 11pt; text-align: left; border-width: 1pt medium medium=
; border-style: solid none none; padding: 3pt 0in 0in; border-top-color: rgb=
(181, 196, 223);"><span style=3D"font-weight:bold">From: </span> Mark Webb-Joh=
nson &lt;<a href=3D"mailto:mark at webb-johnson.net">mark at webb-johnson.net</a>&gt=
;<br><span style=3D"font-weight:bold">Reply-To: </span> OVMS Developers &lt;<a=
 href=3D"mailto:ovmsdev at lists.teslaclub.hk">ovmsdev at lists.teslaclub.hk</a>&gt;=
<br><span style=3D"font-weight:bold">Date: </span> Sunday, November 3, 2013 at=
 5:14 PM<br><span style=3D"font-weight:bold">To: </span> OVMS Developers &lt;<=
a href=3D"mailto:ovmsdev at lists.teslaclub.hk">ovmsdev at lists.teslaclub.hk</a>&gt=
;<br><span style=3D"font-weight:bold">Subject: </span> [Ovmsdev] Debug vs Norm=
al messages in Tesla Roadster<br></div><div><br></div><div><meta http-equiv=3D=
"Content-Type" content=3D"text/html charset=3Dus-ascii"><div style=3D"word-wrap: b=
reak-word; -webkit-nbsp-mode: space; -webkit-line-break: after-white-space;"=
><div><br></div><div>I'm not having much luck trying to differentiate betwee=
n debug and normal alert messages in the Tesla Roadster. So, here is my work=
ing so far, and calling out for ideas.</div><div><br></div><div>First, here =
is what is known about the CAN bus message relating to this:</div><div><br><=
/div><div><blockquote style=3D"margin: 0 0 0 40px; border: none; padding: 0px;=
" type=3D"cite"><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; Erro=
r Notification</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp=
; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; ID=3D0x100</font></div><div><font face=3D"A=
ndale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; B1=3D0x93<=
/font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;=
 &nbsp; &nbsp; &nbsp; B2=3DOn, Off, Severity, etc, indication</font></div><div=
><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &=
nbsp; B3=3DError code LSB</font></div><div><font face=3D"Andale Mono">&nbsp; &nb=
sp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; B4=3DError code MSB (error code =
0xFFFF means no error)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbs=
p; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; B5=3DData LSB</font></div><div><f=
ont face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbs=
p; B6=3DData</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &n=
bsp; &nbsp; &nbsp; &nbsp; &nbsp; B7=3DData</font></div><div><font face=3D"Andale=
 Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; B8=3DData MSB</=
font></div><div><font face=3D"Andale Mono"><br></font></div><div><font face=3D"A=
ndale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; N.B. Reg=
arding B2, we've seen:</font></div><div><font face=3D"Andale Mono">&nbsp; &nbs=
p; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 0x0=
1 =3D 00000001b =3D Show Alert</font></div><div><font face=3D"Andale Mono">&nbsp; =
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;=
 0x00 =3D 00000000b =3D Cancel Alert</font></div><div><font face=3D"Andale Mono">&=
nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; =
&nbsp; 0x05 =3D 00000101b =3D Show Alert</font></div><div><font face=3D"Andale Mon=
o">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nb=
sp; &nbsp; 0x04 =3D 00000100b =3D Cancel Alert</font></div><div><font face=3D"Anda=
le Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbs=
p; &nbsp; &nbsp; 0x15 =3D 00010101b =3D Show Message</font></div><div><font face=
=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp=
; &nbsp; &nbsp; &nbsp; 0x14 =3D 00010100b =3D End Message</font></div><div><font=
 face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; =
&nbsp; &nbsp; &nbsp;Suggestion is that bit0 is set when alert is raised, and=
 zeroed when alert is cleared.</font></div></blockquote></div><div><br></div=
><div>Here is some raw can bus messages showing some alerts coming and going=
:</div><div><br></div><div><blockquote style=3D"margin: 0 0 0 40px; border: no=
ne; padding: 0px;" type=3D"cite"><div><font face=3D"Andale Mono">&nbsp; &nbsp; &=
nbsp; &nbsp; &nbsp;6.6947 100 93 00 FF FF 00 00 00 00 &nbsp; &nbsp;-&gt;VDS =
(message to VDS 93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; =
&nbsp; &nbsp; 13.4250 100 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (mes=
sage to VDS 93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbs=
p; &nbsp; 20.1151 100 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message=
 to VDS 93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &=
nbsp; 26.8368 100 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message to =
VDS 93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp=
; 33.5484 100 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS =
93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 40=
.2862 100 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)<=
/font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 46.976=
6 100 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</fon=
t></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 53.6772 10=
0 93 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></=
div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 60.3577 100 93=
 05 78 03 00 01 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div>=
<div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 63.2089 100 93 04 =
78 03 00 00 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div=
><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 67.0663 100 93 00 FF F=
F 00 00 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div><fo=
nt face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 73.7502 100 93 00 FF FF 00=
 00 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div><font f=
ace=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 80.2421 100 93 05 8D 04 20 00 =
00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div><font face=3D=
"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 80.4511 100 93 05 8D 04 20 00 00 0=
0 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div><font face=3D"And=
ale Mono">&nbsp; &nbsp; &nbsp; &nbsp; 87.1387 100 93 05 8D 04 20 00 00 00 &n=
bsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div><font face=3D"Andale =
Mono">&nbsp; &nbsp; &nbsp; &nbsp; 93.8198 100 93 05 8D 04 20 00 00 00 &nbsp;=
 &nbsp;-&gt;VDS (message to VDS 93)</font></div><div><font face=3D"Andale Mono=
">&nbsp; &nbsp; &nbsp; &nbsp;100.5295 100 93 05 8D 04 20 00 00 00 &nbsp; &nb=
sp;-&gt;VDS (message to VDS 93)</font></div><div><font face=3D"Andale Mono">&n=
bsp; &nbsp; &nbsp; &nbsp;107.2297 100 93 05 8D 04 20 00 00 00 &nbsp; &nbsp;-=
&gt;VDS (message to VDS 93)</font></div><div><font face=3D"Andale Mono">&nbsp;=
 &nbsp; &nbsp; &nbsp;113.9373 100 93 05 8D 04 20 00 00 00 &nbsp; &nbsp;-&gt;=
VDS (message to VDS 93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nb=
sp; &nbsp; &nbsp;120.6307 100 93 05 8D 04 20 00 00 00 &nbsp; &nbsp;-&gt;VDS =
&nbsp; &nbsp;121.7428 100 93 04 8D 04 20 00 00 00 &nbsp; &nbsp;-&gt;VDS (mes=
p; &nbsp;127.3396 100 93 00 FF FF 00 00 00 00 &nbsp; &nbsp;-&gt;VDS (message=
nbsp;128.3633 100 93 05 91 04 00 02 00 00 &nbsp; &nbsp;-&gt;VDS (message to =
;134.0215 100 93 05 91 04 00 02 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS =
93)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;140=
.7018 100 93 05 91 04 00 02 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)<=
/font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;147.401=
8 100 93 05 91 04 00 02 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</fon=
t></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;147.9951 10=
0 93 04 91 04 00 02 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></=
div><div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;154.1413 100 93=
 00 FF FF 00 00 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div>=
<div><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;160.8654 100 93 00 =
FF FF 00 00 00 00 &nbsp; &nbsp;-&gt;VDS (message to VDS 93)</font></div><div=
><font face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;167.5743 100 93 00 FF F=
nt face=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;174.5784 100 93 00 FF FF 00=
ace=3D"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;181.3024 100 93 00 FF FF 00 00 =
"Andale Mono">&nbsp; &nbsp; &nbsp; &nbsp;188.0697 100 93 00 FF FF 00 00 00 0=
ale Mono">&nbsp; &nbsp; &nbsp; &nbsp;194.7832 100 93 00 FF FF 00 00 00 00 &n=
Mono">&nbsp; &nbsp; &nbsp; &nbsp;201.4736 100 93 00 FF FF 00 00 00 00 &nbsp;=
 &nbsp;-&gt;VDS (message to VDS 93)</font></div></blockquote></div><div><br>=
</div><div>The message shown on the car's VDS includes 4 bytes of data, so w=
e are assuming that is B5..B8.</div><div><br></div><div>The most likely seem=
ed to be B2, which we don't normally report back to the server. So, I switch=
ed my car to report that rather that the Data (B5..B8) and here is what I go=
t:</div><div><br></div><div><blockquote style=3D"margin: 0 0 0 40px; border: n=
one; padding: 0px;" type=3D"cite"><div><font face=3D"Andale Mono">rx msg P ETR2N=
,1165,5</font></div><div><font face=3D"Andale Mono">rx msg P ETR2N,888,5</font=
></div><div><font face=3D"Andale Mono">rx msg P ETR2N,1124,5</font></div><div>=
<font face=3D"Andale Mono">rx msg P ETR2N,1166,5</font></div><div><font face=3D"=
Andale Mono">rx msg P ETR2N,1146,5</font></div><div><font face=3D"Andale Mono"=
>rx msg P ETR2N,954,1</font></div><div><font face=3D"Andale Mono">rx msg P ETR=
2N,1146,5</font></div><div><font face=3D"Andale Mono">rx msg P ETR2N,1146,5</f=
ont></div><div><font face=3D"Andale Mono">rx msg P ETR2N,1146,5</font></div><d=
iv><font face=3D"Andale Mono">rx msg P ETR2N,1146,5</font></div></blockquote><=
/div><div><br></div><div>1146 (DMC Motor Fan Problem) is a debug message. 95=
4 (line voltage lost sync), 1166 (release parking brake), 888 (disarm vehicl=
e with keyfob), 1165 (door ajar) and 1124 (unsafe gear shift) are not. The l=
ast number (5 or 1) is the B2 value corresponding to the alert. I have no id=
ea why 954 should be B2=3D1 and the others B2=3D5, but it seems to have no relat=
ion to the debug level of the alert.</div><div><br></div><div>So, how about =
the ID number of the alert itself? Well, here is the list of known alerts, w=
ith the ID number shown in binary, hexadecimal and decimal, followed by the =
message:</div><div><br></div><div><blockquote style=3D"margin: 0 0 0 40px; bor=
der: none; padding: 0px;" type=3D"cite"><div><font face=3D"Andale Mono">00000000=
00011001 0019 &nbsp; &nbsp;25 Memory Stick transfer in progress (%d%%)</font=
></div><div><font face=3D"Andale Mono">0000000000110101 0035 &nbsp; &nbsp;53 G=
PS: No data fault</font></div><div><font face=3D"Andale Mono">0000000100001101=
 010d &nbsp; 269 BSM: Negative contactor/economizer stuck low</font></div><d=
iv><font face=3D"Andale Mono">0000000100011011 011b &nbsp; 283 BSM: Isolation =
fault</font></div><div><font face=3D"Andale Mono">0000000100011110 011e &nbsp;=
 286 BSM: Isolation fault while contactors closed</font></div><div><font fac=
e=3D"Andale Mono">0000000100011111 011f &nbsp; 287 Power train Problem Service=
 Required</font></div><div><font face=3D"Andale Mono">0000000110011001 0199 &n=
bsp; 409 TPMS: Hardware Error</font></div><div><font face=3D"Andale Mono">0000=
000110101100 01ac &nbsp; 428 12V Battery Service Required</font></div><div><=
font face=3D"Andale Mono">0000001001011100 025c &nbsp; 604 Battery Low Power R=
educed</font></div><div><font face=3D"Andale Mono">0000001001011110 025e &nbsp=
; 606 ESS: Range Mode Remaining charge uncertain</font></div><div><font face=
=3D"Andale Mono">0000001001100011 0263 &nbsp; 611 ESS: Almost empty - Car stop=
s in 1 mile</font></div><div><font face=3D"Andale Mono">0000001101110010 0372 =
&nbsp; 882 Before starting, charge port door must be closed</font></div><div=
><font face=3D"Andale Mono">0000001101111000 0378 &nbsp; 888 Disarm vehicle wi=
th key fob before starting</font></div><div><font face=3D"Andale Mono">0000001=
110100110 03a6 &nbsp; 934 DMC FW: Line OverCurrent Peak Fault</font></div><d=
iv><font face=3D"Andale Mono">0000001110101000 03a8 &nbsp; 936 Charging Proble=
m</font></div><div><font face=3D"Andale Mono">0000001110101001 03a9 &nbsp; 937=
 Charge Problem Extension Cord Detected</font></div><div><font face=3D"Andale =
Mono">0000001110110001 03b1 &nbsp; 945 System too hot - Vehicle shutting dow=
n</font></div><div><font face=3D"Andale Mono">0000001110111001 03b9 &nbsp; 953=
 Line Voltage Lost Sync</font></div><div><font face=3D"Andale Mono">0000001110=
111010 03ba &nbsp; 954 Line Voltage Lost Sync</font></div><div><font face=3D"A=
ndale Mono">0000001111001110 03ce &nbsp; 974 DMC FW: Pole Current Error Faul=
t</font></div><div><font face=3D"Andale Mono">0000001111010101 03d5 &nbsp; 981=
 DMC FW: Bad State Transition Fault</font></div><div><font face=3D"Andale Mono=
">0000001111000000 03c0 &nbsp; 960 DMC FW: VBrickMax versus VBattery Error f=
ault</font></div><div><font face=3D"Andale Mono">0000010000110001 0431 &nbsp;1=
073 DMC FW: PhaseA OverTemp warning. Torque limited</font></div><div><font f=
ace=3D"Andale Mono">0000010000110010 0432 &nbsp;1074 DMC FW: PhaseA Temp Diff =
warning</font></div><div><font face=3D"Andale Mono">0000010000110110 0436 &nbs=
p;1078 DMC FW: PhaseC Temp Diff warning</font></div><div><font face=3D"Andale =
Mono">0000010000111100 043c &nbsp;1084 External Charger Problem</font></div>=
<div><font face=3D"Andale Mono">0000010001000100 0444 &nbsp;1092 Do not plug i=
n charge cable while driving</font></div><div><font face=3D"Andale Mono">00000=
10001001111 044f &nbsp;1103 ABS &amp; Traction Control Problems. Service Req=
uired.</font></div><div><font face=3D"Andale Mono">0000010001100100 0464 &nbsp=
;1124 Unsafe Gear Shift Transition Denied</font></div><div><font face=3D"Andal=
e Mono">0000010001111000 0478 &nbsp;1144 Powertrain Problem Service Required=
</font></div><div><font face=3D"Andale Mono">0000010001111010 047a &nbsp;1146 =
DMC Motor Fan Problem</font></div><div><font face=3D"Andale Mono">000001001000=
0000 0480 &nbsp;1152 DMC WARNING Charge Thermal Limit</font></div><div><font=
 face=3D"Andale Mono">0000010010001101 048d &nbsp;1165 Key in Key Switch Door =
Ajar</font></div><div><font face=3D"Andale Mono">0000010010001110 048e &nbsp;1=
166 Release Parking Brake</font></div><div><font face=3D"Andale Mono">00000100=
10010001 0491 &nbsp;1169 Charge port open</font></div><div><font face=3D"Andal=
e Mono">0000010010010010 0492 &nbsp;1170 Tow Mode is not available while car=
 is on</font></div><div><font face=3D"Andale Mono">0000010010010110 0496 &nbsp=
;1174 Fasten Seatbelt</font></div><div><font face=3D"Andale Mono">000001011000=
1000 0588 &nbsp;1416 Low Power System Service Required</font></div><div><fon=
t face=3D"Andale Mono">0000010110110111 05b7 &nbsp;1463 HVAC: Compressor OverT=
emp</font></div><div><font face=3D"Andale Mono">0000010110111001 05b9 &nbsp;14=
65 HVAC: Low current pump fault</font></div><div><font face=3D"Andale Mono">00=
00010110111101 05bd &nbsp;1469 HVAC: Compressor comms timeout</font></div><d=
iv><font face=3D"Andale Mono">0000010110111111 05bf &nbsp;1471 HVAC: Compresso=
r DTC comms timeout</font></div><div><font face=3D"Andale Mono">00001000000111=
10 081e &nbsp;2078 There was a problem processing your request</font></div><=
/blockquote></div><div><br></div><div>The "DMC" prefix is supposed to indica=
te a debug message. I don't see any pattern. It has also been reported that =
one single ID can have both debug and non-debug variants to the message - se=
e:&nbsp;<a href=3D"http://www.teslamotorsclub.com/showwiki.php?title=3DRoadster"=
>http://www.teslamotorsclub.com/showwiki.php?title=3DRoadster</a></div><div><b=
r></div><div>So, here is all the error codes and data that we've seen for th=
e past few months (error code, followed by data bytes in binary, hex and dec=
imal):</div><div><br></div><div><blockquote style=3D"margin: 0 0 0 40px; borde=
r: none; padding: 0px;" type=3D"cite"><div><font face=3D"Andale Mono">&nbsp; &nb=
sp; 0 00000000000000000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; =
&nbsp; &nbsp;0</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; 3 000=
00000000000000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &n=
bsp;0</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; 3 000000000000=
00000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4</fo=
nt></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; 3 000000000000000000000=
00000100000 00000020 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32</font></div><div>=
<font face=3D"Andale Mono">&nbsp; &nbsp; 3 00000000001000000000000000000000 00=
200000 &nbsp; &nbsp; &nbsp;2097152</font></div><div><font face=3D"Andale Mono"=
>&nbsp; &nbsp; 3 10000001001000100011100010110100 812238b4 &nbsp; 2166503604=
</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp; 3 10000001001010111=
011100010110100 812bb8b4 &nbsp; 2167126196</font></div><div><font face=3D"Anda=
le Mono">&nbsp; &nbsp; 3 10000001001011001011100010110100 812cb8b4 &nbsp; 21=
67191732</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;10 000000000=
00000000000000000010000 00000010 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 16</font=
></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;10 00000000000000000000000=
000100000 00000020 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32</font></div><div><f=
ont face=3D"Andale Mono">&nbsp; &nbsp;10 00000000000000000000100000000000 0000=
0800 &nbsp; &nbsp; &nbsp; &nbsp; 2048</font></div><div><font face=3D"Andale Mo=
no">&nbsp; &nbsp;10 01000000000000000000000000000100 40000004 &nbsp; 1073741=
828</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;19 00000000000000=
000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0</font=
></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;25 00000000000000000000000=
000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0 Memory Stick t=
ransfer in progress (%d%%)</font></div><div><font face=3D"Andale Mono">&nbsp; =
&nbsp;25 00000000000000000000000000000001 00000001 &nbsp; &nbsp; &nbsp; &nbs=
p; &nbsp; &nbsp;1 Memory Stick transfer in progress (%d%%)</font></div><div>=
<font face=3D"Andale Mono">&nbsp; &nbsp;25 00000000000000000000000000000010 00=
000002 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;2 Memory Stick transfer in p=
rogress (%d%%)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;25 000=
00000000000000000000000000011 00000003 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &n=
bsp;3 Memory Stick transfer in progress (%d%%)</font></div><div><font face=3D"=
Andale Mono">&nbsp; &nbsp;25 00000000000000000000000000101111 0000002f &nbsp=
; &nbsp; &nbsp; &nbsp; &nbsp; 47 Memory Stick transfer in progress (%d%%)</f=
ont></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;25 00000000000000000000=
000000110000 00000030 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 48 Memory Stick tra=
nsfer in progress (%d%%)</font></div><div><font face=3D"Andale Mono">&nbsp; &n=
bsp;25 00000000000000000000000001000000 00000040 &nbsp; &nbsp; &nbsp; &nbsp;=
 &nbsp; 64 Memory Stick transfer in progress (%d%%)</font></div><div><font f=
ace=3D"Andale Mono">&nbsp; &nbsp;25 00000000000000000000000001000001 00000041 =
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 65 Memory Stick transfer in progress (%d%=
%)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;25 000000000000000=
00000000001000010 00000042 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 66 Memory Stic=
k transfer in progress (%d%%)</font></div><div><font face=3D"Andale Mono">&nbs=
p; &nbsp;25 00000000000000000000000001100001 00000061 &nbsp; &nbsp; &nbsp; &=
nbsp; &nbsp; 97 Memory Stick transfer in progress (%d%%)</font></div><div><f=
ont face=3D"Andale Mono">&nbsp; &nbsp;25 00000000000000000000000001100011 0000=
0063 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 99 Memory Stick transfer in progress=
 (%d%%)</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;25 0000000000=
0000000000000001100100 00000064 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;100 Memory=
 Stick transfer in progress (%d%%)</font></div><div><font face=3D"Andale Mono"=
>&nbsp; &nbsp;29 00000000000000000000000000000000 00000000 &nbsp; &nbsp; &nb=
sp; &nbsp; &nbsp; &nbsp;0</font></div><div><font face=3D"Andale Mono">&nbsp; &=
nbsp;32 00000000000000000000000000000010 00000002 &nbsp; &nbsp; &nbsp; &nbsp=
; &nbsp; &nbsp;2</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;50 0=
0000000000000000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; =
&nbsp;0</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;52 0000000000=
0000000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4</=
font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;53 0000000000000000000=
0000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0</font></di=
v><div><font face=3D"Andale Mono">&nbsp; &nbsp;53 0000000000000000000000000000=
1000 00000008 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;8</font></div><div><f=
ont face=3D"Andale Mono">&nbsp; &nbsp;55 00000000000000000000000000100000 0000=
0020 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32</font></div><div><font face=3D"Anda=
le Mono">&nbsp; &nbsp;57 00000000000000000000000000000000 00000000 &nbsp; &n=
bsp; &nbsp; &nbsp; &nbsp; &nbsp;0</font></div><div><font face=3D"Andale Mono">=
&nbsp; &nbsp;57 00000000000000000000000010000000 00000080 &nbsp; &nbsp; &nbs=
p; &nbsp; &nbsp;128</font></div><div><font face=3D"Andale Mono">&nbsp; &nbsp;6=
3 00000000000000000010000000000000 00002000 &nbsp; &nbsp; &nbsp; &nbsp; 8192=
</font></div><div><font face=3D"Andale Mono">&nbsp; 104 0000000000000000010000=
0000000000 00004000 &nbsp; &nbsp; &nbsp; &nbsp;16384</font></div><div><font =
face=3D"Andale Mono">&nbsp; 257 00000000000000000000000000000001 00000001 &nbs=
p; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;1</font></div><div><font face=3D"Andale M=
ono">&nbsp; 263 00000000000000000000000001000000 00000040 &nbsp; &nbsp; &nbs=
p; &nbsp; &nbsp; 64</font></div><div><font face=3D"Andale Mono">&nbsp; 264 000=
00000000000000000000010000000 00000080 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;128=
</font></div><div><font face=3D"Andale Mono">&nbsp; 269 0000000000000000000101=
0000000000 00001400 &nbsp; &nbsp; &nbsp; &nbsp; 5120 BSM: Negative contactor=
/economizer stuck low</font></div><div><font face=3D"Andale Mono">&nbsp; 270 0=
0000000000000000010100000000000 00002800 &nbsp; &nbsp; &nbsp; &nbsp;10240</f=
ont></div><div><font face=3D"Andale Mono">&nbsp; 271 0000000000000000010000000=
0000000 00004000 &nbsp; &nbsp; &nbsp; &nbsp;16384</font></div><div><font fac=
e=3D"Andale Mono">&nbsp; 276 00000000000010000000000000000000 00080000 &nbsp; =
&nbsp; &nbsp; 524288</font></div><div><font face=3D"Andale Mono">&nbsp; 283 00=
100100000000000000000000000000 24000000 &nbsp; &nbsp;603979776</font></div><=
div><font face=3D"Andale Mono">&nbsp; 283 01000100000000000000000000000000 440=
00000 &nbsp; 1140850688</font></div><div><font face=3D"Andale Mono">&nbsp; 286=
 00100100000000000000000000000000 24000000 &nbsp; &nbsp;603979776</font></di=
v><div><font face=3D"Andale Mono">&nbsp; 287 01000100000000000000000000000000 =
44000000 &nbsp; 1140850688 Power train Problem Service Required</font></div>=
<div><font face=3D"Andale Mono">&nbsp; 399 00010000000000000000000000000000 10=
000000 &nbsp; &nbsp;268435456</font></div><div><font face=3D"Andale Mono">&nbs=
p; 399 10000001001000100011100010110100 812238b4 &nbsp; 2166503604</font></d=
iv><div><font face=3D"Andale Mono">&nbsp; 399 10000001001000111011100010110100=
 8123b8b4 &nbsp; 2166601908</font></div><div><font face=3D"Andale Mono">&nbsp;=
 399 10000001001010111011100010110100 812bb8b4 &nbsp; 2167126196</font></div=
><div><font face=3D"Andale Mono">&nbsp; 399 10000010111110011011100010110100 8=
2f9b8b4 &nbsp; 2197403828</font></div><div><font face=3D"Andale Mono">&nbsp; 4=
00 00000000000000000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nb=
sp; &nbsp;4</font></div><div><font face=3D"Andale Mono">&nbsp; 400 00000000000=
000000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;256</font><=
/div><div><font face=3D"Andale Mono">&nbsp; 400 000100000000000000000000000000=
00 10000000 &nbsp; &nbsp;268435456</font></div><div><font face=3D"Andale Mono"=
>&nbsp; 400 10000001001000100011100010110100 812238b4 &nbsp; 2166503604</fon=
t></div><div><font face=3D"Andale Mono">&nbsp; 400 100000010010001100111000101=
10100 812338b4 &nbsp; 2166569140</font></div><div><font face=3D"Andale Mono">&=
nbsp; 400 10000001001000111011100010110100 8123b8b4 &nbsp; 2166601908</font>=
</div><div><font face=3D"Andale Mono">&nbsp; 400 10000001001010111011100010110=
100 812bb8b4 &nbsp; 2167126196</font></div><div><font face=3D"Andale Mono">&nb=
sp; 400 10000010111110011011100010110100 82f9b8b4 &nbsp; 2197403828</font></=
div><div><font face=3D"Andale Mono">&nbsp; 401 0000000000000000000000000000000=
1 00000001 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;1</font></div><div><font=
 face=3D"Andale Mono">&nbsp; 403 00000000000000000000000000000100 00000004 &nb=
sp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4</font></div><div><font face=3D"Andale =
Mono">&nbsp; 405 00000000000000000000000000010000 00000010 &nbsp; &nbsp; &nb=
sp; &nbsp; &nbsp; 16</font></div><div><font face=3D"Andale Mono">&nbsp; 407 00=
000000000000000000000001000000 00000040 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 6=
4</font></div><div><font face=3D"Andale Mono">&nbsp; 409 000000000000000000000=
00100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;256 TPMS: Hardware Er=
ror</font></div><div><font face=3D"Andale Mono">&nbsp; 415 0000000000000000010=
0000000000000 00004000 &nbsp; &nbsp; &nbsp; &nbsp;16384</font></div><div><fo=
nt face=3D"Andale Mono">&nbsp; 416 00000000000000001100000000000000 0000c000 &=
nbsp; &nbsp; &nbsp; &nbsp;49152</font></div><div><font face=3D"Andale Mono">&n=
bsp; 420 00000000000000000000000000000001 00000001 &nbsp; &nbsp; &nbsp; &nbs=
p; &nbsp; &nbsp;1</font></div><div><font face=3D"Andale Mono">&nbsp; 428 00000=
000000000000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbs=
p;0 12V Battery Service Required</font></div><div><font face=3D"Andale Mono">&=
nbsp; 428 00000000000000000000000000000001 00000001 &nbsp; &nbsp; &nbsp; &nb=
sp; &nbsp; &nbsp;1 12V Battery Service Required</font></div><div><font face=3D=
"Andale Mono">&nbsp; 428 00000000000000000000000000000100 00000004 &nbsp; &n=
bsp; &nbsp; &nbsp; &nbsp; &nbsp;4 12V Battery Service Required</font></div><=
div><font face=3D"Andale Mono">&nbsp; 428 00000000000000000000000000010000 000=
00010 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 16 12V Battery Service Required</fo=
nt></div><div><font face=3D"Andale Mono">&nbsp; 428 00000000000000000000000000=
100000 00000020 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32 12V Battery Service Re=
quired</font></div><div><font face=3D"Andale Mono">&nbsp; 428 0000000000000000=
0000000001000000 00000040 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 64 12V Battery =
Service Required</font></div><div><font face=3D"Andale Mono">&nbsp; 428 000000=
00000000000000000010000000 00000080 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;128 12=
V Battery Service Required</font></div><div><font face=3D"Andale Mono">&nbsp; =
428 00000000000000000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &n=
bsp;256 12V Battery Service Required</font></div><div><font face=3D"Andale Mon=
o">&nbsp; 428 10000001001000011011100010110100 8121b8b4 &nbsp; 2166470836 12=
428 10000001001000011011110110011100 8121bd9c &nbsp; 2166472092 12V Battery =
Service Required</font></div><div><font face=3D"Andale Mono">&nbsp; 428 100000=
01001000100011100010110000 812238b0 &nbsp; 2166503600 12V Battery Service Re=
quired</font></div><div><font face=3D"Andale Mono">&nbsp; 428 1000000100100010=
0011100010110100 812238b4 &nbsp; 2166503604 12V Battery Service Required</fo=
nt></div><div><font face=3D"Andale Mono">&nbsp; 428 10000001001000100011110110=
011100 81223d9c &nbsp; 2166504860 12V Battery Service Required</font></div><=
div><font face=3D"Andale Mono">&nbsp; 428 10000001001001000011100010110100 812=
438b4 &nbsp; 2166634676 12V Battery Service Required</font></div><div><font =
face=3D"Andale Mono">&nbsp; 428 10000001001001000011110110011100 81243d9c &nbs=
p; 2166635932 12V Battery Service Required</font></div><div><font face=3D"Anda=
le Mono">&nbsp; 428 10000001001010111011100010110100 812bb8b4 &nbsp; 2167126=
196 12V Battery Service Required</font></div><div><font face=3D"Andale Mono">&=
nbsp; 428 10000001001010111011110110011100 812bbd9c &nbsp; 2167127452 12V Ba=
ttery Service Required</font></div><div><font face=3D"Andale Mono">&nbsp; 529 =
00000000000000000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;=
 &nbsp;0</font></div><div><font face=3D"Andale Mono">&nbsp; 529 00000000000000=
000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4</font=
></div><div><font face=3D"Andale Mono">&nbsp; 529 0000000000000000000000000000=
ont face=3D"Andale Mono">&nbsp; 529 00000000000000000000000000001100 0000000c =
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 12</font></div><div><font face=3D"Andale Mo=
no">&nbsp; 529 00000000000000000000000000100000 00000020 &nbsp; &nbsp; &nbsp=
; &nbsp; &nbsp; 32</font></div><div><font face=3D"Andale Mono">&nbsp; 529 0000=
0000000000000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;256<=
/font></div><div><font face=3D"Andale Mono">&nbsp; 529 00000000000000000000000=
100000100 00000104 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;260</font></div><div><f=
ont face=3D"Andale Mono">&nbsp; 529 00000100000000000000000000000000 04000000 =
&nbsp; &nbsp; 67108864</font></div><div><font face=3D"Andale Mono">&nbsp; 529 =
00010000000000000000000000000000 10000000 &nbsp; &nbsp;268435456</font></div=
><div><font face=3D"Andale Mono">&nbsp; 529 00100100000000000000000000000000 2=
4000000 &nbsp; &nbsp;603979776</font></div><div><font face=3D"Andale Mono">&nb=
sp; 529 01000000000000000000000000000100 40000004 &nbsp; 1073741828</font></=
div><div><font face=3D"Andale Mono">&nbsp; 529 0100000000000000000000000000110=
0 4000000c &nbsp; 1073741836</font></div><div><font face=3D"Andale Mono">&nbsp=
; 529 10000001001000100011100010110100 812238b4 &nbsp; 2166503604</font></di=
v><div><font face=3D"Andale Mono">&nbsp; 529 10000001001001001011100010110100 =
8124b8b4 &nbsp; 2166667444</font></div><div><font face=3D"Andale Mono">&nbsp; =
530 10000001001010111011100010110100 812bb8b4 &nbsp; 2167126196</font></div>=
<div><font face=3D"Andale Mono">&nbsp; 537 00000000000000000010000000000000 00=
002000 &nbsp; &nbsp; &nbsp; &nbsp; 8192</font></div><div><font face=3D"Andale =
Mono">&nbsp; 537 00010000000000000000000000000000 10000000 &nbsp; &nbsp;2684=
35456</font></div><div><font face=3D"Andale Mono">&nbsp; 537 10000001001000100=
011100010110100 812238b4 &nbsp; 2166503604</font></div><div><font face=3D"Anda=
le Mono">&nbsp; 537 10000001001000111011100010110100 8123b8b4 &nbsp; 2166601=
908</font></div><div><font face=3D"Andale Mono">&nbsp; 538 1000000100100010001=
1100010110100 812238b4 &nbsp; 2166503604</font></div><div><font face=3D"Andale=
 Mono">&nbsp; 538 10000001001000100011110110011100 81223d9c &nbsp; 216650486=
0</font></div><div><font face=3D"Andale Mono">&nbsp; 539 000100000000000000000=
00000000000 10000000 &nbsp; &nbsp;268435456</font></div><div><font face=3D"And=
ale Mono">&nbsp; 539 10000001001011000011100010110100 812c38b4 &nbsp; 216715=
8964</font></div><div><font face=3D"Andale Mono">&nbsp; 539 100000010010110000=
11110110011100 812c3d9c &nbsp; 2167160220</font></div><div><font face=3D"Andal=
e Mono">&nbsp; 601 00000000000000000000000000000010 00000002 &nbsp; &nbsp; &=
nbsp; &nbsp; &nbsp; &nbsp;2</font></div><div><font face=3D"Andale Mono">&nbsp;=
 604 00000000000000000000000000010000 00000010 &nbsp; &nbsp; &nbsp; &nbsp; &=
nbsp; 16 Battery Low Power Reduced</font></div><div><font face=3D"Andale Mono"=
>&nbsp; 604 00000000000000000000000000010010 00000012 &nbsp; &nbsp; &nbsp; &=
nbsp; &nbsp; 18 Battery Low Power Reduced</font></div><div><font face=3D"Andal=
e Mono">&nbsp; 606 00000000000000000000000001000000 00000040 &nbsp; &nbsp; &=
nbsp; &nbsp; &nbsp; 64</font></div><div><font face=3D"Andale Mono">&nbsp; 608 =
00000000000000000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;=
256</font></div><div><font face=3D"Andale Mono">&nbsp; 609 0000000000000000000=
0001000000000 00000200 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;512</font></div><di=
v><font face=3D"Andale Mono">&nbsp; 610 00000000000000000000010000000000 00000=
400 &nbsp; &nbsp; &nbsp; &nbsp; 1024</font></div><div><font face=3D"Andale Mon=
o">&nbsp; 611 00000000000000000000100000000000 00000800 &nbsp; &nbsp; &nbsp;=
 &nbsp; 2048</font></div><div><font face=3D"Andale Mono">&nbsp; 881 0000000000=
0000000000000000000010 00000002 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;2</=
font></div><div><font face=3D"Andale Mono">&nbsp; 882 000000000000000000000000=
00000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4 Before starting=
, charge port door must be closed</font></div><div><font face=3D"Andale Mono">=
&nbsp; 883 00000000000000000000000000001000 00000008 &nbsp; &nbsp; &nbsp; &n=
bsp; &nbsp; &nbsp;8</font></div><div><font face=3D"Andale Mono">&nbsp; 887 000=
</font></div><div><font face=3D"Andale Mono">&nbsp; 888 0000000000000000000000=
0100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;256 Disarm vehicle wit=
h key fob before starting</font></div><div><font face=3D"Andale Mono">&nbsp; 8=
88 00000000000000000000000100000100 00000104 &nbsp; &nbsp; &nbsp; &nbsp; &nb=
sp;260 Disarm vehicle with key fob before starting</font></div><div><font fa=
ce=3D"Andale Mono">&nbsp; 920 00000000000010000000000000000000 00080000 &nbsp;=
 &nbsp; &nbsp; 524288</font></div><div><font face=3D"Andale Mono">&nbsp; 925 0=
0000000000000000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;2=
56</font></div><div><font face=3D"Andale Mono">&nbsp; 925 00000001000000000000=
000000000000 01000000 &nbsp; &nbsp; 16777216</font></div><div><font face=3D"An=
dale Mono">&nbsp; 934 00000000000000000000000000000010 00000002 &nbsp; &nbsp=
; &nbsp; &nbsp; &nbsp; &nbsp;2</font></div><div><font face=3D"Andale Mono">&nb=
sp; 935 00000000000000000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp=
; &nbsp; &nbsp;4</font></div><div><font face=3D"Andale Mono">&nbsp; 936 000000=
00000000000000000000001000 00000008 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp=
;8 Charging Problem</font></div><div><font face=3D"Andale Mono">&nbsp; 936 000=
00000000000000000000000001010 0000000a &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 10=
 Charging Problem</font></div><div><font face=3D"Andale Mono">&nbsp; 937 00000=
000000000000000000000010000 00000010 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 16 C=
harge Problem Extension Cord Detected</font></div><div><font face=3D"Andale Mo=
no">&nbsp; 945 00000000000000000001000000000000 00001000 &nbsp; &nbsp; &nbsp=
; &nbsp; 4096</font></div><div><font face=3D"Andale Mono">&nbsp; 953 000000000=
00000000000000000000000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0 =
Line Voltage Lost Sync</font></div><div><font face=3D"Andale Mono">&nbsp; 953 =
00000000000100000000000000000000 00100000 &nbsp; &nbsp; &nbsp;1048576 Line V=
oltage Lost Sync</font></div><div><font face=3D"Andale Mono">&nbsp; 954 000000=
00001000000000000000000000 00200000 &nbsp; &nbsp; &nbsp;2097152 Line Voltage=
 Lost Sync</font></div><div><font face=3D"Andale Mono">&nbsp; 955 000000000100=
00000000000000000000 00400000 &nbsp; &nbsp; &nbsp;4194304</font></div><div><=
font face=3D"Andale Mono">&nbsp; 974 00000000000000000000001000000000 00000200=
 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;512 DMC FW: Pole Current Error Fault</fon=
t></div><div><font face=3D"Andale Mono">&nbsp; 977 000000000000000000010000000=
00000 00001000 &nbsp; &nbsp; &nbsp; &nbsp; 4096</font></div><div><font face=3D=
"Andale Mono">&nbsp; 981 00000000000000010000000000000000 00010000 &nbsp; &n=
bsp; &nbsp; &nbsp;65536 DMC FW: Bad State Transition Fault</font></div><div>=
<font face=3D"Andale Mono">&nbsp;1022 00000010000000000000000000000000 0200000=
0 &nbsp; &nbsp; 33554432</font></div><div><font face=3D"Andale Mono">&nbsp;102=
3 00000100000000000000000000000000 04000000 &nbsp; &nbsp; 67108864</font></d=
iv><div><font face=3D"Andale Mono">&nbsp;1023 00000110000000000000000000000000=
 06000000 &nbsp; &nbsp;100663296</font></div><div><font face=3D"Andale Mono">&=
nbsp;1063 00000000000000000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nb=
sp; &nbsp; &nbsp;4</font></div><div><font face=3D"Andale Mono">&nbsp;1065 0000=
0000000000000000000000010000 00000010 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 16<=
/font></div><div><font face=3D"Andale Mono">&nbsp;1067 00000000000000000000000=
001000000 00000040 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 64</font></div><div><f=
ont face=3D"Andale Mono">&nbsp;1069 00000000000000000000000100000000 00000100 =
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;256</font></div><div><font face=3D"Andale Mo=
no">&nbsp;1070 00000000000000000000001000000000 00000200 &nbsp; &nbsp; &nbsp=
; &nbsp; &nbsp;512</font></div><div><font face=3D"Andale Mono">&nbsp;1070 0000=
0000000000000000001100000000 00000300 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;768<=
/font></div><div><font face=3D"Andale Mono">&nbsp;1073 00000000000000000001000=
000000000 00001000 &nbsp; &nbsp; &nbsp; &nbsp; 4096 DMC FW: PhaseA OverTemp =
warning. Torque limited</font></div><div><font face=3D"Andale Mono">&nbsp;1074=
 00000000000000000010000000000000 00002000 &nbsp; &nbsp; &nbsp; &nbsp; 8192 =
DMC FW: PhaseA Temp Diff warning</font></div><div><font face=3D"Andale Mono">&=
nbsp;1076 00000000000000001000000000000000 00008000 &nbsp; &nbsp; &nbsp; &nb=
sp;32768</font></div><div><font face=3D"Andale Mono">&nbsp;1077 00000000000000=
010000000000000000 00010000 &nbsp; &nbsp; &nbsp; &nbsp;65536</font></div><di=
v><font face=3D"Andale Mono">&nbsp;1077 00000000000000011000000000000000 00018=
000 &nbsp; &nbsp; &nbsp; &nbsp;98304</font></div><div><font face=3D"Andale Mon=
o">&nbsp;1081 00000000000100000000000000000000 00100000 &nbsp; &nbsp; &nbsp;=
1048576</font></div><div><font face=3D"Andale Mono">&nbsp;1082 000000000010000=
00000000000000000 00200000 &nbsp; &nbsp; &nbsp;2097152</font></div><div><fon=
t face=3D"Andale Mono">&nbsp;1084 00000000100000000000000000000000 00800000 &n=
bsp; &nbsp; &nbsp;8388608 External Charger Problem</font></div><div><font fa=
ce=3D"Andale Mono">&nbsp;1084 00000000100000000000000000010000 00800010 &nbsp;=
 &nbsp; &nbsp;8388624 External Charger Problem</font></div><div><font face=3D"=
Andale Mono">&nbsp;1085 00000001000000000000000001000000 01000040 &nbsp; &nb=
sp; 16777280</font></div><div><font face=3D"Andale Mono">&nbsp;1086 0000001000=
0000000000000000000000 02000000 &nbsp; &nbsp; 33554432</font></div><div><fon=
t face=3D"Andale Mono">&nbsp;1087 00000100000000000000000000000000 04000000 &n=
bsp; &nbsp; 67108864</font></div><div><font face=3D"Andale Mono">&nbsp;1092 10=
000000000000000000000000000000 80000000 &nbsp; 2147483648 Do not plug in cha=
rge cable while driving</font></div><div><font face=3D"Andale Mono">&nbsp;1094=
 00000000000000000000000000000010 00000002 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp=
; &nbsp;2</font></div><div><font face=3D"Andale Mono">&nbsp;1095 0000000000000=
0000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4</fon=
t></div><div><font face=3D"Andale Mono">&nbsp;1096 000000000000000000000000000=
00000 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0</font></div><div><=
font face=3D"Andale Mono">&nbsp;1096 00000000000000000000000000001000 00000008=
 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;8</font></div><div><font face=3D"And=
ale Mono">&nbsp;1103 00000000000000000000010000000000 00000400 &nbsp; &nbsp;=
 &nbsp; &nbsp; 1024 ABS &amp; Traction Control Problems. Service Required.</=
font></div><div><font face=3D"Andale Mono">&nbsp;1124 100000000000000000000000=
00000000 80000000 &nbsp; 2147483648 Unsafe Gear Shift Transition Denied</fon=
t></div><div><font face=3D"Andale Mono">&nbsp;1131 000000000000000000000000010=
00000 00000040 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 64</font></div><div><font =
face=3D"Andale Mono">&nbsp;1133 00000000000000000000000100000000 00000100 &nbs=
p; &nbsp; &nbsp; &nbsp; &nbsp;256</font></div><div><font face=3D"Andale Mono">=
&nbsp;1144 00000000000010000000000000000000 00080000 &nbsp; &nbsp; &nbsp; 52=
4288 Powertrain Problem Service Required</font></div><div><font face=3D"Andale=
 Mono">&nbsp;1146 00000000001000000000000000000000 00200000 &nbsp; &nbsp; &n=
bsp;2097152 DMC Motor Fan Problem</font></div><div><font face=3D"Andale Mono">=
&nbsp;1146 00001000001000000000000000000000 08200000 &nbsp; &nbsp;136314880 =
DMC Motor Fan Problem</font></div><div><font face=3D"Andale Mono">&nbsp;1152 0=
0001000000000000000000000000000 08000000 &nbsp; &nbsp;134217728 DMC WARNING =
Charge Thermal Limit</font></div><div><font face=3D"Andale Mono">&nbsp;1152 00=
001000000010000000000000000000 08080000 &nbsp; &nbsp;134742016 DMC WARNING C=
harge Thermal Limit</font></div><div><font face=3D"Andale Mono">&nbsp;1152 000=
01000001000000000000000000000 08200000 &nbsp; &nbsp;136314880 DMC WARNING Ch=
arge Thermal Limit</font></div><div><font face=3D"Andale Mono">&nbsp;1153 0001=
0000000000000000000000000000 10000000 &nbsp; &nbsp;268435456</font></div><di=
v><font face=3D"Andale Mono">&nbsp;1160 00000000000000000000000000000001 00000=
001 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;1</font></div><div><font face=3D"=
Andale Mono">&nbsp;1161 00000000000000000000000000000010 00000002 &nbsp; &nb=
sp; &nbsp; &nbsp; &nbsp; &nbsp;2</font></div><div><font face=3D"Andale Mono">&=
nbsp;1161 00000000000000000000000000000011 00000003 &nbsp; &nbsp; &nbsp; &nb=
sp; &nbsp; &nbsp;3</font></div><div><font face=3D"Andale Mono">&nbsp;1162 0000=
0000000000000000000000000100 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nb=
sp;4</font></div><div><font face=3D"Andale Mono">&nbsp;1162 000000000000000000=
00000000000101 00000005 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;5</font></d=
iv><div><font face=3D"Andale Mono">&nbsp;1162 00000000000000000000000000000110=
 00000006 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;6</font></div><div><font =
face=3D"Andale Mono">&nbsp;1162 00000000000000000000000000001100 0000000c &nbs=
p; &nbsp; &nbsp; &nbsp; &nbsp; 12</font></div><div><font face=3D"Andale Mono">=
&nbsp;1163 00000000000000000000000000001000 00000008 &nbsp; &nbsp; &nbsp; &n=
bsp; &nbsp; &nbsp;8</font></div><div><font face=3D"Andale Mono">&nbsp;1163 000=
00000000000000000000000001100 0000000c &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 12=
</font></div><div><font face=3D"Andale Mono">&nbsp;1164 0000000000000000000000=
0000010000 00000010 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 16</font></div><div><=
font face=3D"Andale Mono">&nbsp;1165 00000000000000000000000000000000 00000000=
 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0 Key in Key Switch Door Ajar</fon=
t></div><div><font face=3D"Andale Mono">&nbsp;1165 000000000000000000000000001=
00000 00000020 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32 Key in Key Switch Door =
Ajar</font></div><div><font face=3D"Andale Mono">&nbsp;1165 000000000000000000=
00000000100001 00000021 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 33 Key in Key Swi=
tch Door Ajar</font></div><div><font face=3D"Andale Mono">&nbsp;1165 000000000=
00000000000000000100011 00000023 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 35 Key i=
n Key Switch Door Ajar</font></div><div><font face=3D"Andale Mono">&nbsp;1165 =
00000000000000000000000000101000 00000028 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;=
 40 Key in Key Switch Door Ajar</font></div><div><font face=3D"Andale Mono">&n=
bsp;1165 00000000000000000000000000101001 00000029 &nbsp; &nbsp; &nbsp; &nbs=
p; &nbsp; 41 Key in Key Switch Door Ajar</font></div><div><font face=3D"Andale=
 Mono">&nbsp;1166 00000000000000000000000000000000 00000000 &nbsp; &nbsp; &n=
bsp; &nbsp; &nbsp; &nbsp;0 Release Parking Brake</font></div><div><font face=
=3D"Andale Mono">&nbsp;1166 00000000000000000000000001000000 00000040 &nbsp; &=
nbsp; &nbsp; &nbsp; &nbsp; 64 Release Parking Brake</font></div><div><font f=
ace=3D"Andale Mono">&nbsp;1166 00000000000000000000000001000100 00000044 &nbsp=
; &nbsp; &nbsp; &nbsp; &nbsp; 68 Release Parking Brake</font></div><div><fon=
t face=3D"Andale Mono">&nbsp;1167 00000000000000000000000010000000 00000080 &n=
bsp; &nbsp; &nbsp; &nbsp; &nbsp;128</font></div><div><font face=3D"Andale Mono=
">&nbsp;1169 00000000000000000000001000000000 00000200 &nbsp; &nbsp; &nbsp; =
&nbsp; &nbsp;512 Charge port open</font></div><div><font face=3D"Andale Mono">=
&nbsp;1169 00000000000000000000001000100000 00000220 &nbsp; &nbsp; &nbsp; &n=
bsp; &nbsp;544 Charge port open</font></div><div><font face=3D"Andale Mono">&n=
bsp;1170 00000000000000000000010000000000 00000400 &nbsp; &nbsp; &nbsp; &nbs=
p; 1024 Tow Mode is not available while car is on</font></div><div><font fac=
e=3D"Andale Mono">&nbsp;1171 00000000000000000000100000000000 00000800 &nbsp; =
&nbsp; &nbsp; &nbsp; 2048</font></div><div><font face=3D"Andale Mono">&nbsp;11=
73 00000000000000000010000000000000 00002000 &nbsp; &nbsp; &nbsp; &nbsp; 819=
2</font></div><div><font face=3D"Andale Mono">&nbsp;1173 000000000000000000100=
00000000001 00002001 &nbsp; &nbsp; &nbsp; &nbsp; 8193</font></div><div><font=
 face=3D"Andale Mono">&nbsp;1173 00000000000000000010000000100000 00002020 &nb=
sp; &nbsp; &nbsp; &nbsp; 8224</font></div><div><font face=3D"Andale Mono">&nbs=
p;1174 00000000000000000100000000000000 00004000 &nbsp; &nbsp; &nbsp; &nbsp;=
16384</font></div><div><font face=3D"Andale Mono">&nbsp;1174 00000000000000000=
100000000000010 00004002 &nbsp; &nbsp; &nbsp; &nbsp;16386</font></div><div><=
font face=3D"Andale Mono">&nbsp;1174 00000000000000000100000000000100 00004004=
 &nbsp; &nbsp; &nbsp; &nbsp;16388</font></div><div><font face=3D"Andale Mono">=
&nbsp;1174 00000000000000000100000000000110 00004006 &nbsp; &nbsp; &nbsp; &n=
bsp;16390</font></div><div><font face=3D"Andale Mono">&nbsp;1174 0000000000000=
0000100000000001100 0000400c &nbsp; &nbsp; &nbsp; &nbsp;16396</font></div><d=
iv><font face=3D"Andale Mono">&nbsp;1174 00000000000000000100000000010000 0000=
4010 &nbsp; &nbsp; &nbsp; &nbsp;16400</font></div><div><font face=3D"Andale Mo=
no">&nbsp;1174 00000000000000000100000000010100 00004014 &nbsp; &nbsp; &nbsp=
; &nbsp;16404</font></div><div><font face=3D"Andale Mono">&nbsp;1174 000000000=
00000000100000000100000 00004020 &nbsp; &nbsp; &nbsp; &nbsp;16416</font></di=
v><div><font face=3D"Andale Mono">&nbsp;1174 00000000000000000100000001000000 =
00004040 &nbsp; &nbsp; &nbsp; &nbsp;16448</font></div><div><font face=3D"Andal=
e Mono">&nbsp;1400 00000000000000000000000000000001 00000001 &nbsp; &nbsp; &=
nbsp; &nbsp; &nbsp; &nbsp;1</font></div><div><font face=3D"Andale Mono">&nbsp;=
1401 00000000000000000000000000000010 00000002 &nbsp; &nbsp; &nbsp; &nbsp; &=
nbsp; &nbsp;2</font></div><div><font face=3D"Andale Mono">&nbsp;1412 000000000=
00000000001000000000000 00001000 &nbsp; &nbsp; &nbsp; &nbsp; 4096</font></di=
v><div><font face=3D"Andale Mono">&nbsp;1415 00000000000000001000000000000000 =
00008000 &nbsp; &nbsp; &nbsp; &nbsp;32768</font></div><div><font face=3D"Andal=
e Mono">&nbsp;1426 00000100000000000000000000000000 04000000 &nbsp; &nbsp; 6=
7108864</font></div><div><font face=3D"Andale Mono">&nbsp;1442 010000000000000=
00000000000000100 40000004 &nbsp; 1073741828</font></div><div><font face=3D"An=
dale Mono">&nbsp;1442 01000000000000000000000000001100 4000000c &nbsp; 10737=
41836</font></div><div><font face=3D"Andale Mono">&nbsp;1443 00000000000000000=
000000000001000 00000008 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;8</font></=
div><div><font face=3D"Andale Mono">&nbsp;1443 0000000000000000000000000000110=
0 0000000c &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 12</font></div><div><font face=
=3D"Andale Mono">&nbsp;1443 01000000000000000000000000001100 4000000c &nbsp; 1=
073741836</font></div><div><font face=3D"Andale Mono">&nbsp;1450 0000000000000=
0000000010000000000 00000400 &nbsp; &nbsp; &nbsp; &nbsp; 1024</font></div><d=
iv><font face=3D"Andale Mono">&nbsp;1451 00000000000000000000110000000000 0000=
0c00 &nbsp; &nbsp; &nbsp; &nbsp; 3072</font></div><div><font face=3D"Andale Mo=
no">&nbsp;1461 00000000001000000000000000000000 00200000 &nbsp; &nbsp; &nbsp=
;2097152</font></div><div><font face=3D"Andale Mono">&nbsp;1463 00000000100000=
000000000000000000 00800000 &nbsp; &nbsp; &nbsp;8388608</font></div><div><fo=
nt face=3D"Andale Mono">&nbsp;1469 00100000000000000000000000000000 20000000 &=
nbsp; &nbsp;536870912</font></div><div><font face=3D"Andale Mono">&nbsp;1470 0=
1000000000000000000000000000100 40000004 &nbsp; 1073741828</font></div><div>=
<font face=3D"Andale Mono">&nbsp;1470 01000000000000000000000000001100 4000000=
c &nbsp; 1073741836</font></div><div><font face=3D"Andale Mono">&nbsp;1471 101=
00000000000000000000000000000 a0000000 &nbsp; 2684354560</font></div><div><f=
ont face=3D"Andale Mono">&nbsp;1493 00000000000000000000000000001000 00000008 =
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;8</font></div><div><font face=3D"Anda=
le Mono">&nbsp;1545 00000000000000000000000010000000 00000080 &nbsp; &nbsp; =
&nbsp; &nbsp; &nbsp;128</font></div><div><font face=3D"Andale Mono">&nbsp;1545=
 01000000000000000000000000000100 40000004 &nbsp; 1073741828</font></div><di=
v><font face=3D"Andale Mono">&nbsp;1554 00000000010000000000000000000000 00400=
000 &nbsp; &nbsp; &nbsp;4194304</font></div><div><font face=3D"Andale Mono">&n=
bsp;1554 10000001001000100011100010110100 812238b4 &nbsp; 2166503604</font><=
/div><div><font face=3D"Andale Mono">&nbsp;1560 000000000000000000000000000000=
00 00000000 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;0</font></div><div><fon=
t face=3D"Andale Mono">&nbsp;1560 00000000000000000000000000100000 00000020 &n=
bsp; &nbsp; &nbsp; &nbsp; &nbsp; 32</font></div><div><font face=3D"Andale Mono=
">&nbsp;1560 00000000000000000000000010000000 00000080 &nbsp; &nbsp; &nbsp; =
&nbsp; &nbsp;128</font></div><div><font face=3D"Andale Mono">&nbsp;1560 000000=
00000000000000001000000000 00000200 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;512</f=
ont></div><div><font face=3D"Andale Mono">&nbsp;1562 0000000000000000000000000=
0100000 00000020 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 32</font></div><div><fon=
t face=3D"Andale Mono">&nbsp;1562 00000000000000000000000001000000 00000040 &n=
bsp; &nbsp; &nbsp; &nbsp; &nbsp; 64</font></div><div><font face=3D"Andale Mono=
">&nbsp;1562 00000000000000000010000000000000 00002000 &nbsp; &nbsp; &nbsp; =
&nbsp; 8192</font></div><div><font face=3D"Andale Mono">&nbsp;1562 10000001001=
010111011100010110100 812bb8b4 &nbsp; 2167126196</font></div><div><font face=
=3D"Andale Mono">&nbsp;1660 00000000000000000000000000010000 00000010 &nbsp; &=
nbsp; &nbsp; &nbsp; &nbsp; 16</font></div><div><font face=3D"Andale Mono">&nbs=
p;1661 00000000000000000000000000100000 00000020 &nbsp; &nbsp; &nbsp; &nbsp;=
 &nbsp; 32</font></div><div><font face=3D"Andale Mono">&nbsp;1664 000000000000=
00000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;256</font></=
div><div><font face=3D"Andale Mono">&nbsp;3003 0000000000000000000000000000010=
0 00000004 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;4</font></div><div><font=
 face=3D"Andale Mono">&nbsp;3008 00000000000000000000000010000000 00000080 &nb=
sp; &nbsp; &nbsp; &nbsp; &nbsp;128</font></div><div><font face=3D"Andale Mono"=
>&nbsp;3009 00000000000000000000000100000000 00000100 &nbsp; &nbsp; &nbsp; &=
nbsp; &nbsp;256</font></div><div><font face=3D"Andale Mono">&nbsp;3010 0000000=
0000000000000001000000000 00000200 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;512</fo=
nt></div><div><font face=3D"Andale Mono">&nbsp;3011 00000000000000000000010000=
000000 00000400 &nbsp; &nbsp; &nbsp; &nbsp; 1024</font></div><div><font face=
=3D"Andale Mono">&nbsp;3012 00000000000000000000100000000000 00000800 &nbsp; &=
nbsp; &nbsp; &nbsp; 2048</font></div><div><font face=3D"Andale Mono">&nbsp;301=
2 00000000000000000000110000000000 00000c00 &nbsp; &nbsp; &nbsp; &nbsp; 3072=
</font></div><div><font face=3D"Andale Mono">&nbsp;3018 0000000000000010000010=
0000000000 00020800 &nbsp; &nbsp; &nbsp; 133120</font></div><div><font face=3D=
"Andale Mono">&nbsp;3020 00000000000010000000000000000000 00080000 &nbsp; &n=
bsp; &nbsp; 524288</font></div><div><font face=3D"Andale Mono">&nbsp;3021 0000=
0000000100000000000000000000 00100000 &nbsp; &nbsp; &nbsp;1048576</font></di=
v><div><font face=3D"Andale Mono">&nbsp;3023 00000000010000000000000000000000 =
00400000 &nbsp; &nbsp; &nbsp;4194304</font></div></blockquote></div><div><br=
></div><div>Again, I don't see it.</div><div><br></div><div>Any ideas? I'm s=
tumped.</div><div><br></div><div>Regards, Mark.</div><div><br></div></div></=
div>_______________________________________________
<a href=3D"mailto:OvmsDev at lists.teslaclub.hk">OvmsDev at lists.teslaclub.hk</a><=
a href=3D"http://lists.teslaclub.hk/mailman/listinfo/ovmsdev">http://lists.tes=
laclub.hk/mailman/listinfo/ovmsdev</a></span></div>
_______________________________________________<br>OvmsDev mailing list<br>=
<a href=3D"mailto:OvmsDev at lists.teslaclub.hk">OvmsDev at lists.teslaclub.hk</a><b=
r><a href=3D"http://lists.teslaclub.hk/mailman/listinfo/ovmsdev">http://lists.=
teslaclub.hk/mailman/listinfo/ovmsdev</a><br></blockquote></div><br></div></=
div></div>_______________________________________________
<a href=3D"http://lists.teslaclub.hk/mailman/listinfo/ovmsdev">http://lists.t=
</span></body></html>
--B_3466431514_32795896--
--B_3466431514_32784614
Content-type: image/jpg; name="image003.jpg"
Content-ID: <02941424-4E97-458F-B85E-A49E7FAC75FF>
Content-disposition: inline;
	filename="image003.jpg"
Content-transfer-encoding: base64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TwDzjOfSrUvgvU4p44fLUmQE
ghuBgZqPZNmrxNNbs5fbgUbeOK3tQ8L6jpyo00XDvtXac81K/g/VEhMvkEqF3HBB4wT/AEpe
xYfWqX8xgwWktwxWKNnPcKM02W3eJysilWA6EYNdX4OM1pqFw8No85EQDBcfL8wP9Kp+IvP1
LxC6rbOkjbUEZHOcYpuloSsQ/auD2sc7sFIQK2X8N6qBk2UoH+7WfPaSW8zQyoUkU4Kkciod
KXY2jXpy2dypjk0hWtP+xr/AP2SbBGfuH0zVae0mgk2yxsjehGKl0pLoNVYPRMqY/CmkD05q
49lPEm54XVfUioCuKhwa3NFNPYhweKMetSbfWmkc5zUWKTI8E/Sk9qkIOcUw4FSO40kUYpxH
NNIP/wBakMTvxQeB9acR+FJt+lIQwAZoxzTiOfpSd+OKBiH1pyjJA60hHGBVixi828gjP8ci
r+ZqZOyuC3PTvFH+h+BRD/0zij/Qf/E15O/cmvUviLJ5ehQxD+ObH5A/415cyjdzXnZev3N+
7Nqu5FjPWkPXJ/lUnA6mmtkd69EzOlABIHTbj8a9J0AiXwTt/wCmMo/Rv8a80zhjkZwfz613
vge+e5064091GyJSQR1+bg10ZpFuhfs7mGGa5rHm7feOOOajyQSDkcVqa/Yx6drd1aRZMccm
FJHbrWYVyCc1105KcVJdTJ6aBz0zTc8nOenX8KXGOmP8mm54IB7VpYkXceh5yf60ds0uM9+9
Haiw0w79Oc0ClX9M0AY65pWHcXBJzT1HI4/zxTe/XA//AF08ZGMUWGmOGB1NPVzmoueuPrTl
b2oKubFn4n1KzhjhWfdEn8JGePTP41uL4m0jVW8nUrJYI1O9WT1z04HpXFM5C5NMyxPfrTsc
06UWbl7NYf2yjafn7P8AJyfXAz+tdp4z1MQ6KHtLnbJ54GUbnHz15hk4zk0/zXYYYkjPOTSa
vYj2Rcn1K7vFUXFxJKF5AY5x0r0PSJYx4JUbgD9lk4z7PXmAYDJFPFzMI9gkdV9ATjvQ1ccq
V9iVGUSg+h/rXqdrfw63oxNlcGJ1QD3UhTwfyryQHBHFWIby4twfJleMHrtbHY0SVxTpcyse
lWNjrpnYXmoqifwlQDk7v/r1zk8K3fi8QvqAz5YxOvHITgf0rnv7Z1HOfts3XrvPrVUTMDu3
Hd1z3zVJ2Mo4eS6nqVvFqw1Mx3yxXNoXwpIHHzdcfjWH40tLOG4tHgCxySna4XoAAuD+tcwv
iHVQ2ft02Qf73vVS4vprqTzp5WkcgDLH0FSnZ3FDDyTuz0kx61a+RboEvrXGHPcjcaq+KtKs
F0BrpIxDLGFYKvGc7RzXGweJdWtoliiumVE4UHBxzUF9rV/qUapc3DSKnQdOw/wFLmdwjhpc
ybKpYZ4rtvh0Bm+Oedq/1rhgcH0q1p2p3OmXHnWshRsHPoeKG7qx0VIOUbI2/Ftpcrrl3dNE
yxNNhWI4P+cV2d0kl/4SEdjIDIYEwytjGApP8q8+1LxLf6rbrb3ToUV9+AuOef8AGk0zxNfa
RE8VuwKP/C3IHHahvbyMXRqOCXVHUeBtOvra9mnmDJCV24PGWyO351i+OJI5fEDMrBgIUGR/
uiibx1qssTpiNC4+8o5HOciubZ3mcu5LM3JJo5ryuVTpT5uaZq+HGUeIrDdgD7QmSf8Aers/
Gwuv7Nh+zbvL/wCWhX0wuP5V50h2MCDgg5BFdRa+ObqC0S3mgScoMbmPXg4ovqmKtSm2pR1O
q8GR3cekKt0G5kzHu/u8f1Jql4OG651WUd5AP0esi28fXMIcPbq4MhZBnG0ZBAqloXig6QLk
GHzfPcNnOMcMP60m9/Mz9lUs9DXt7+W18a38qQNKhkKSbRnaNw5/Srzrb+I7jz7C8kt5YgN6
888en4Vy9j4lkstbuL8ISlwxLpntnNbEHjTTbeXzItN2MeCVABIyf8armS1W5FSjUb0Q4pen
xxZpfOHaNsowGAV5Iqz411O4sRb28DlBKpZmHXgkVz6+KC/iOPVLhCVjBUKPTBA/nUfibxBF
rdzBJCjIsSFefdif60rrmTNVRlzK6O0upmt/DMV66rJPDCkis5/iIXn9TVXwbeXF5Y3ElxIZ
D5wVc9uOn61ian4stLzw+bCONxIUReRxwBn+VN8L+JrLSbB4LjduaXfwO3H/ANelfQxdCXI/
d1NXwt82q6vNgY34/Un+lVI7+3tPHd48+MMxjUkcA7h/hVTw54istPN6bosDO4K4GeMN/iKr
2muWSeI7u6uIlkt7ljhmGdozkGqurjdKd5adDpNQm1C9uFl0i6iljwN6ZHBx/XBrntS1BJPF
VvNf2ghED4lXGdwyTn361p6bqvh3Tbhpbad1L8FWJwevbFYt9r1re+I472SDfbouwo3cYxn+
tNyS0Jo0pXfuu1n0szrNTubqSCM6RJHI6jDR9yMEZ/CuU8UX8s8cEN3ZmG7T5mc/xAgdK14Z
vD9tqYvbe/MR3/cU/LjPT6Vl+KtbsdQntY4x5iQNl2H8QIHH6USaSJw9OSqL3dvKwy38VG7P
kanaJNBgfKo5yOn860F8N6Xrlst/bB7VWUgIBxkDr+lUW8R6Np7+bptgDIxIYOONuQf6VnXX
i7UJXfyCsEbjGxR04wamVWCVm7myw9WTvTjyfP8AQyr+1ayvJrZyC8TFSV6HBqoTxxTpJGlY
s7EseST1pmAeK4ZSvsexFNLUbnim4NP6DpSD1rO5Y0+9IByadigDFIEMx7Gl47U48cYoHoQa
BjeMY60hB6j8akKjGe1NYen/AOukBHj0rW8NRCfxHp6Y4NwhP4GsvBx3rofA8PmeJ7b/AGA7
/kprDES5aUn5MqGskdD8SpcQWMPqWY+/Qf0rzpxnvXcfEmXOp28QOdkOfzY1xJ6c1jglahEq
o/eZEQR9abjJ5/Wnnmmt0z0rsIN9eM4OR+ldN4M1RbDVTBJsVLnCMzHG3kc1zK8qKkUhGBye
vH517FekqtNwfU8+E3CSZ2Hj7Q1KJqcCYBGJeepOcH9K4EggcivWdFv4fEXh9oLgo0wQo67e
BwQDXnWvaLPouotbSjcp5RuxXOM/pXl4Gq43oT3j+R01Yr4lszK29ycUm0dBT2HHUikGdxr1
DEbgZ696v6LYx3+pR28pIV85x9Kpgc/Stbw3hdct/wDeIqorU568mqcmuxbttBgm8QT2DOwi
jBKnHNM+waOb1rM3MiOrFSzLgZGO+frWvaDb4xuu/wAnX/gIrnNShd9YukRGJMzcY681ocNO
c5ys5W0TEv8ASJ7CNJWKvE44dTkd/wDCqr28saK7oVRuhI6101+Qngy3jbhwy5B69WrGvdSu
rqygt5UAii+4QOvAFS0jqoVpz+9oZYaXNqB/dlQAQDk+oP8AhT9Y0ttKvBb+Zvyu4EfX/wCt
UGnki+g5I+cVseMsf2vGRnHl9P8AgRpW0HKpNYhRvo0Y9lptzqGfIXIUgMfT/OKk1fSZNKuV
gd1fcuQR9SP6VFYMy3kWGZQXGcHGa2vGWP7VjI4/d9/95qdlYmdWarxjfR3KNt4fmudNF950
aR8j52xjFV7zTPskQk+0xSDdjCMCe/8AhWta6taR+HPskqs755UDAPI70o06z1LRri7t4zA8
LE4LZBABNVyqxgq9WMrz0V7GVZaTcXsDSx7VjT+JzgdqfcaJdQWzXB2SIpwxRgcdf8KhtpHk
AtpLpordid2Sdvbt+Aro7JUtPDt8LV/tKtncyjG0bW5pcqsXWr1Kb369v1OR5Bx+tBoJppzx
zWDZ6KHZJOKTJ7frSH72cmlBqLlBnmgjjAFIASfalPTrU6jsGefxoz/Kk70c9O9FwFzzSEml
I9aVVyRQrsTHrbT4DCNueRx16U14XXAdSufWuw1u8nsdG0827+WzIM4HX5VqDSZk8QSfZL2F
WZITiUcEc/8A166PZx2ueZHGT9n7Vx9311OVxgcc0ozWpaaXDPfTxTTiOOEnknk+mB+FW7XQ
7PUDJHaXDmVVyA6bc84/rU+yZ0SxdOG/5GCqk8gZowRXW+GrK1FneGVVd1BDBlzswDWDPaRt
fR29pMJhIfvY24OenNDpWFDFRnOUbbdSj05zRk561syaHbpcC3N/H5hwNu09SOKhbQ5o9WGn
uwRmPysehHrUulJGkcTSfXpf5GXuPT2pcnP1NXpdLeLVBYb1d94QHsc1sS2+m6VNDZTW/nOw
Bkf0yBjH40o0m9xTxUI2SV29dOxy/IppP4Zrdu/Ds0WqCzSSP5wWQs2Mjdj86yzp9wLr7N5R
83ptx0pOnJGkMRTmrp+ZX3DGKQMauzac1perb3Uipz8zA7toz7VqXej2UHh1buJ2kkYgBux5
Pb8KXspO4TxNOLiv5tjncknijnufwq/pulzajOUj+VU5dz0ArROj2F6s8WnSu08RyFb+Mc9P
0ojSk1cVTFU6cuV/Py9TnyxB74puT2rQsdIuL2d41G1UyZGPReM/0q9LodtPDM2nTtNJAx3I
QORnqPzpKjNq45YmlGXK2YG5iOtNwQetaNhpkt9IQg2ov33PRRVi50VDavPZz+f5TlXAGCMY
5qPYzauXLEUoy5W9TFIwOlN/GtHT9Lmv5hHGNqj77noozj+tTXeitDa/aYJVuI8lXKj7p96n
2M2r2KeIpxlyt6mPtpMYrQsdMmv5tkQwo+8x6Lz3/OnXmkS2kCTh0lhfjehyAeeP0qfYztew
3XpqXK3qZpGMc0hUnmr1np0185WJeAMlj0HGeT+FLeaZPZKjvtZJBw6HI/Ol7GVr20K9tDm5
b6lAj0pMdcVdtdPnvWZYU+6MlmOBwPWi7sJ7JwJlA3DII5yPrUunK17aFe1hzct9Sjg4pwHP
9KdigDmsmjVBjAprAkcVJ1FJt5qRkODXWfDqEHXpJG6RwH9SB/WuWK56V6V4MtEsvDL3TxCO
djIxYjDFQAR+HFcOOny0Wu+hpTV5GB48Tz9Xdl6xoqn8q40nB5/Wuiu7iW6d3lYszHknqawJ
12SkeldNKHJBR7Ez1dyJuKiZwOSfapG/nVW7bEa845rUg6QNwPbilY7gPzpDw2MgCjJ6kY4r
6A8w2NA1ufSLjfEco3DoTww/ya7jUdPsPGGmie2YLMB8rHqvJ4PpXmSNjvxWto2uXGkXYliJ
2HG9OzD/ABrzcXhHN+0p6SX4nVSqJLllsV9Z8OXmjzhJkLKw4dRkHgH+tZO3uR3r1jTvEela
3GsNwiLMxIEUgzjgc5xis3VvAdrcgzadIFKoSEJzuOTXJTx0oPkrxs+5pKj1jqjzj2qe0upL
K6SeHAdDkZGa1bvwnq9lbvPLatsQDOPw/wAay/sVwOsLY+lelCtCWsWc8oX0aLCa3dR6i18N
pmZcHjjpirA8RzrP532a383du3bTnOazPslx08tunTbSfZ5d2DG/5Vp7QweHpvdElxf3F4QZ
5Wk2/dz2qze6u95YwWjRqqw4ww6ntVIxSBfuN+VNEbA8qR+FLnL9nDTTYu2F7DZks9uJmzlS
WI28Vb1TXIdTVmltAJcbVcP05z0rG2tjvShcfnRzidCEpc3Uuadd21qS89uZWGCpDYwav6nr
VpqhMktq6y7SqsGGByT/AFrFAO0c9qUKSOlP2hLw8ZT53uaNlqFmli9tdW28HlXUAMPxq0+s
29vpktlYxOomJ3GQ9jn0/CsTbwMClC5bJFJ1WDw0JO7NCyu7EWL215Ack5WRB8w6VcGsWdnp
k9pYiRvOJBMgxgEEf4VhbTn8KXYaXtXawPCwbu/UYeetAGPanhDSheeaybOpIjI5oxn04p5H
HIFLt6Z4qblDNufakI4qQLxR5ZPT1ouBHj1NOA5pxTIHGcCgL7d6VwG4OM05BgjpyaXHGDxS
dD7VSkJo6zWEh1LT7OKC5hzEnzZcD+Ff8Khs5LLw85l+0edO8X3FHGd3r+Fc1gijPOPStvbL
seesD7ns3L3Tf0KSznurl7gDz2DNEG+70Of6Vs6PMyXMiXJt45MA7YwAcbh3FcRyMAHmlDHq
Cc+tNV7KxNbL1VbfNudX4fYG01LaRuclVHrlWrEhs0h1SKC/PlIxyxz09KoCRgeHP4UMS3JO
al1kzWGElGUmpfEdgYUh1lFFlCkAkASUk/Meenv1/KqWuW8moeI1t4HAcxAgk4Awua57zpdw
zI3ByMnoaQzS7/M8xt4H3t3PSh10+hnDAzhLmUtbWL0X/Er11PtLb/s8w3kHOcGtfUrGXUNX
huodjQuisH3DACjn+Vcw7u7l2JLE5JJ5qRLy6jj8pZ3VOm0Nx3zUxrRW5rVws5SU4vW1jd1m
U6trcaaeSzRDBcHGCGJzmtF545g9pBNEdRVMeZtxuGCMA/iK4+C6uLZmaCVoyw5KnGaZHK8c
iyIxV1bIYeuapYhIxll7klG+kdv+D5Ek6Ti5kWUMZcndnkk10WoIyeELOMKclhx+Lf41z5vr
k3IuTKTMBjf36Y/lU/8Ab2pEYNxke6ipjVgrm1WhVm4NW01/rQ0/CsiKl7GWxK8fyL68H/61
P8NxNaXdzc3CeWka7SzcDO4ZFc5FNJFMJYyVcHIIqzdareXkWyaT5cliFGMnjrj6U1XikRVw
U5uVnpK1/l2NvQZlaDUwpBkcEhR1PDf403wyptjd3Ev7tQuMtxz/AJFc9b3MtpcLPE211OQf
xqe61a6vIBHIVVAclUGAfr+VCxEbXe4p4KcnKK2lb5WNnR3H9iajtILtngdemP603w4PIsr+
Z/lGzCk9/lb/AArDsr+axuBNA3I6g9D9alvNWuLuJYcLFEv8CdM5PP601Xha73QVMHOTlFbS
ad/Q19NIHha9IPzFjx3/AIaboJEWiahIw4IwM/7p/wAaxbDUZtPlLx/MrqQyHo3FSXmrS3UK
QoghhQfcXp1/+vSVeFk+o5YOo3KPRu9/0NW2xH4OmZTgs5/mP8KNLUDwzfM4BBJxn8P8ayLD
U3si6MglhkGGjbp3H9aL3VXuY1hhXyYVGAg78Dr69KPbwSv1sDwlRycejle/6GqcQeEEZDta
Rhkr16t/hSQBf+EPlaQBvnO3dzjlen61mWeqiC3ktriPzYHH3c/dPqP1pl9qjXCLDCvlQKMC
MfzNL28LXv0tYFhanNy9Obmv+hq3QW18LW3lHY0pG4rwW6/4024UN4QieUB33YUnqOSP6VnW
2qIbB7S8jMsY5jIPKHj/AApmo6m15iGFBFbp9yMduc/1pSrw5W79LWKhhpqSVtpXuZ/UE0pH
B4puDTgCa81yPWSEAx+NGCR608fSrVjY3F7cJb28Zkkc4AFZykkrsqxc8NaE+s6kqMpNuhzM
ynBArqfGusCzhi0u1bkqNxB6AZGK1I4tO8J6KxUhZmTlj95mwcD8683u7qXUNRkuZT88rlmr
zKf+0Vud/Ctjb4FYk2/KPpWXfKPPPIrYYAdKxrwh7huOnFeojKRXYfLWdqB+4PrWiw4xmsy/
P71R6CmQdUMnIbnmjnHSmg5A6gYzgUduDxnrX0B5pICQOh60Z49//rUwAAYHNOHIyRTsK5Ir
bSSp6HFbmk+KtQ0sqobzoUXasTngdf8AGsAYwQego3fLxx/+qsqlKFRWkrmkJuOx3lr4/wB8
6re2iLEchipJPbt+FaQ8Y+H3ALLz7w+5rzIPyM0byRmuCeWUJO6VjZYmXVHpp8TeGnXBEfTv
B7D2pw13wqzf8u3J5zD7n2rzDJwc/wCelAfP+H51m8qpdGx/WH2R6cNS8JOv/Lp0/uew9qk+
0eEXbJNn1+nc15buxjmlDZOSTjtUvK4dJsarr+U9PCeEZEzm06f3/Ye9SfYfCjngWuM/89fc
+9eW7/qcf4VNFPtYBmOM9u3NH9mdqjH7eP8AKekjSfCrrwLfOP8Anr7D3qwPCnh+Q5EKkE54
k/2jXlsiY+ZP88VqaRr72bCOcs0eRznpzUPL5x/5eMarQf2Tu/8AhDdBKj90enZ/YUp8D6GW
wI3HP94ep9qyoL+C5h3Ryg/L0B/2RVpZWDD5z971/wBo1H1Sov8Al4x+0h2Jz4D0crwJBx6j
0HtSnwBpBbAaUc+3r9KriZwmfMbO31P90VIbh9/Ejfe9f9o0fVqv/Pxhzw7A3w+0or/rJeno
PQU0/DvTC3E8o5/u+9RyaiYYS0lwVwuc7v8AZrB1XxZLuaKzuH5J+cMfU9KPq1f+cfNT7G83
w707bxdOMD+77fWkPw4sd2BdvjP933+tcXDqupPk/bZwMf8APQ+lWH1/U04W+nGD/fPrVfVM
Va/tBe0pXtY6j/hW9qRxenp/d9vrTT8NoS523wxnpt965YeIdVVf+P8Anxj++fSn/wDCTaxn
I1Cbr/e9xUfVsX/z8K5qXY6M/DVSuRfr07qfSmt8M27XydfQ+ornx4p1kD/j/l6evsakXxfr
Stn7e5x6ge1HsMX/ADoL0jX/AOFazdryLOPf0Pt7Uh+Gt1uO27h5+vt7VnnxdrTJlbwk+m0e
9Ft441iKUeZOHXuCg9ql0cYvtIP3TLh+Gt8TkXMR7dfr7U1vhvqOMrLCeM/e+ldBaeJ5rxA8
UiEEjIKjjk1P/bl3sBBTp/d/2aOTFr7SF+7OVPw41QMPmiPP94etMPw81fGQI+n98eldh/bt
3uPCcH0/2qT+37ry8bI87eOPY0rYvugXs31OOPw+1gNjy0P0cetMPgLWwBiAHj+8P8a66LX9
T8wmVYCoz0ByenvU0nid4Rl0jAHU5+tH+19bDtT6M4hvA2trz9lJ+hHtUbeCdcDf8eTn/wDW
a3rv4jzLLtgtYyo4JJPPApY/iJdEbns48Z7MfX/69L/a+yKtDuc2/g7W1BJsZemeB7U1vCet
A4+wTdf7p9a6X/hZEuP+PBen9/2pw+JBzk2H/kT6e1TzYtfZX9fMfLDuck3hjWBj/QZun9w0
w+HtVUZNlN/3wfauyHxKUcmwb8H+vtTx8SISPmspBx1Dj0pe0xf8gcke5w/9h6iDg2coP+4a
jbSb4Dm2k4/2TXoLfEa0U5+yTYz6j1qWz+IGn3MgjeGWMngE49xR7XEreA+RdzzY6bdgkG3k
HP8Ad96abG5HWF/yr14+I7Erko/Iz90egNL/AG9pxOTGev8AzzHr/wDXpe2xH8gcq7njxtJg
OY2H4U020gP3G/KvYf7Z0p1G6IcjvEPQ/wCFI+qaMesUXPrCPY1H1iv/AM+x8i7njv2eTH3D
nHpSGFx/Cfyr2I3mgu2DBBwcHMI9SPSo3n8OGPLw2w47xAdvp7UfWqq/5dsOTzPIDEw/hNM8
tsdK9Tm1PwespVo7U7T/AM8/ce1It14NkAPl2gGfQj1qfrk/+fbH7Nnluw56U0pzyMV6jv8A
Bb5ylsCR1yfSmmLwY5+UW/8A38I7/Wl9df8AIw9mzy/YeuB0pCvqK9PFh4MbHMI5/wCep9T7
0n9jeEHHWPp2m9vrS+vLrF/cHspHmGwgUmwkelemPoXhIsQJNuO/nfSpB4T8NSjMcjEZ5xMP
Wl9ej/K/uD2cjzEJk8c/SpYrOWYlYo2Yj0HSvSo/Dvh3TGW6f5x93bIwYcgjpipxqmiaejzW
UUSuwwRGMFhwaTxU5fBBsah3OY0vwDfXBD3jLbqGGVPJYd8Yro7m40bwvZ7raNDKU2Db95sY
6/zrH1bxFqF2xS3kEEW7chH3uvQ/nXMzWU8jkvJuJOTzSWHq1Xeq9OxV4x2G6tq9xqly0sz5
54HYVRgyZwOeO1WW09+NzgUR2/kMzE5OK7owUVZEXuLcMscRbPOOKxm+d8kd8mrV5cGZsZ+U
VWxhM4rREsjkI3dKyb45uOvQVqnP1rIuzm6f64oYjrO4pG+631/rRRX0J5gi9D+H8qf2H1FF
FMRJH/rG+tEf+pP1/pRRQAw9TR3P0/pRRQxoQf1/wp56LRRUjFXo/wBP8KB/q2+n+NFFJghP
4DSr1oopDZZ/5Z/8B/pVb/lp+NFFEhRNPQ/9ef8APauwh+5/wL/2Y0UVzSNkO/5Z/wDAf/ZR
SN/X/wBmoorMDnNc/wCPY/QfyFc6KKK0iJl1f9T+H9DUMn3z9f60UVvLYzjuRj7tOXof896K
KyNA/hX/AD605fvH/PpRRSBE8P3v8+tQyf60/jRRTew1ua/h7/X/AIj+Yrpx/qx/u/8Aspoo
rBlky/eP1P8A6EKj/wA/+hUUVBKA9B+P8lrC8Qf6n/gf9Wooo6lo5gfeFXZeg+n9RRRWkRPc
rdv8+9Ifu/jRRUspCN1P+e9J3X6UUVIx5+4fof6UyP8A4+E+o/nRRUTHE7G3/wCPVP8AcH/o
NSn/AF4+n/swooqUNiL9/wDz71G3T8P/AGUUUUDF/wCWh/3v61Uvv+PZ/wDd/o1FFQxnKS/f
P1qQ/coooiBEe/1pF7/WiioZSGjvUkfSiipKFk+4laWlf6lvqf6UUVDKRek+6v1/rUD/AHV/
z2NFFNAxsv8Aqm+tI/3j+NFFWSMk+5Wfe/6miigDHPb8KJulFFAiI9R9Kxbj/j4k/wB40UUm
I//Z
Content-type: image/png; name="131004 Roadster Pump Failure[1].png"
Content-ID: <2E3537BC-8E56-428C-A08E-C753EDBD7EB7>
	filename="131004 Roadster Pump Failure[1].png"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--B_3466431514_32784614--
